Problems with Percentage: From 300 to 3,850 - what percentage increase is that?
  • Context: MHB
  • Thread starter Thread starter riffwraith
    increase
The discussion revolves around calculating percentage increases, specifically from 300 to 3,850 and from 300 to 5,000. Participants explore the formula for percentage increase and clarify the calculations involved, addressing potential misunderstandings regarding the results from online calculators.
  • One participant suggests dividing 3,850 by 300 to find the percentage increase, resulting in approximately 1283%.
  • Another participant calculates that 300 increased by 1666% results in 5,000, questioning the correctness of this interpretation.
  • A further clarification is provided that increasing 300 by 1666% actually results in 5,298, highlighting a distinction between percentage increase and the final value achieved.
  • One participant emphasizes the definition of "percent" as "per hundred" and provides a simple example of a percentage increase.
  • Another participant notes that the final number can vary depending on the direction of the calculation and the starting point, suggesting a need for careful consideration in percentage calculations.
  • One participant illustrates various percentage increases from 300, showing how different multipliers correspond to specific percentage increases.
Participants express differing views on the interpretation of percentage increases and the calculations involved. There is no consensus on the correct approach or final values, as some participants challenge and refine earlier claims.
There are unresolved mathematical steps and assumptions regarding the calculations of percentage increases, particularly in how they relate to the final values derived from different methods.
riffwraith
Hi all. Hopefully this is in the right place.
I tried using an online percentage calculator, but it's not giving me the correct results, and was hoping someone here could help me.
-and-
From 300 to 5,000 - what percentage increase is that?
Again, the online calcs I have tried aren't working properly, and I have no idea how to do this with a regular calculator. Is there a formula for this? :/
Thanks in advance.
Hi riffwraith and welcome to MHB! :D
Dividing 3850 by 300 will give you the correct answer:
$$\frac{3850}{300}\approx12.83$$
Multiply the RHS by 100:
$$12.83\cdot100=1283$$
So $300$ increased by $1283\%$ is $3850$ (which is approximate due to rounding.)
Can you apply this to the second problem? Do you need any clarification?
Thank you! :)
Based on what I see - assuming I understand correctly - 300 increased by 1666% is 5000.
That correct?
riffwraith said:
Thank you! :)
That correct?
$$300+300\cdot\frac{1666}{100}=300(1+16.66)=300\cdot17.66=5298$$
Here, we have taken 300, and added 1666% of 300 to it. However if we multiply 300 by 5000/300 we will get 5000.
$$\frac{5000}{300}=\frac{5000}{3}\%=1666.\overline{6}\%$$
So, we can say 1666% of 300 is roughly 5000, but if we increase 300 by 1666% we will get a larger number, namely 5298. Do you see the difference?
https://percentagecalculator.net/
"percent" means "per hundred"
Simple example:
200 increases to 218: that's "9 per hundred", right?
Henceforth***:
200 * 1.09 = 218
***I went to French school (grades 1 - 8),
then to English school (grades 9 - 13);
I noticed that Mr Fraser (my English Lit teacher)
loved the word "henceforth", and used it often...
Soooo...I'd use it on tests and always got a pass mark :)
I think - it seems as tho the final # you wind up with will vary depending upon which direction you go, and/or what the starting point is.
Cheers.
Cheers.
300 + 1*300 = 2*300 = 600 -- Pretty obviously a 100% increase.
300 + 2*300 = 3*300 = 900 -- Pretty obviously a 200% increase.
300 + 3*300 = 4*300 = 1200 -- Pretty obviously a 300% increase.
300 + 4*300 = 5*300 = 1500 -- Pretty obviously a 400% increase.
Feel free to tear things apart and see how they work.
  • · Replies 17 ·
