Producing a metric with only a single coordinate function
grav-universe
Given the metric
c^2 d\tau^2 = c^2 B(r) dt^2 - A(r) dr^2 - C(r) r^2 d\phi^2
and solving only for a static, spherically symmetric vacuum spacetime, I want to reduce the number of coordinate functions A, B, and C from three to only one using the EFE's. We can then make a coordinate choice for that one function in terms of r and automatically produce the entire metric from our choice for that single function. The four components of the Ricci tensor for a vacuum spacetime are all zero and these are
(-4 r A^2 B C) R_{00} = 2 r A B C B" - r A C B'^2 - r B C A' B' + 4 A B C B' + 2 r A B B' C'
(4 r A B^2 C^2) R_{11} = 2 r A B C^2 B" - r A C^2 B'^2 - r B C^2 A' B" + 8 A B^2 C C' + 4 r A B^2 C C" - 4 B^2 C^2 A' - 2 r B^2 C A' C' - 2 r A B^2 C'^2
(-4 A^2 B) R_{22} = - r^2 A B' C' - 2 r^2 A B C" - 8 r A B C' + r^2 B A' C' + 4 A^2 B + 2 r B C A' - 2 r A C B' - 4 A B C
R_{33} = R_{22} (sin \phi)^2
as graciously worked out for me by Markus Hanke in this thread. Okay, so we will start with the R_00 component. Dividing all of its terms by r A B C B" gives simply
\frac {2 B"} {B'} - \frac {B'} {B} - \frac {A'} {A} + \frac {4} {r} + \frac {2 C'} {C} = 0
and finding the indefinite integrals for this gives
log(B'^2) - log(B) - log(A) + log(r^4) + log(C^2) = k
log(\frac {B'^2 r^4 C^2} {A B}) = k
\frac {B'^2 r^4 C^2} {A B} = e^k = k_2
where k and k_2 are constants. In this thread, Pervect works out the local proper acceleration of a static observer as
a = \frac {c^2 B'} {2 B \sqrt{A}}
where B = f and A = g for the metric he uses (with an opposite sign convention for the metric itself). With the equation we just gained then, that gives
a = \frac {c^2 B'} {2 B \sqrt{A}} = \frac {c^2 \sqrt{k_2}} {2 \sqrt{B} r^2 C}
Since we know that in the low Newtonian limit, B and C work toward unity and the proper acceleration works toward a = G M / r^2 = m c^2 / r^2 and k_2 is a constant for all r, then k_2 = 4 m^2 as we can see in the last part of the equation.
Okay, so let's explore the R_11 component. If we divide all of the terms on the right side by A B B', we gain
\frac{2 r C^2 B"} {B'} - \frac {r C^2 B'} {B} - \frac {r C^2 A'} {A} + \frac {8 B C C'} {B'} + \frac {4 r B C C"} {B'} - \frac{4 B C^2 A'} {A B'} - \frac {2 r B C A' C'} {A B'} - \frac{2 r B C'^2} {B'} = 0
Now we are going to change the metric slightly to make the mathematics easier. We will say D = C r^2, so that the metric now becomes
c^2 d\tau^2 = c^2 B(r) dt^2 - A(r) dr^2 - D(r) d\phi^2
The derivative and double derivative for C are now
C = D / r^2
C' = (r D' - 2 D) / r^3
C" = (r^2 D" - 4 r D' + 6 D) / r^4
and plugging those into the terms for the r_11 component we just gained, it reduces to
simply
\frac {2 B" D^2} {B'} - \frac {B' D^2} {B} - \frac {A' D^2} {A} + \frac {4 B D D"} {B'} - \frac {2 B A' D D'} {A B'} - \frac {2 B D'^2} {B'} = 0
and rearranging, we get
D^2 (\frac {A'} {A} + \frac {B'} {B} - \frac {2 B"} {B'}) = \frac {4 B D D"} {B'} - \frac {2 B D'^2} {B'} - \frac {2 B A' D D'} {A B'}
Earlier we gained from the R_00 component, the relation
\frac {A'} {A} + \frac{B'} {B} - \frac {2 B"} {B'} = \frac {4} {r} + \frac {2 C'} {C}
which now works out in terms of D to simply
\frac {A'} {A} + \frac{B'} {B} - \frac {2 B"} {B'} = \frac {2 D'} {D}
So plugging that into what we gained from the R_11 component now gives
2 D' D = \frac {4 B D D"} {B'} - \frac {2 B D'^2} {B'} - \frac {2 B A' D D'} {A B'}
and multiplying these terms with B' / (2 B D D') gives
\frac {A'} {A} + \frac {B'} {B} = \frac {2 D"} {D'} - \frac {D'} {D}
Finding the indefinite integrals in the same way as we did before for R_00, we get
\frac {A B D} {D'^2} = k_3
The relation we gained earlier for R_00 was
A B = \frac {B'^2 C^2 r^4} {4 m^2} = \frac {B'^2 D^2} {4 m^2}
so plugging that into what we have now gives
\frac {B'^2 D^3} {4 m^2 D'^2} = k_3
B' = \frac {2 m \sqrt{k_3} D'} {D^{(3/2)}}
and the indefinite integral of that is
B = - \frac{4 m \sqrt{k_3}} {\sqrt{D}} + k_4
and switching back to C for a moment,
B = - \frac{4 m \sqrt{k_3}} {\sqrt{C} r} + k_4
The constant of motion for energy is
E = \frac {\sqrt{1 - v^2 / c^2}} {\sqrt{B}}
where E = 1 for an object falling from rest at infinity, so we have
B = 1 - v^2 / c^2 = - \frac{4 m \sqrt{k_3}} {\sqrt{C} r} + k_4
where v is now the escape velocity, which in the low Newtonian limit is just v^2 = 2 m c^2 / r and C works toward unity, so k_4 = 1 and k_3 = 1/4. We now have
B = 1 - \frac{2 m} {\sqrt{C} r} = 1 - \frac{2 m} {\sqrt{D}}
as our general relation for B. The derivative of B is
B' = \frac{m D'} {D^{(3/2)}}
and plugging these into the relation we gained from R_00 earlier, we now get
B'^2 = \frac{4 m^2 A B} {D^2} = \frac{m^2 D'^2} {D^3}
4 m^2 A (1 - \frac{2 m} {\sqrt{D}}) = \frac {m^2 D'^2} {D}
A = \frac {D'^2} {4 D (1 - \frac {2 m} {\sqrt{D}})}
And plugging those back into the metric finally gives us
c^2 d\tau^2 = c^2 (1 - \frac{2 m} {\sqrt{D(r)}}) dt^2 - \frac {D'(r)^2} {4 D(r) (1 - \frac {2 m} {\sqrt{D(r)}})} dr^2 - D(r) d\phi^2
The metric is now described solely in terms of the single function D. Once we make a coordinate choice for D in terms of r, we will automatically gain the entire metric. It is interesting that we only needed the R_00 and R_11 components of the Ricci tensor to solve for the metric. We could also rearrange using the couple of relations we found to describe a metric in terms of only the time dilation, for example, with
c^2 d\tau^2 = c^2 B(r) dt^2 - \frac {4 m^2 B'(r)^2 dr^2} {(1 - B(r))^4 B(r)} - \frac {4 m^2 d\phi^2 } {(1 - B(r))^2}
If we wish to find a solution for an isotropic metric, where A = C or A = D / r^2, then we would have
A = \frac {D'^2} {4 D (1 - \frac {2 m} {\sqrt{D}})} = D / r^2
r D' = 2 D \sqrt{1 - 2 m / \sqrt{D}}
with a solution for D according to Wolfram of
D = \frac {(k_5 r + m)^4} {4 k_5^2 r^2}
C = \frac{D} {r^2} = \frac {(k_5 r + m)^4} {4 k_5^2 r^4}
C = \frac{(k_5 + m / r)^4} {4 k_5^2}
where C works toward unity in the low Newtonian limit with large r and this relation would reduce to 1 = k_5^4 / (4 k_5^2), so our constant k_5 = 2, giving
C = \frac{(2 + m / r)^4} {16}
C = (1 + m / (2 r))^4
Strictly speaking, the EFE's use the Einstein tensor; but in the vacuum case the Einstein tensor being zero is equivalent to the Ricci tensor being zero, so it amounts to the same thing. The Einstein tensor components don't look any neater, except that ##G_{22}## and ##G_{33}## are exactly equal (the factor of ##\sin^2 \theta## difference goes away).
Just to sanity check, let's evaluate how this works out for the Schwarzschild case, where ##D = r^2## (you have already partially evaluated the isotropic case, where ##D = r^2 \left( 1 + m / 2r \right)^4##--but it would be nice to confirm that your formula for the metric gives the right isotropic metric when the formula for ##D## is plugged in). The metric becomes
c^2 d\tau^2 = c^2 (1 - \frac{2 m} {\sqrt{r^2}}) dt^2 - \frac {(2r)^2} {4 r^2 (1 - \frac {2 m} {\sqrt{r^2}})} dr^2 - r^2 d\Omega^2
On evaluating the square roots and canceling, this gives the correct Schwarzschild vacuum metric. (Note, btw, that I used the more usual notation of ##d\Omega^2## to represent the angular part of the metric.)
Another note: the physical meaning of the function ##D## isn't immediately obvious. It would be interesting to try expressing everything in terms of ##B##, since that has an obvious physical meaning--it's the "time dilation factor" for a static observer, or, in more coordinate-free language, it's the invariant squared norm of the timelike Killing vector field.
Now for the obvious next question: :wink:
How many independent functions do you need to describe a static, spherically symmetric spacetime that is not vacuum everywhere (i.e., the stress-energy tensor components are nonzero in at least some region)? Note that for this case, you will need the Einstein tensor components, since those are what are equal to the SET components (with a factor of ##8 \pi##).
The non-vacuum case is also of interest because we know from Birkhoff's Theorem that there is only one spacetime geometry that is spherically symmetric and vacuum, namely, the Schwarzschild geometry. (Note that you don't have to assume staticity to prove the theorem; the fact that the spacetime is static can actually be derived from the assumptions of spherical symmetry and vacuum. That was the original point of Birkhoff's Theorem.) So the vacuum case you've analyzed is of limited range, since it only works for one particular solution to the Einstein Field Equation. The case of a static, spherically symmetric spacetime that is not vacuum is more general, since there are multiple possible solutions meeting those conditions.
Thanks PeterDonis. The metric in terms of the time dilation is also given. It is
c^2 d\tau^2 = c^2 B(r) dt^2 - \frac {4 m^2 B'(r)^2} {(1 - B(r))^4 B(r)} dr^2 - \frac{4 m^2} {(1 - B(r))^2} d\Omega^2
I would like to move forward to a more general solution, but I'm not sure what that would entail. I would have to see specifically how all of the functions in a metric are laid out like they were done for me with the components of the Ricci tensor.
You equate the components of the Einstein tensor with the components of the stress-energy tensor. The components of the Einstein tensor are expressions in A, B, C and their derivatives, just like the Ricci tensor components (but slightly different expressions), and the components of the stress-energy tensor are the energy density and the pressures in the radial and tangential directions. For the case you are looking at, the Einstein tensor (like the Ricci tensor) is diagonal, so you have three equations:
G^t{}_t = - \frac{4 r^2 A C C'' - r^2 A (C')^2 - 2 r^2 A' C C' + 12 r A C C' - 4 r A' C^2 + 4 A C^2 - 4 A^2 C}{4 r^2 A^2 C^2} = - 8 \pi \rho
G^r{}_r = - \frac{r^2 B (C')^2 + 2 r^2 B' C C' + 4 r B C C' + 4 r B' C^2 + 4 B C^2 - 4 A B C}{4 r^2 A B C^2} = 8 \pi p
G^\theta{}_\theta = G^\phi{}_\phi = - \frac{2 r A B^2 C C'' - r A B^2 (C')^2 + r A B B' C C' - r A' B^2 C C' + 4 A B^2 C C' + 2 r A B B'' C^2 - r A (B')^2 C^2 - r A' B B' C^2 + 2 A B B' C^2 - 2 A' B^2 C^2}{4 r A^2 B^2 C^2} = 8 \pi s
where ##\rho## is the energy density (the minus sign is there because we are using the mixed Einstein tensor, with one upper and one lower index; if both indexes were lower, there would be extra factors on the RHS of these equations that would make them messier), ##p## is the radial pressure, and ##s## is the tangential pressure (note that the pressure must be the same in both tangential directions, by spherical symmetry, and the last two diagonal components of the Einstein tensor are identical for the same reason). I used Maxima to compute the specific expressions for the Einstein tensor components that are given above. Note that ##\rho##, ##p##, and ##s## are all functions of ##r##.
Note also that it will probably be simpler, rather than trying to solve the last of the three equations above, to use the fact that the covariant divergence of the stress-energy tensor is zero. The covariant divergence is a set of four equations ##\nabla_a T^a{}_b = 0##; the ##r## component of this equation reads
\nabla_a T^a{}_r = \partial_a T^a{}_r + \Gamma^a{}_{ad} T^d{}_r - \Gamma^e{}_{ar} T^a{}_e = \partial_r T^r{}_r + \Gamma^t{}_{tr} \left( T^r{}_r - T^t{}_t \right) + \Gamma^\theta{}_{\theta r} \left( T^r{}_r - T^\theta{}_\theta \right) + \Gamma^\phi{}_{\phi r} \left( T^r{}_r - T^\phi{}_\phi \right) = 0
The ##\Gamma##s are the Christoffel symbols, which can also be easily computed with Maxima, and filling in the results along with the stress-energy tensor components gives
\frac{dp}{dr} + \left( \rho + p \right) \frac{B'}{2B} + \frac{2}{r} \left( p - s \right) = 0
This, when it is rearranged to put everything but ##dp / dr## on the RHS, is a well-known equation called the Tolman-Oppenheimer-Volkoff equation (in a slightly more general form--the original TOV equation assumed isotropic pressure, so the ##p - s## term was zero). Combined with the first two of the EFE equations above, it gives a complete solution for the general static, spherically symmetric case.
That is so cool. Thank you very much for laying all of that out for me. Looks like I have a new project to begin working on. Awesome :smile:
Well, from the first three sets you give, I have so far managed to come up with the relation
p' + (\rho + p) \frac{B'} {2 B} + (p - s) \frac{D'} {D} = 0
or
\frac{dp} {dr} + (\rho + p) \frac{B'} {2 B} + (\frac{2} {r} + \frac{C'} {C}) (p - s) = 0
so it looks like the coordinate choice C = 1 has already been made for what you have at the end of your post. I also found the relation
A = \frac{[(4 s + \rho - 3 p) (D' / D) - 4 p'] (D' / D)} {4 (\rho + p) (1 / (8 \pi D) - p)}
so if we make a coordinate choice for D and we know the pressures, we could potentially find A. The problem here is that for a vacuum solution, the pressures all becomes zero and divide by each other so we would end up with A = 0 / 0 which could be anything, and I want to directly see the result for a vacuum, so I'll keep working on it.
For an isotropic pressure where p = s, we would have
A = \frac{(D' / D)^2 / 4 - p' (D' / D)/ (\rho + p)} {1 / (8 \pi D) - p}
and since all three pressures are zero for a vacuum solution, that could be considered isotropic, which perhaps brings us a little closer.
No; that equation does not assume any coordinate choice other than the general form of the metric we have been using; i.e., it does not assume any specific form for A, B, C, or D.
I just double checked by placing each of the values you give for ##\rho##, p, s, and finding for p' into the last relation in the post directly and I still get
p' + (\rho + p) \frac{B'} {2 B} + \frac{2} {r} (p - s) = -\frac{C'} {C} (p - s)
so if that last relation really does equal zero without a coordinate choice, then the pressure must always be isotropic, which would be an interesting discovery.
I don't understand; where is the ##C' / C## term coming from on the RHS? The LHS is just the last equation I wrote down in post #4, with nothing substituted at all; the RHS should be zero.
Perhaps I should amplify somewhat on what is necessary for a solution, given the equations I posted in post #4. These are three equations, so if we consider the functions ##\rho##, ##p##, and ##s## to be known functions of ##r##, we can use those three equations to solve for ##A##, ##B##, and ##C## (or ##D##). But that's not really what we want, because in general (and in fact in the usual case), we do not know ##\rho##, ##p##, or ##s## in advance; they also have to be solved for. So we need more equations, and we may also need more assumptions/choices to narrow things down.
One obvious equation we can add is an equation of state for the matter: this is an equation relating ##p## and ##\rho##. (In principle, it could be two equations, relating both ##p## and ##s## to ##\rho##, but in every treatment I've seen, the pressure is assumed to be isotropic, which amounts to eliminating one variable, ##s##, by assumption, and adding one equation to the set of equations to be solved.) It is less obvious, but can be shown (IIRC), that we can also always eliminate ##A## or ##C## by a proper choice of coordinates--in other words, these two functions are not actually independent. (In the vacuum case, this is obvious because the ##G^t{}_t## equation only contains ##A## and ##C##; it doesn't contain ##B##. But, IIRC, it turns out to be possible even in the general static, spherically symmetric case.)
The above leaves four equations (three EFE, or two EFE and the covariant divergence equation, plus the equation of state) and four unknowns (##A## or ##C##, ##B##, ##\rho##, and ##p##), so it should in principle be solvable. But, as I think I said before, in the general case no closed-form solution is known; the equations have to be integrated numerically. The only case for which I know there is a closed-form solution is the (highly unrealistic) case of constant density (and isotropic pressure).
Well, here's something interesting so far. For the non-vacuum solution, we could use still use the same form of the functions in the RHS of the components of the Ricci tensor and just consider that the LHS of those components is now non-zero, while still denoting them ##R_{00}##, ##R_{11}##, and ##R_{22}##. We find that the relations to the pressures in the non-vacuum solution then become simply
2 R_{00} = (8 \pi) (\rho + p + 2 s) B \text{ giving } B = \frac {2 R_{00}} {(8 \pi) (\rho + p + 2 s)}
2 R_{11} = (8 \pi) (\rho + p - 2 s) A \text { giving } A = \frac {2 R_{11}} {(8 \pi) (\rho + p - 2 s)}
2 R_{22} = (8 \pi) (\rho - p) D \text { giving } D = \frac {2 R_{22}} {(8 \pi) (\rho - p)}
Placing these values for the functions into the metric now gives us
c^2 d\tau^2 = c^2 \frac {2 R_{00}} {(8 \pi) (\rho + p + 2 s)} dt^2 - \frac {2 R_{11}} {(8 \pi) (\rho + p - 2 s)} dr^2 - \frac {2 R_{22}} {(8 \pi) (\rho - p)} d\Omega^2
Nonzero, but not the same as the RHS of the Einstein Field Equation components--i.e., not the simple expressions ##8 \pi \rho##, ##8 \pi p##, and ##8 \pi s##. That's why I wrote down the Einstein tensor components for the non-vacuum case. So I don't see how you can arrive at the equations you wrote here.
Perhaps it would help for visualization purposes if I lay these out similar to the way I have been using them. If we convert all of the C's to D's, it reduces the number of terms considerably as many of them cancel and the r's fall out completely. So we would have
C = \frac{D}{r^2}
C' = \frac{D'}{r^2} - \frac{2 D}{r^3}
C" = \frac{D"}{r^2} - \frac{4 D'}{r^3} + \frac{6 D}{r^4}
Plugging those directly into each of the components of the Ricci tensor and EFE's and cancelling out terms, we gain
\frac{4 A}{B} R_{00} = \frac{B'^2}{B^2} + \frac{A' B'}{AB} - \frac{2 B"}{B} - \frac{2 B' D'}{B D}
4 R_{11} = \frac{2 B"}{B} - \frac{B'^2}{B^2} - \frac{A' B'}{A B} + \frac{4 D"}{D} - \frac{2 A' D'}{A D} - \frac{2 D'^2}{D^2}
\frac{4 A}{D} R_{22} = \frac{B' D'}{B D} + \frac{2 D"}{D} - \frac{A' D'}{A D} - \frac{4 A}{D}
4 A (8 \pi \rho) = \frac{4 D"}{D} - \frac{D'^2}{D^2} - \frac{2 A' D'}{A D} - \frac{4 A}{D}
4 A (8 \pi p) = - \frac{D'^2}{D^2} - \frac{2 B' D'}{B D} + \frac{4 A}{D}
4 A (8 \pi s) = - \frac{2 D"}{D} + \frac{D'^2}{D^2} - \frac{B' D'}{B D} + \frac{A' D'}{A D} - \frac{2 B"}{B} + \frac{B'^2}{B^2} + \frac{A' B'}{A B}
Now we can see the relationships between them much more easily. For instance, if we subtract the terms on the RHS of the ##p## row from the terms on the RHS of the ##\rho## row, we gain twice the same values on the RHS of the ##R_{22}## row, and so forth.
None of these look right, because, once again, you are using the Ricci tensor components instead of the Einstein tensor components. For the non-vacuum case, you can't use the Ricci tensor components, because they are not equal to ##8 \pi \rho##, ##8 \pi p##, or ##8 \pi s##; the Einstein tensor components are equal to those quantities. You can only get away with using the Ricci tensor components in the vacuum case.
I thought you might say something like that. I'm just saying that it's interesting that the way the functions are laid out in the RHS of the components of the Ricci tensor, although the results on the LHS would now be non-zero for the non-vacuum case, they work out with those simple relations I gave as compared to the way the same functions are laid out in the RHS of the EFE's. I'm curious, though, as to how the components of the Ricci tensor would be laid out for the non-vacuum case. Is it still applicable at all?
Are you saying here that there would be more factors than what you have given for those equations, or a bunch of "partial" factors that when put together work out to exactly the same thing as what you gave? If there are extra factors than what you already gave in the equations, then those extra factors must sum to zero, and that would tell us a lot, so would be very significant, or even with completely different factors in the equations that amount to the same thing, just as long as they don't reduce to precisely the same factors that you already gave.
The components of the Ricci tensor are the same; the problem is that you don't know what to set them equal to. In the vacuum case, you can set them equal to zero because the Ricci tensor must be zero if the Einstein tensor is zero (which it is in vacuum by the EFE). But if the Einstein tensor is not zero, there is no general formula that tells you what the Ricci tensor components are equal to; the only formula we have is the EFE, which is an equation in the Einstein tensor components, not the Ricci tensor components.
Yes.
No, they don't, because those relations have ##\rho##, ##p##, and ##s## in them, and you don't have any equations relating the Ricci tensor components to ##\rho##, ##p##, and ##s##. You only have equations (the EFE components) relating the Einstein tensor components to ##\rho##, ##p##, and ##s##.
Oh, okay good. Then the equations I gave still apply, but they don't tell us anything new, right, just a curiosity.
Yes.
Oh wow. Then those are a must have. Those extra factors would be of utmost significance.
No, they don't, because those relations have ρ, p, and s in them, and you don't have any equations relating the Ricci tensor components to ρ, p, and s. You only have equations (the EFE components) relating the Einstein tensor components to ρ, p, and s.
They do once we relate them to the same functions involved in each of the components of the Ricci tensor using the EFE's. For instance, we can see from the EFE's that
2A(8 \pi) (\rho - p) = \frac{B' D'}{B D} + \frac{2 D"}{D} - \frac{A' D'}{A D} - \frac{4 A}{D}
and that is identical to how the functions are laid out for ##(4A / D) R_{22}##, so that is how the pressures are related for the ##R_{22}## component of the Ricci tensor (along with the left over function (4A / D) tagged to it), but I agree that doesn't tell us anything new if that is what you are saying since we had to use the pressures according to the EFE's to find it in the first place, so we might as well just use the EFE's altogether. The Ricci tensor is no longer required as it doesn't tell us anything at all about the pressures as you said when using it alone, nor does it add anything to what can already be gained from the EFE's alone.
The equations describing the components of the Ricci tensor are still the same, yes. But anything you derived by setting those components equal to zero no longer applies if the spacetime is not vacuum. As far as I can tell, that's everything you've done with the Ricci tensor components except write them down.
No, they're not. They don't change the physics at all; they just clutter up the equations to no purpose. The EFE component equations I gave you are the simplest ones possible for the metric we are discussing.
They wouldn't change the physics, right, which means that those extra factors must sum up to zero. It would give me a relation between the functions, then, extra equations between the functions themselves that equal zero, which I could then use to solve much more easily for the metric in terms of the pressures involved and may even give some direct relation between the pressures themselves. In any case it would add more information. Could you please work those out for me?
They're factors, not terms. They multiply each side of the equation, but don't change any physics; they don't contain any additional information.
Oh, that's too bad. Well, then I guess I'll just have to keep diving into those equations you generously supplied until I can come up with something worth while. Thanks again for those by the way :smile:
Well I'm still not coming up with anything that looks very useful yet, still requiring more information, so I may need to start setting conditions that must be met for the spacetime we are solving for or for the pressures we are considering in order to come up with a full solution to the metric. There are a couple of such conditions I have in mind, but I have a couple of questions in the meantime. How would the constant of motion for angular momentum ##L## work out in terms of these functions in the non-vacuum case? Would the precession of Mercury and gravitational lensing and so forth still have all of the observed values for all possible solutions of the non-vacuum metric?
Once again, did you read my post #10? I discuss there what is needed, in addition to the EFE components, to obtain a full solution. The EFE alone is not enough, since it gives you only three equations (three EFE components, or two plus the covariant divergence equation) for, on the face of it, six unknowns (##A##, ##B##, ##C## or ##D##, ##\rho##, ##p##, and ##s##).
If you want to start with the simplest possible case (and the only one for which there is a known closed-form solution), I suggest assuming that the density ##\rho## is constant in the non-vacuum region, which can be assumed to extend from the center at ##r = 0## out to some finite radial coordinate ##R## that describes the surface of a gravitating object like a planet or star, and that the pressure is isotropic so ##p = s##. These assumptions are obviously not valid for all solutions, but they will give you at start at a case that, as I said, has a known closed-form solution, so you can see how the mechanics go before tackling more complicated cases.
Obviously the non-vacuum metric is not going to have the same solutions for the trajectories of test objects as the vacuum metric. Objects do not behave the same in the interior of a gravitating body (such as the Earth) as they do in the vacuum region outside it.
Yes of course I read it. I was trying to see what might be found without making any assumptions first however. Still am, I'm stubborn lol. I found a few simple relationships, but nothing yet that could be reduced much further to anything meaningful.
Okay, sounds good for a start. I'll go ahead and work on that.
I hadn't realized that you were suggesting applying these equations to the interior of a body. I was still thinking about it exterior to the body as in the vacuum case, but for the non-vacuum case we would be adding some type of dust cloud that extends indefinitely, or CMB pressure, or something to do with the cosmological constant perhaps or some such. I presume that we can still apply it in this manner exterior to the body as well as we could interior, but interior I can't work out constants for orbits and such using the low Newtonian limit. All I could say so far that I can think of is that the constant for the state of motion for energy E would still apply.
For the interior of a body then, I have a few more questions. There are no terms in the equations for the radius of the body R. Is that because the equations are found in such a way that the R factor drops out? If we were to place a particle at R + dr, considering the outside of the body to be vacuum, then the equations for a vacuum would apply for that particle, right? And since that would be the same as a point mass at the center in the vacuum case, then only the total mass/energy below r matters, regardless of the radius of the body as long as r>R, as with Newton, correct? So the difference between the vacuum and the non-vacuum case is that if we were to place the particle within the body whereas r<R, then we must also consider the contribution of the energy density from r to R, is that right? In Newton the contribution from r to R would be zero, but in GR that would add to the potential which would also affect the time dilation at r and so forth, right?
Of course they do. That's what "non-vacuum", i.e., having the RHS of the EFE nonzero, means--it means you are in the interior of a body containing matter. As long as the body is static and spherically symmetric, the general form of the metric we have been using applies just fine. But of course the relationships between the metric coefficients won't be the same as for the vacuum case (e.g., in the vacuum region outside the body).
"Exterior" means vacuum--no matter is present. The EFE is a local equation--the stress-energy tensor on the RHS describes the matter and energy present at the particular event in spacetime where the equation is evaluated.
As long as the spacetime is static, yes, there will be a constant of the motion corresponding to the timelike Killing vector field, which is usually called "energy at infinity". But it is only a constant of the motion for geodesic motion.
That's because R is either something you specify in order to obtain the full solution, or something you get out of the solution once you've specified other things. For example, in the constant density case, you could specify the radius of the body, and then integrate the equation for ##dp / dr## inward until you reached ##r = 0## to obtain the pressure at the center; or you could specify the pressure at the center of the body, and then integrate the equation for ##dp / dr## outward until you reached a radial coordinate where ##p = 0##; that radial coordinate is then the radius R of the body.
At that event, yes. But if the particle were at rest, it would fall inward and soon reach the non-vacuum region.
Yes.
That's one difference, but not the only one. The energy density is not the only thing that affects gravity; pressure affects it too.
Yes, but again, that's not the only difference. See above. If you work out the constant density case, you will see a lot of these things illustrated.
