Projective Representations: a simple example
12 replies · 3K views
rocdoc
Could anyone help with providing a simple example of a projective representation of a small finite group ( order of group not greater than six )?
My understanding is that, if the group has N elements, then I should see N matrices in the projective representation.
I would prefer the example to not involve a direct prduct group.
I have used nice simple groups, like C2v, in chemistry, this group has four elements.
What do you mean by a projective representation? A (surjective) projection ##G \longrightarrow GL(V)## or a projective resolution of ##G## or ##GL(V)##?
Hopefully the following helps with your question.
If the group is denoted by G and
$$g_1~ and ~g_2 $$are in G then we have, a projective representation of G if
$$M(g_1)M(g_2)=M(g_1g_2)e^{i\theta(g_1,g_2)}$$
With M meaning matrix.
In chemistry, the projective representations raise their head in the form of so called "double groups". There, the projective factors are avoided by introducing another group element "R". Also the permutation groups S_n have projective representations for S_n when n>=4.
The smallest example which I have found is
\mathbb{Z}_2\, , \,\mathbb{Z}_3\; , \; \mathbb{Z}_2 \rtimes \mathbb{Z}_3 \longrightarrow PSL(2,\mathbb{F}_2)=SL(2,\mathbb{F}_2) = \mathcal{Sym}(3) = D_3 = \mathbb{Z}_2 \rtimes \mathbb{Z}_3
With less finiteness conditions on the group it might be worth mentioning
\mathbb{S}^1 \cong SO(2,\mathbb{R}) \cong U(1,\mathbb{C}) \cong \mathbb{P}(1,\mathbb{R}) \text{ (unit circle) } \\ \text{ and } \\ \mathbb{S}^2 \cong SO(3,\mathbb{R})/SO(2,\mathbb{R}) \cong \mathbb{P}(1,\mathbb{C}) \text{ (Riemann sphere) }
and finite subgroups (reflections, rotations) of the unit circle or the 2-sphere will provide examples.
An interesting example (https://dl.acm.org/citation.cfm?id=676246) of a projective representation can be found for the Lie algebra ##\mathfrak{g}= \mathfrak{sl}(2,\mathbb{F})## with ##\mathbb{F}\in \{\mathbb{R},\mathbb{C}\}## but only because I don't remember the characteristic ##2## case and the centers need more care if other fields are involved. However, I assume that finite fields would work as well.
If we define the group ##\Gamma^°(\mathfrak{g})## of all ##\phi^* \otimes \psi^* \otimes \chi \in GL(\mathfrak{g}^*\otimes \mathfrak{g}^* \otimes \mathfrak{g})## such that ##[X,Y]= \chi([\phi(X),\psi(Y)])## for all ##X,Y \in \mathfrak{g}## then
\Gamma^°(\mathfrak{g}) \cong PSL(2,\mathbb{F})
which means the isometries of the Lie multiplication in ##\mathfrak{sl}(2,\mathbb{F})## have such a representation.
It looks like the Klein four-group, V4 has a projective representation.
The group multiplication table of V4 can be given as
$$\begin{array}{|c|c|c|c|c|}
\hline & e & a & b & c \\
\hline e & e & a & b & c \\
\hline a & a & e & c & b \\
\hline b & b & c & e & a \\
\hline c & c & b & a & e \\
\hline
\end{array} $$
If we have four matrices M(e),M(a),M(b),M(c) representing our group elements e,a,b,c, respectively.Then they form a matrix representation of our group if the "matrix multiplication table" has the same structure as the group multiplication table. I.E if we have
\hline & M\left( e \right) & M\left( a \right) & M\left( b \right) & M\left( c \right) \\
\hline M\left( e \right) & M\left( e \right) & M\left( a \right) & M\left( b \right) & M\left( c \right) \\
\hline M\left( a \right) & M\left( a \right) & M\left( e \right) & M\left( c \right) & M\left( b \right) \\
\hline M\left( b \right) & M\left( b \right) & M\left( c \right) & M\left( e \right) & M\left( a \right) \\
\hline M\left( c \right) & M\left( c \right) & M\left( b \right) & M\left( a \right) & M\left( e \right) \\ \hline \end{array}
Where the matrix in a cell of the table body, is formed by multiplying on the left, the matrix shown at the top of a particular column, by the matrix shown in the leftmost column for a particular row, in the natural obvious way.
If we use the following matrices
$$M(e)=\begin{bmatrix}1 & 0 \\0 & 1 \end{bmatrix},M(a)=\begin{bmatrix}0 & -1 \\1 & 0 \end{bmatrix},M(b)=\begin{bmatrix}1 & 0 \\0 & -1 \end{bmatrix},M(c)=\begin{bmatrix}0 & 1 \\1 & 0 \end{bmatrix}$$
we find a matrix multiplication table as below
\hline M\left( a \right) & M\left( a \right) & -M\left( e \right) & M\left( c \right) & - M\left( b \right) \\
\hline M\left( b \right) & M\left( b \right) & - M\left( c \right) & M\left( e \right) & -M\left( a \right) \\
This shows that the matrices we are now using form a representation up to a phase, or a projective representation.
Been thinking, just a little, not a lot. There seem to be much simpler examples.
