Proof about continuous function related to balls and sets
12 replies · 3K views · last reply
Hernaner28
Let [tex]\displaystyle f:{{\mathbb{R}}^{n}}\to \mathbb{R}[/tex] a continuous function. Proove that:
If [tex]\displaystyle f\left( p \right)>0[/tex] then there's a ball [tex]\displaystyle {{B}_{p}}[/tex] centered at p such that [tex]\displaystyle \forall x\in {{B}_{p}}[/tex] we have [tex]\displaystyle f\left( x \right)>0[/tex].
f is continuous, that is:
[tex]\displaystyle \forall \varepsilon >0[/tex] [tex]\displaystyle \exists \delta >0[/tex] such that [tex]\displaystyle f\left( B\left( p,\delta \right) \right)\subset B\left( f\left( p \right),\varepsilon \right)[/tex].
Let f(p)>0, then I cannot conclude anthing with the above hypothesis. What's missing?
Thank you!
Let's talk for a moment about a continuous f(x) on the real line. If f(p) > 0 do you see how to find an interval about p where f(x) > 0? What happens if ##\epsilon = \frac {f(p)}{2}##?
I don't understand why you ask that and why you say that at the end. Is there seomthing wrong with my attempt?
Thank you!
He is making a specific choice for [itex]\epsilon[/itex]. While there are many possible, f(p)/2 is one choice that will help here. Do you see why?
Thank you!
Because I am trying to help you see how to work your problem by working a simpler one. How about addressing my questions? You might learn something in the process.
Hmm.. alright. Answering your question I honestly don't remember exactly how to find an interval about p where f(x) > 0. Could you please remind me?
Thank you both!
Thank you both!
If ##\epsilon = \frac {f(p)}{2}##, write out carefully what the ##\delta,\epsilon## definition of continuity of ##f## at ##p## tells you.
Yes. It would be:
[tex]\displaystyle \forall \varepsilon >0[/tex] [tex]\displaystyle \exists \delta >0[/tex] such that if: [tex]\displaystyle |x-p|<\delta[/tex] then [tex]\displaystyle |f\left( x \right)-f\left( p \right)|<\frac{f\left( p \right)}{2}[/tex].
But what is this for? Just setting [tex]\displaystyle \varepsilon =\frac{f\left( p \right)}{2}[/tex] it's not enough to find an interval about p such that f(x)>0. It also depends on delta... doesn't it?
Thank you
Ahhh I see it now!. If you choose that epsilon you get forced to choose a delta such that the interval about p of radious delta has positive image. Is it right?
Hernaner28 said:
Yes. It would be:
In particular for ##\epsilon = \frac{f(p)}{2}##
So you have a ##\delta## that works for this value of ##\epsilon##. And doesn't ##|x-p|<\delta## describe an interval about ##p## that goes from ##p-\delta## to ##p+\delta##?
What does that last inequality tell you about ##f(x)##? Unscramble it without the absolute value signs.
Yeah, now I get it. It implies that:
[tex]\displaystyle \frac{f\left( p \right)}{2}<f\left( x \right)<\frac{3}{2}f\left( p \right)[/tex]
That is: f(x)>0 . So the interval about p exists and it's the one of radious delta for that epsilon. Now it's almost the same but for balls, isn't it?
Thank you very much!
Edit. I think the definition of continuity I used in my attempt is not useful in this demonstration. I think I should use the equivalent definition with distances, shouln't I?
Yes, it's almost the same proof. It is frequently a good idea, when trying to prove something for ##R^n## to make sure you understand it first for ##R^1## or ##R^2##.
You're welcome.
Yeah, I think the problem was that we were given three equivalent definitions and in my attempt I used the definition of continuityn (for several variables) involving balls but I think in this case I should have used the definition involving distances or norm, those are closer to the one for one variable.
