Proving n2 < n! for n > 3: Simplifying the Induction Step
  • Thread starter Thread starter murshid_islam
    Induction Proof
The discussion focuses on proving the inequality n^2 < n! for n > 3 using mathematical induction. The base case for n = 4 is established as true since 4^2 < 4!. The inductive step involves assuming the inequality holds for n = k and proving it for n = k + 1, which participants agree is somewhat complex but valid. Suggestions for simplification include recognizing that proving k + 1 < k^2 is easier due to k(k - 1) > 1 for k > 3. Overall, while the proof may feel forced, it is acknowledged as clear and well-reasoned.
murshid_islam
i have to prove by induction that n2 < n! for n > 3
this is what i have done:
the base case (n = 4) is obviously true since 42 < 4!
now, assume that it is true for n = k, i.e., k2 < k!
now i have to prove it for n = k+1
since k > 3,
1 < k-1
1(k+1) < (k-1)(k+1)
k+1 < k2 - 1 < k2 < k!
k+1 < k!
(k+1)(k+1) < (k+1)k!
(k+1)2 < (k+1)!
what i have done seems ok to me. but is there any simpler way to do the induction step? what i have done seems a bit "forced" (if you know what i mean).
thanks in advance.
Mathematics news on Phys.org
since k > 3,
1 < k-1
1(k+1) < (k-1)(k+1)
k+1 < k!
(k+1)2 < (k+1)!
thanks in advance.
The steps you take seem correct. A bit simpler way is to think of what you want to prove: (k+1)2<(k+1)! and by using equivalent relations to simplify it, like this for example:
(k+1)2<(k+1)!<=>
(k+1)(k+1)<k! (k+1)<=> *note k+1>0*
k+1<k!
We know that k2<k! so we just have to prove that k+1<k2, which is easy because k(k-1)>1 for any k>3
I'm not a big fan of this particular inductive proof, since I've never found a short argument that didn't require me to manipulate both sides of the inequality like that. I've seen a similar proof on www.inductiveproofs.com that is 2^n < n! -- maybe that one will provide some inspiration.
since k > 3,
1 < k-1
1(k+1) < (k-1)(k+1)
k+1 < k!
(k+1)2 < (k+1)!
thanks in advance.
Thereis no simpleway of doing this . For all mathematcialproof by inductionyou must assume p(k) is true and then prove p(K+1) is true for all n =1,2... which you haveseem tobe done any way
since k > 3,
1 < k-1
1(k+1) < (k-1)(k+1)
k+1 < k!
(k+1)2 < (k+1)!
thanks in advance.
i know exactly what you mean. the trouble is, for n < 4, the theorem simply isn't true:
12 = 1! = 1
22 > 2! = 2
32 > 3! = 6
and it's not like for n = 3, we have equality, or that 32 is "just barely" more than 3!, the break-even point is somewhere between 3 and 4 (if you were using the gamma function, for example). so when we get to the part where we use n > 3:
1 < k-1
it's not "elegant", we prove something a little stronger than we need (after all, k = 3 would make that statement true, but then our "base case" fails).
this often happens with inequalities, the bounding term is often something that is more than "just barely greater than".
i wouldn't worry over-much about this, your proof is clear, clean, and well-reasoned. there's bigger molehills to make into mountains, if you're into that sort of thing.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
