Is the proof of the KRK endgame theorem rigorous and original?
  • Context: Undergrad
  • Thread starter Thread starter HrvojeDjurdjevic
    Chess Proof Theorem
The discussion centers on the rigor and originality of a proof for the KRK endgame theorem, which asserts that white can always win in this endgame scenario, barring specific exceptions. Participants explore the proof's construction, comparing it to existing literature and computer-aided methods, while also considering the mathematical and strategic aspects of chess endgames.
  • One participant presents a detailed proof of the KRK endgame theorem, outlining several lemmas and strategies for achieving checkmate.
  • Another participant argues that the proof lacks originality, suggesting that the strategy described is well-known among chess players.
  • A different participant questions whether similar proofs exist for other endgame scenarios, such as KBNK, and expresses uncertainty about the complexity involved in those proofs.
  • Concerns are raised about the mathematical rigor of the proof, with one participant asserting that it does not contain formal mathematical elements, contrasting it with more rigorous mathematical approaches to chess problems.
  • Some participants highlight the distinction between traditional chess strategies and the mathematical framing of these strategies, suggesting that the connection between chess and mathematics is not adequately represented in the proof.
Participants express differing views on the originality and rigor of the proof. While some acknowledge the proof's validity as a demonstration of strategy, others contest its originality and mathematical depth. The discussion remains unresolved regarding the proof's standing in relation to existing literature and its mathematical formulation.
Participants note that the proof relies on established chess strategies and may not fully engage with formal mathematical methods. There is also a mention of the potential for computer-aided proofs, which may differ in approach from the presented pen-and-paper proof.
HrvojeDjurdjevic
TL;DR
Series of articles authored by Maliković, Janičić, Marić and Čubrilo demonstrate computer-aided proofs of KRK theorem, here I present pen and paper one
The articles:
https://lmcs.episciences.org/5328/pdf
http://argo.matf.bg.ac.rs/publications/2013/2013-icga-krk-sat.pdf
http://archive.ceciis.foi.hr/app/public/conferences/1/papers2012/dkb3.pdf
KRK endgame is a win for white regardless of starting position, with the trivial drawing exception in case when black moves first and is able to capture the rook, or is stalemated in the corner.
Proving that requires describing at least one winning strategy for white, and proving its correctness, either by computer aided method or by pen and paper non-computer-aided method.
Auxiliary Definition 1: two kings stand in opposition if they are on the same line two squares away.
Corollary 1: two kings in opposition prevent each other to move to three squares adjacent to both of them, ie to move to the line that separates them, and is perpendicular to the line they both stand on. Proof: trivially follows from Definition 1 and from the game rules.
Corollary 2: when king is not placed at the edge of the board, and is not constrained by other pieces, it has access to three lines parallel to the same edge, ie to three ranks and to three files. Proof: trivally follows from the game rules.
Obviously, these two are not corollaries of the main theorem, but of the game rules, they are also lemmas to main theorem, so I could have named them also that way.
Lemma 1: in KRK endgame checkmate is possible if and only if BK is at the edge of the board. Proof:
BK is checkmated if WK stands in opposition on the line perpendicular to the edge at which both BK and WR stand, with d(BK,WR)>1, if BK is in the corner, WK can also stand one square away from the previously described opposition square, two lines away from the edge at which both BK and WR stand, with Chebyshev d(WK,BK)=2.
In both cases WK denies BK access to penultimate line parallel to the edge BK stands on, in case of opposition according to Corrolary 1, and in the other case corner placement helps due to the fact that the third square not guarded by WK does not exist, and WR covers the edge. No other checkmate position is possible, because there are no other pieces that could prevent BK from accessing the third line BK would have access to, according to Corollary 2, had BK not been placed at the edge, and this proves Lemma 1.
Now, in order to prove the main theorem, one has to prove two more lemmas:
Lemma 2: in KRK endgame it is always possible to force BK to one edge
Lemma 3: in KRK endgame, if BK is constrained to one edge by WR standing on the penultimate line which is parallel to that edge and separates two kings, it is always possible to force position in which it is white to move and deliver checkmate, by achieving position described in Lemma 1.
Proof of Lemma 3:
In order to prepare that mate in 1 position, white will make three kinds of moves:
1.) decreasing Manhattan d(WK,BK), approaching with king without ever stepping onto penultimate line or into opposition
2.) shifting rook from one edge to another staying safe on the same penultimate line when BK threatens its capture
3.) waiting move with rook when 1.) is not possible and 2.) is not necessary, this is any move on penultimate line which does not change the ordering of pieces and keeps WR safe from capturing
It is obvious that applying 2.) white can always obtain tempo to approach with the king to a line adjacent to that which rook holds, two lines away from the edge where BK stands, from any other line further away, and to transpose to a position in which WK stands between BK and WR in terms of lines perpendicular to the edge where BK stands, although WR stands all the time between WK and BK in terms of lines parallel to that edge.
From that position, black has two choices moving king along the edge, either to increase or decrease Manhattan d(WK,BK). If it tries to increase it, white will follow with 1.), but black is limited in this strategy with the corner, if it tries to decrease it, white will either follow with 1.) if possible, or 3.) otherwise, limit to this strategy is black stepping into opposition, when white follows with checkmate, which proves Lemma 3.
In the same vein, one can prove Lemma 2, and complete the theorem:
It is always possible to place safely from capturing WR on the line that separates two kings, that conclusion is rather trivial. From there white will apply exactly the same strategy as in Lemma 3, the only difference is that instead of checkmate it will result in squeezing BK one line nearer the edge, the limit of this strategy is BK ending at the edge.
Questions:
how rigorous
how original
is this proof?
Mathematics news on Phys.org
HrvojeDjurdjevic said:
Summary:: Series of articles authored by Maliković, Janičić, Marić and Čubrilo demonstrate computer-aided proofs of KRK theorem, here I present pen and paper one
The articles:
http://archive.ceciis.foi.hr/app/public/conferences/1/papers2012/dkb3.pdf.
I'm a little worried the point is being missed here. Constructing a winning KRK checkmate is not that interesting. I think the main point of those papers is the computer aided proof technique.
Questions:
how rigorous
how original
is this proof?
Definitely not original, you just described how to do something every chess player has known how to do for a thousand years. If your goal was to practice writing a proof though, it's fine.
So, can you do the same for KBNK?
Can I? No, because I haven't learned the pattern to get checkmate. The algorithm is known though, someone could write it out in detail and demonstrate the correctness of it. That one might be more suitable to a computer aiding the check though, since I think there are more choices you have to analyze?
There are more choices even with KRK which is far more basic than KBNK, because there is more than just this one strategy which I described and, you say, demonstrated fine proof of correctness. Maliković and others use Bratko’s strategy which is far less known and understood and which leads to a decomposition of main theorem into a different set of lemmas, corresponding to different stages of strategic plan, comparing to “mine”, which you say knows every chess player, and I agree with that. What they show is definitely somewhat different, not just because of usage of computer aided techniques, for which I have no idea how you came up with the idea that I think they are not their primary focus.
Besides that, even if the strategy I described is well known, that still does not mean the proof is not original, if nobody else so far presented it the way I did, and showed the real connection between math and chess. Because, so called mathematical chess problems are rather artifical link between the two areas, they are math problems that have very little to do with chess https://en.wikipedia.org/wiki/Mathematical_chess_problem, what I showed is a chess subject presented in mathematical way. And all that chess’n math organizations, I don’t know what they actually teach, that’s why I ask, but receive a wrong answer. Could you post a link to a page where already exists a similar proof? I couldn’t find it, otherwise, I wouldn’t bother to write it by myself and ask such things.
I hope to find there similar proofs for other endings ...
But your proof does not contain any mathematics, it is just a strategy written in a semi-formal language. An example of a mathematical solution to a chess problem is solving domination by queens using the properties of a Salem-Spencer set, or the methods shown in this paper on combinatorial game theory in chess endgames.
Chess endgames were analysed long before the internet, you would do better to look in a book such as How to Play Chess Endings in the set by Znosko-Borovsky or Max Euwe's A guide to chess endings.
I was giving them the benefit of the doubt. If their goal was really to prove that endgame has a checkmate solution then their paper seems pretty pointless to me.
Besides, it even says this in the first one
. One of our goals and contributions is modelling the chess rules and chess
endgames so that the correctness proofs can be made as automated, efficient and reliable as
possible.
Though to be honest, this feels like a pretty underwhelming paper anyway. If they had a really good method at the end they probably would have used it to solve something more interesting.
Office_Shredder said:
Though you be honest, this feels like a pretty underwhelming paper anyway.
Agreed. Here is my alternative abstract: "We use a black-box computer proof assistant to prove something that has already been proven demonstrating that (i) it is still true and (ii) we read the manual properly".
Their goal is not solutions, it is merely the verification of existing solutions using 'provably correct' proof assistants. For chess this is almost worthless because all endgames have already been exhaustively analysed using demonstrably correct chess engines.
For me a more interesting, and earlier (2005) result is Gonthier's proof of the four-colour theorem using the proof assistant Coq: this removes the reliance on bespoke code in previous proofs (noting that the original 1976 proof was flawed).
Yeah well, my proof was supposed to be a proof of correctness of that strategy, not the strategy itself. And that was supposed to prove the theorem (that claim that is a subject of proof, in our concrete case it says that KRK is a win for white), that was its final purpose. And what does that even mean “a proof does not contain any mathematics”? I thought it can only be the other way around: mathematics can contain certain theorems and their proofs, if they are rigorous enough to be acceptable, no? And what improvement would you suggest in order to upgrade it to a fully formal language, if I may ask? Shredder said it was fine, now you say it is only of semi quality.
OK, I can take it, my proof is not mathematics, because mathematics is only that what mathematicians consider as such. Following that logic, this is not a chess problem. No chess professional would consider its solution very relevant for their business, because they rarely deal with more than two queens of the same color, although it may be a fine mathematical problem.
So OK, I thought it was only a question of rigorosity, not of the actual content of the theory, perhaps I was wrong.
The other paper looks interesting though, I will take a look at it, thanks.
Still, I don’t see how the same theorem proven by using automated proof assistant or a constraint programming system would count as mathematics, and without it, it is not.
I did not say it was of 'semi quality', I said it was written in a semi-formal language.
Using the language of formal proof would definitely not be an improvement. For instance
is perfectly acceptable to anyone who understands chess, and it is reasonable to assume that anyone who is interested in this proof understands chess. However this is a long way away from the language of formal proof.
Well if your proof contained something like the following we might say there was some mathematics (specifically combinatorics) in there:
there are 64 x 63 x 62 = 249,984 possible placings of KRK on a chessboard, although we can reduce this by a factor of 8 for the two reflectional and two rotational symmetries. This leaves 31,248 placings but many of these are not possible starting positions
(note this is probably NOT the best way to calculate legal starting positions for this problem!)
But this wouldn't make it a better proof, there is nothing special about mathematics, it is just a big toolbox containing things that have (mostly!) already been proved which can often help.
No problem. You might be interested in this one on formal proof too: https://cmartinez.web.wesleyan.edu/documents/FP.pdf
I don't think anyone here thinks those papers are interesting new mathematics.
The author of the third paper
https://www.google.com/amp/s/www.researchgate.net/profile/Marko-Malikovic/amp
Is a professor of psychology? And they have a bizarre number of publications that prove correctness of KRK endgame using different tools. I'm not sure what their career is supposed to be, but it isn't in research mathematics
I haven't looked at the other authors.
  • · Replies 23 ·
