Proof using axioms for a field
4 replies · 8K views · last reply
msbell1
Hi, I am trying to work through Finite Dimensional Vector Spaces by Halmos, and I am having some difficulty with the first problem on page two (the specific problem is included below). The last class I took involving formal proofs was linear algebra about 8 years ago, and I am very rusty, but I am trying to regain some of those skills now. Here is the problem:
Prove that (-a)(-b)=ab (assuming that F is a field and that a, b, and c belong to F)
A reminder of the axioms:
addition is defined in the usual way, and it is commutative (a + b = b + a), associative (a + (b + c) = (a + b) + c), 0 is the unique additive identity such that a + 0 = a, and -a is the unique additive inverse such that a + -a = 0
multiplication is defined in the usual way:
it is commutative (ab = ba), associative (a(bc) = (ab)c), 1 is the unique additive identity such that a1 = a, and 1/a is the unique multiplicative inverse such that a(1/a) = 1.
In the previous part of this problem I was asked to prove that (-1)a = -a, so I will use that proposition to prove the next part. I start out by using that to write:
(-a)(-b)=(-1)a(-1)b
However, once I write this I am stuck--for the past day I have been thinking about this off and on and have not been able to make any progress, and I was wondering if anyone could suggest how I should proceed.
Thank you for the help!
Do you know what (-1)(-1) equals? If not could you prove it equals 1?
Thanks for the reply!
I forgot to include that multiplication is distributive with respect to addition:
a(b+c) = ab + ac (which I will use later)
Would it be ok to first rewrite (-1)a(-1)b as (-1)(-1)ab and then start working separately on the (-1)(-1) part?
like continuing the proof as
(-a)(-b) = (-1)(-1)ab
Then forgetting about a and b and working on (-1)(-1):
(1 + (-1))(-1) = 0 (1 + -1 = 0 (-1 is unique additive inverse of 1 such that 1 + -1 = 0) and I already had to prove that 0a = a0 = 0)
(-1)(1 + (-1)) = 0 (by commutativity of multiplication)
(-1)(1) + (-1)(-1) = 0 (multiplication is distributive w.r.t. addition)
-1 + (-1)(-1) = 0 (because 1 is multiplicative identity)
1 + -1 + (-1)(-1) = 1 + 0
(1 + -1) + (-1)(-1) = 1 + 0 (because addition is associative)
0 + (-1)(-1) = 1 + 0 (because 1 + -1 = 0)
(-1)(-1) + 0 = 1 + 0 (because addition is commutative)
(-1)(-1) = 1 + 0 (because a + 0 = a)
(-1)(-1) = 1 (because a + 0 = a)
Then plugging this result into
(-a)(-b) = 1ab
(-a)(-b) = ab
Is that an ok proof? How would a mathematician prove this? Thanks again for your reply.
yup looks good, so an outline would look like:
lemma 1: -a = (-1)a
lemma 2: (-1)(-1)=1
proof:
(-a)(-b) =(-1)a(-1)b
(-1)a(-1)b = (-1)(-1)ab
(-1)(-1)ab = 1ab
1ab = ab
