Prooving a statement with a Lemma
  • Thread starter Thread starter alexk307
The discussion revolves around proving a statement related to integers and their divisibility, specifically using a lemma that states if the product of two integers is 1, then each integer must equal 1. Participants are exploring the implications of this lemma in the context of integer division.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants express confusion about the lemma's validity and its implications for integers. There is a discussion about the meaning of one integer dividing another and the assumptions that need to be made regarding integers and their relationships. Some participants attempt to relate the lemma to their proof by exploring the implications of integer division.
The discussion is active, with participants questioning the lemma and its assumptions. Some have begun to articulate their reasoning regarding integer relationships, while others are clarifying definitions and exploring the implications of their assumptions. There appears to be a productive exchange of ideas, with some participants feeling they are making progress in understanding the proof.
Participants note the importance of distinguishing between integers and non-integers in their reasoning. There is an ongoing examination of the assumptions needed to apply the lemma correctly in the context of the problem.
alexk307
Using the lemma below, prove that if two integers divide each other, then they are equal
Lemma: If the product of two integers is 1, then the integers each equal 1.
Very lost here, I can format the proof but I don't know where to start it. Also, isn't the lemma false? If a*b = 1, then a and b equal 1. What about 3/4 * 4/3 = 1? or 2/3 * 3/2 = 1?
Ah, but you're forgetting the hypothesis of the lemma. What's the hypothesis? The hypothesis is assumed to be true so...
Once you understand the lemma, what does it mean for one integer to divide another integer?
3/4 and 4/3 aren't integers, nor are 2/3 and 3/2.
Oh man, that's embarrassing... Thanks
okay so,
I assumed that a and b are both integers and that a/b = 1.
Should I also assume that c*d=1 according to the lemma that if cd=1 then c and d are 1?
alexk307 said:
okay so,
Start with the hypothesis of what you're trying to prove. Using math terms, what does it mean if a divides b? b divides a?
Okay, so if a divides b, then a = bq, where q is the multiplier, also there is no remainder.
so I see that a = bq and b=aq
solving for q... q^2=1 and q=1
I don't know if I'm onto anything by saying q*q=1, and the lemma are related.
just got it I think. because q*q = 1, q must equal 1. Therefor a = bq and b = aq can be reduced to a=b and b=a.
Not quite. It's true that a = bq, where q is an integer. However, you cannot say b = aq. It could be a different integer, so the simple solution is to make b = ar, where r is an integer.
So now that you have the two equations:
a = bq
b = ar
What can we do?
oh okay so a=bq and b=ar solving for then rq=1.
So I had the right idea, but I can't say that they're both able to be divided by the same integer, but that rq=1
and then r and q both equal 1, so a=b and b=a.
You got it.
very helpful, thanks for the walkthrough!
