Properties of the Absolute Value
5 replies · 33K views · last reply
roam
Just wanted to say hi before I start my post! :smile:
As you may know there is a property of the absolute value that states; for [tex]a, b \in R[/tex];
[tex]|ab| = |a||b|[/tex]
Well, my friend asked me if I knew a proof for this... but I don't know...
How can we prove this statement/property? I know there is a proof for the triangle inequality but for this I really don't know but I'm curious.
I'd appreciate it if anyone could show me any kind of proof or send me some links etc. Thanks!
You prove that |ab|= |a||b| the same way you prove any such elementary statement: use the definitions.
The simplest definition of |x| (there are several equivalent definitions) is that |x|= x if x is positive or 0, -x if x is negative.
Now break it into "cases":
case 1: x and y are both positive: |x|= x and |y|= y. xy is also positive so |xy|= xy= |x||y|.
case 2: x is positive while y is negative: |x|= x and |y|= -y. xy is negative so |xy|= -xy= x(-y)= |x||y|.
case 3: x is negative while y is positive: |x|= -x and |y|= y. xy is negative so |xy|= -xy= (-x)y= |x||y|.
case 4: x and y are both negative: |x|= -x and |y|= -y. xy is positive so |xy|= xy= (-x)(-y)= |x||y|.
case 5: x= 0 and y is positive: |x|= 0 and |y|= y. xy= 0 so |xy|= 0= 0(y)= |x||y|.
case 6: x= 0 and y is negative: |x|= 0 and |y|= -y. xy= 0 so |xy|= 0= (0)(-y)= |x||y|.
case 7: x is positive and y is 0: |x|= x and |y|= 0. xy= 0 so |xy|= 0= x(0)= |x||y|.
case 8: x is negative and y is 0: |x|= -x and |y|= 0. xy= 0 so |xy|= 0 = (-x)(0)= |x||y|.
case 9: both x and y are 0: |x|= 0 and |y|= 0. xy= 0 so |xy|= 0= (0)(0)= |x||y|.
There are simpler ways to prove that but I thought this would be conceptually clearest.
First, we have to understand that the absolute value is a function defined by:
[tex]|x| = \begin{cases}<br /> x & \text{if } x\geq 0 \\<br /> -x & \text{if } x<0<br /> \end{cases}[/tex]
So,
[tex]|ab| = \begin{cases}<br /> ab & \text{if } ab\geq 0 \\<br /> -ab & \text{if } ab<0<br /> \end{cases}[/tex]
Now, let's see what |a||b| is:
[tex]|a||b| = \begin{cases}<br /> ab & \text{if } a\geq 0 \wedge b\geq0 \\<br /> (-a)(-b) & \text{if } a\leq 0 \wedge b\leq0 \\<br /> (-a)b & \text{if } a> 0 \wedge b<0 \\<br /> a(-b) & \text{if } a<0 \wedge b<0<br /> \end{cases} \Leftrightarrow[/tex]
[tex]|a||b| = \begin{cases}<br /> ab & \text{if } a\geq 0 \wedge b\geq0 \\<br /> ab & \text{if } a\leq 0 \wedge b\leq0 \\<br /> -ab & \text{if } a> 0 \wedge b<0 \\<br /> -ab & \text{if } a<0 \wedge b<0<br /> \end{cases} \Leftrightarrow[/tex]
Notice that you have ab if a and b have the same sign and that you use -ab otherwise.
Now, if a and b have the same sign, [tex]ab\geq0[/tex]. If they have opposite signs (and are different than zero), [tex]ab<0[/tex].
Using this,
[tex]|a||b| = \begin{cases}<br /> ab & \text{if } ab \geq 0 \\<br /> -ab & \text{if } ab<0<br /> \end{cases} = |ab|[/tex]
Quod erat demonstrandum :-p
let a = mcis(kpi) where m => 0, k is integer
and b = ncis(hpi) where n => 0, h integer
(clearly a,b are real)
|a||b|= mn
|ab|=|mcis(kpi)*ncis(hpi)| = |mncis[pi(k+h)]| = mn
as required
|a||b|= mn
as required
This would make more sense if you had said that "mcis(hpi)" is
[tex]m (cos(h\pi)+ i sin(h\pi))[/tex]
That is much more an "engineering notation" than mathematics.
If you really want to go to complex numbers, why not
if
[tex]x= r_xe^{i\theta_x}[/tex]
and
[tex]y= r_ye^{i\theta_y}[/tex], then
[tex]|xy|= |r_xe^{i\theta_x}r_ye^{i\theta_y}|= |(r_xr_y)e^{i(\theta_x+\theta_y)}|[/tex]
But for any [itex]z= re^{i\theta}[/itex], |z|= r, so
[tex]|xy|= r_x r_y= |x||y|[/tex]
[tex]\Huge |ab|=\sqrt{(ab)^2}=\sqrt{a^2b^2}=\sqrt{a^2}\sqrt{b^2}=|a||b|[/tex]
and
[tex]\large |a+b|=\sqrt{(a+b)^2}=\sqrt{a^2+2ab+b^2}\leq \sqrt{a^2+|2ab|+b^2}=\sqrt{(|a|+|b|)^2}=||a|+|b||[/tex]
where I utilize the following fact:
|2ab|=|2(ab)|=|2||ab|=2|a||b|
À bientôt
?;-D
