Prove a=b=2 given a+b = ab = a^b
  • Thread starter Thread starter Norway
    Proof
37 replies · 7K views · last reply
Norway
[tex]a+b = ab = a^b[/tex]
Prove that [tex]a=b=2[/tex]
Ok, I've tried this for more than an hour now, but can't figure out how to do it. I guess it could be done with Lambert's W-function (?) but this task is given on a much lower level. They haven't even learned how to prove that when x is a odd number, then x squared must be odd aswell. So this must be really simple, but still I can't figure anything out.
I've tried to take the equations and isolate a or b, and then insert it into one of the other functions, but I've gotten nowhere. I really hope someone could help me se the obvious here.
This is part of the proof:
I'm in a hurry continue later(=
[tex]a+b\equiv0(moda)[/tex]
[tex]b\equiv0(moda)[/tex]
Therefore,a divides b
[tex]a^{b}\equivab(modb)[/tex]
[tex]a^{b}\equiv0(modb)[/tex]
Therefore,b divides a
Concluding that [tex]a=\pmb[/tex]
Don't give complete answers. But your approach can't work anyways, because it doesn't say anything about non-integers.
I presume that you're supposed to have an idea inspired by the qualitative behavior of addition vs. multiplication vs. exponentiation...
At low level I would mean to substitute the values given for a and b and see if the relations are true :)
ehild
Hi Norway! :smile:
(try using the X2 tag just above the Reply box :wink:)
Here's a start …
the bit on the left gives you an ab - a - b … does that remind you of anything? :wink:
ehild
?? There were no "values given". The problem is to show that his is true for all numbers a and b.
To be hones - no, it doesn't. :(
First thing that comes to mind are those (a+b)2 rules, but I guess neither of them fits in here.
Then I think; "So a and b multiplied minus a and b is zero. That must mean that a+b=ab", and we're back to the start...
Sorry.
Try adding a constant to it, and then factoring it. :wink:
Geez, I still don't get it.
I'm trying to look at this task like I have no idea what a and b could be, I'm not doing anything wrong there, am I?
Ok, [tex]ab-a-b=0[/tex]. If we knew that a=b, then OK, but we don't. That's what we're going to prove. Right?
Or wait;
[tex]ab - a - b + 1 = 1 \ \Rightarrow \ (a-1)(b-1) = 1[/tex]
Was this what you had in mind?
Then what? If they had to be integers, then sure, but they don't. Any more hints would be greatly appreciated. :D
Norway said:
Or wait;
:biggrin: Woohoo! :biggrin:​
ok, now have a go at the bit on the right … ab = ab …
how can you get an (a - 1) or a (b - 1) out of that? :wink:
Hi everyone,
tiny-tim, I tried: ab=a^b
a-1=a^(b-1)-1 and since b-1=1/(a-1), then (a-1)(a^(1/(a-1))-1)=1...
but it's not a likeable equation,is it?
is there any other way?
Hi penguin007! :smile:
(please use the X2 tag just above the Reply box :wink:)
I managed to get as far as ab-2ba-2 = 1 …
not sure what to do then. :redface:​
Hurkyl said:
Don't give complete answers. But your approach can't work anyways, because it doesn't say anything about non-integers.I presume that you're supposed to have an idea inspired by the qualitative behavior of addition vs. multiplication vs. exponentiation...
Hi Hurkyl!
You are true I've neglected the non-integers. But if it is non-integers, i do not know how should i deal with my proof.
Hi!Norway can you specify if a and b are real numbers or solely integers?
Hi! The task was given exactly as I gave it to you. I would guess this means all numbers, but maybe it was integers. As I said, this was given on a relatively low level, to students who has never ever done any proofs before.
Thank you guys.
Norway, was it said that "Prove that a=b=2" with the same words? Or was it meant like that: prove that a=b=2 satisfies the equations above? A simple substitution of a=2 and b=2 into the equations is a complete proof then, the derivation of the solution is not necessary. If the question means "prove that a=b=2 is the unique solution", that is a nice problem for high level, as this thread illustrates it, but not for beginners in maths.
ehild
The expression you got seems to be interesting tiny-tim but I didn't manage to exploit it.
We can try to introduce the function f:=x->(x-1)*(x(1/(x-1))-1) and then by studying the variations of this function, we would show that the equation (x-1)*(x(1/(x-1))-1) =1 has a single solution (x=2, which would give us a=2); BUT:
1-I do not guarantee the study of f is easy;
2-this problem seems to be a more arithmetic one and therefore should be solved differently;
ehild
Well, it said "Given [tex]a+b=ab=a^b[/tex], prove: [tex]a=b=2[/tex]"
But yes, I do start to wonder. They can express themselves quite sloppy sometimes, especially on lower levels. I just saw a good try on this on a Norwegian forum of maths (that's why I posted this here, I saw this question, and was unable to help, even though I'm on a much higher course :blushing:).
[tex]ab = a^b[/tex]
[tex](ab)^b = \left(a^b\right)^b[/tex]
[tex]a^b b^b = a^{b \cdot b}[/tex]
[tex]b^b = a^b[/tex]
[tex]a = b[/tex]
[tex]a+b = ab[/tex]
[tex]2a = a \cdot a[/tex]
[tex]a = b = 2[/tex]
Obviously this turned out to be wrong, but I guess it was still a nice try.
They said they found a solution to this now, so I'm going to check out the link they gave and then check back here.
Okay, I just reviewed the other solution, and I can't see anything wrong with it. Maybe you guys can?
[tex]ab = a^b \ \Rightarrow \ b = a^{b-1}[/tex]
[tex]a+b = ab \ \Rightarrow \ b = 1 + \frac{b}{a} \ \Rightarrow \ b - 1 = \frac{b}{a}[/tex]
Therefore:
[tex]b = a^{b-1} = a^{\frac{b}{a}}[/tex]
[tex]b = a^{\frac{b}{a}} \ \Rightarrow \ b^a = a^b[/tex]
[tex]a \cdot \log{b} = b \cdot \log{a}[/tex]
[tex]\frac{\log{a}}{a} = \frac{\log{b}}{b}[/tex]
[tex]a = b[/tex]
Is this correct here? Why not?
[tex]a+b = a^2 \ \Rightarrow \ 2a = a \cdot a \ \Rightarrow \ a = b = 2 \; \; \; Q.E.D.[/tex]
[tex]a = b[/tex]
It's not. Because you believed too much in the guy who said it was strictly increasing. If you actually take a look at the graph, you'll see that a=b could mean a ton (infinite?) of possible (a,b) pairs.
Hi Norway! :smile:
That requires that logx/x be single-valued.
Unfortunately, it has a maximum value of 1/e at x = e (2.718…),
so loga/a = logb/b does not imply a = b. :redface:
EDIT: uhh? are you two different people (or countries)? :confused:​
Ha ha, no, I just replied to myself, because I asusmed the guy who posted this proof was telling he truth about it being strictly increasing, without even having looked at the function. Then I checked it out, and realized that it was wroong. Still a nice try, though.
Let me just ask you; is there anyone here who knows how to prove this at all?
Here's the sketch of the first elementary complete proof I've put together.
I hope you'll allow me to assume a is positive, so that we don't have any worries about whether ab is well-defined.
First solve ab=ab (e.g. with logarithms): this gives
a = bb-1​
Then a+b = ab gives
bb-1 + b = bb​
or equivalently
1 + b2-b = b​
Checking the three cases b <= 1, 1 <= b <= 2, and 2 <= b yields b=2 is the only solution.
Hi Hurkyl! :smile:
a = bb-1​
No, a = b1/(b-1).
My first ideas simplest implementation, unfortunately, uses calculus to get the identity I wanted, and works out like this:
Solving a + b = ab gives
a = b/(b-1)​
Our assumption of a > 0 implies b > 1.
Plugging into ab = ab gives
(b-1) log(b-1) = (b-2) log(b)​
If we set f(x) = (x-1) log(x-1) - (x-2) log(x), we see that the equation f'(x)=0 simplifies to
0 = 2/x + log (1 - 1/x)​
which has no solutions. Therefore f is monotone and has a unique zero on x>1: x=2.
NM I messed this one up too. I feel silly making two arithmetic errors in a row. Terrible ones even -- I shouldn't be allowed to do math today:redface:
tiny-tim said:
Hi Hurkyl! :smile:
No, a = b1/(b-1).
Oh bah.
Both a and b satisfy
[tex]x^{\frac{1}{x-1}} = \frac{x}{x-1}[/tex]
if that helps. You can also show that [itex]1<a<e[/itex].
a = b/(b-1)​
If we set f'(x) = (x-1) log(x-1) - (x-2) log(x), we see that the equation f'(x)=0 simplifies to
What's wrong with this one?
has solutions. Or, at least, it doesn't obviously not have solutions. Somehow I convinced myself this was positive + positive = zero.
I think I may have something. Correct me if I'm wrong:
ab=ab which implies a=[tex]\sqrt[b-1]{b}[/tex]
a+b=ab which implies a = b/(b-1)
Then b = bb-1/(b-1)b-1
From this we get: bb-2 = (b-1)b-1
Expanding gives: bb-2 =bb-1-b-1C1bb-2+...
And b-1C1 = b-1
From this we get: 0 = bb-1-(b-1+1)bb-2+... = bb-1-bb-1
Now, correct me if I'm wrong, but I think this implies that there are only two entries in the (b-1)th row in pascals triangle, so b-1=1 which implies b = 2.
From there: ab = ab implies 2a = a2 implies a = 2
Is this valid?
