Prove ( a + b + c )^2 <= 4( ab + bc + ca )
  • Thread starter Thread starter Bernie Hunt
13 replies · 22K views
Bernie Hunt
The Problem;
If a>0, b>0, c>0 and a + b > c, b + c > a, c + a > b then ( a + b + c )^2 <= 4( ab + bc + ca ).
Hints: Start with ( a + b + c )^2 and establish the inequality ( a + b + c )^2 <= 4( ab + bc + ca ). Us the inequality fact: if x < y then xy < y^2 if y > 0.
I haven’t make much progress. I’ve been trying;
( a + b + c )^2 = a^2 + b^2 + c^a + 2ab + 2bc + 2ca
But I haven’t been able to figure out a way to get the right side manipulated. I tried a couple of substitutions, but couldn’t justify a<b or such to be able to use the hint.
Can anyone give me a push in the right direction?
Thanks,
Bernie
I would start the question by expanding the RHS of the equation to:
a^2 + b^2 + c^2 + 2(ab + bc + ac)
Now, It is obvious that (a + b + c)^2 >= 2(ab + bc + ac)
Hence 2(a + b + c)^2 >= 4(ab + bc + ac)
Therefore we can assume that 4(ab + bc + ac) = 2(a + b + c)^2
And as (a + b + c)^2 <= 2(a + b + c)^2
Therefore (a + b + c)^2 <= 4(ab + bc + ac)
ACM,
Thanks for the quick reply. I think there is a flaw in your logic. The statements workout to;
2(a + b + c)^2 > (a + b + c)^2 > 2(ab + bc + ac)
2(a + b + c)^2 > 4(ab + bc + ac) > 2(ab + bc + ac)
Therefore 4(ab + bc + ac) > (a + b + c)^2
Which is saying that:
x > y
x > z
Therefore y > z
Which is not always true. It is true sometimes but not for all conditions.
Is there a way to prove that because a + b > c, b + c > a, c + a > b then the above logic is always true?
Bernie
No problem, Should have though that through.
Bernie Hunt said:
The Problem;
Thanks,
Bernie
Either a=b and you can use that fact, or either a<b, or b<a and wlog we may assume that a<b in this case. (or, they're either all equal, when it is trivially true, or we may assume a<b without loss of generality - the labels of a,b,c are obviously not important).
StatusX,
StatusX said:
Expand out the square and cancel like terms. Then use their clue.
Cancel out which like terms? Expanding out the square gives;
Which of these terms can be canceled?
Bernie
And then rewrite 2ab as ab+ab, etc. Also, I don't think equality ever holds, unless you meant a + b >= c, b + c >= a, c + a >= b.
OK, here we go;
Prove:
(a+b+c)^2 = (a+b+c)^2 (Reflective property of equality)
(a+b+c)^2 = a^2 + b^2 + c^a + 2ab + 2bc + 2ca
a + b > c
c(a+b) > c^2 fact of inequity
ca + cb > c^2
b + c > a
a(b+c) > a^2 fact of inequity
ab + ac > a^2
c + a > b
b(c+a) > b^2 fact of inequity
bc + ab > b^2
From above
By substitution
(a+b+c)^2 < (ab + ac) + (ca + cb) + (bc + ab) + 2ab + 2bc + 2ca
(a+b+c)^2 < 2ab + 2ac + 2bc + 2ab + 2bc + 2ca
(a+b+c)^2 < 4ab + 4ac + 4bc
(a+b+c)^2 < 4(ab + ac + bc)
(a+b+c)^2 <= 4(ab + ac + bc) ?
Can I make this last step from < to <=? If so is there a principal or property that justifies it?
Thanks,
Bernie
If something is less than something else, it is certainly also less than or equal to it. It's probably a typo though, and you were supposed to prove your next to last line.
The proof is definitely <=, but I think I found the justification. I don't have my notes handy, but I think it's disjunctive addtion justifies that if p then (p or q). Also if (p or q) and (~q) then p.
Bernie
Yea, although it's pretty obvious if you just think about it. Also, I'm not saying you copied the question wrong, I'm saying it was wrong in the book. It's not strictly incorrect, but it's completely unnatural to use a [itex]\leq[/itex] in place of a < when equality is not possible.
