Prove by induction or any other logical argument
26 replies · 7K views · last reply
jammed
Songs of the Martian classical period had just two notes (let us call them x and y) and
were constructed according to rigorous rules:
I. the sequence consisting of no notes was deemed to be a song (perhaps the most
pleasant);
II. a sequence starting with x, followed by two repetitions of an existing song and
ending with y was also a song;
III. the sequence of notes obtained by interchanging xs and ys in a song was also a
song.
All songs were constructed using those rules.
(i) Write down four songs of length six (that is, songs with exactly six notes).
(ii) Show that if there are k songs of length m then there are 2k songs of length 2m+2.
Deduce that for each natural number there are 2^n songs of length (2^n+1) − 2.
Songs of the Martian later period were constructed using also the rule:
IV. if a song ended in y then the sequence of notes obtained by omitting that y was
also a song.
(iii)What lengths do songs of the later period have? That is, for which natural numbers n
is there a song with exactly n notes? Justify your answer.
No equations needed.
The (i) part was really easy. I used the second rule and third rule to produce the four songs of length 6. The four songs were as follow: xxyxyy, xyxyxy, yyxyxx and yxyxyx. In the second part I tried to use every method possible (even induction) but cannot come to a solution. Same is the case with (iii).
hi jammed! :smile:
if a song has length 2m+2, the only way of producing it is by … ? :wink:
jammed said:
its by rule 2
well, yes, since rule 2 is the only rule that makes a song longer
can you be more precise …
how is any particular song of length 2m+2 made up?
hmm … you really should have got this by now
try it this way …
if X is a song of length m, how many songs of length 2m+2 with X in the middle can be created from the rules?
if there is a song k of length m then xkky and by rule 3 ykkx is also a song so we have produce another k song of 2m+2. Am i right?
that doesn't make sense :confused:
try "if there is a song k of length m then xkky and by rule 3 ykkx is also a song so the number of songs of length 2m+2 is … "
By rule 2 and 3 i have created another 2 songs, which are of length 2m+2...thats all i know :cry:
sooo …
I am unable to think in the form of variable to tell you the truth.
you should by now immediately see how to prove (ii)
if it's night-time where you are, then have some sleep :zzz:, and you'll see it in the morning :smile:
if it isn't, then this maths aptitude test does rather indicate that you should be thinking of a different degree course
First of all thank u for being rude. That has really helped.
If there is a song k of length m than by rule 2 we have produced another song of length 2m + 2 so if there are k songs of length m then there will be k songs of length 2m+2. Now to produce other songs of length 2m+2 we have to swap the xs and ys. So in total there are 2k songs of length 2m+2.
Now what do you have to say on this solution
yes, that's the right idea, but it's nowhere near rigorous enough to be a proof
you need to prove a 2-to-1 correspondence between songs of length m and of length 2m+2, all you have proved is that it can't be more than 2-to-1 (you haven't eliminated the possibility of getting the same song in two different ways)
you have shown that for every song X of length m there are songs xXXy and yYYx
you need to show that for every song X of length m there are songs xXXy and yXXx
(and you need to mention that the second song requires Rule III twice)
Now because the first songs of 2m+2 end in y and the second song of 2m+2 end in x so they are different from each other.
you don't have to persuade me … i agree that the answer is correct
but to pass the test, you have to be able to write the proof out clearly briefly and rigorously …
that's what maths is, particularly so when they specifically claim to be testing "logical argument" :smile:
(and if I'm understanding your post correctly, you're still only proving that those two songs are different … which is obvious … not that no song can be produced twice from different Xs)
also a song.
jammed said:
… How abt the third part of the question?
ok, have a go! :smile:
Ok...
now if we remove the y(i.e song ending in a y) ,according to rule 4, of a song of length m then it will have length m-1
And if there is a song which ends in x we can use rule 3 to swap it and make it end in y so it will also have a length of m-1. So i think there will exist songs of all possible lengths.
jammed said:
Ok...
you haven't proved all possible lengths, you've only proved that m-1 is possible
No what I meant was that when m-1 was left it will also be ending in either x or y. If it is ending in x then v can again swap it to end it in y and then again remove the y to get song of m-2 length. so like this v can keep on getting songs of length m-3, m-4, m-5 etc. In the end we will be song on no notes so in this way we get all the possibilities
I don't think this is rigorous or close to the way you may be demanding. After i have tried every way, pls its my request that you write the proof of the questions so that i can know how to write them in a proper way.
you can say that if there exists a song of length m, there exists a song of length m-1 (constructed in the way you defined), and therefore by induction of any length less than m
and since there exist songs (under the original rules) of indefinitely large length, that means that any length is possible
So i should combine your argument plus mine and that will make the proof brief and rigorous
Can u tell me the variations in this type of question that is what other questions can be asked in this context
it could be anything …
the question won't be difficult, it'll be designed to test your ability to translate from ordinary English to short clear logic :wink:
(but if i was setting the question, it'd be about how long is a piece of string :biggrin:)
