Prove:if 1/a+1/b+1/c=1 and a,b,c >0 then (a-1)(b-1)(c-1)>=8
  • Thread starter Thread starter Danijel
    proof
The discussion revolves around proving the inequality (a-1)(b-1)(c-1) ≥ 8 under the condition that 1/a + 1/b + 1/c = 1, with a, b, c being positive numbers. Participants suggest that since a, b, and c must all be greater than 1, it follows that a + b + c must exceed 9 to satisfy the inequality. The problem can be framed as a constrained optimization problem, where the goal is to minimize the function f(a, b, c) = (a-1)(b-1)(c-1) subject to the constraint 1/a + 1/b + 1/c = 1. The solution involves deriving a new function F(a, b) and finding its stationary points to confirm that the minimum value is at least 8.
  • Understanding of inequalities and optimization in mathematics
  • Familiarity with constrained optimization techniques
  • Knowledge of algebraic manipulation and functions
  • Basic understanding of the properties of positive numbers
  • Study constrained optimization problems in calculus
  • Learn about the method of Lagrange multipliers for optimization
  • Explore inequalities and their proofs in mathematical analysis
  • Investigate the properties of symmetric functions and their applications
Mathematicians, students studying advanced algebra, and anyone interested in optimization problems and inequalities in mathematical analysis.
Danijel
The problem: prove that if 1/a + 1/b + 1/c=1 and a,b,c are positive numbers then (a-1)(b-1)(c-1)>=8
I've tried it myself but couldn't do it. I have tried going backwards i.e. :
(a-1)(b-1)(c-1)>=8
(fast forward) abc -(ab+bc+ac) +a+b+c -1 >=8
Now from 1/a + 1/b + 1/c = 1 we have that ab+bc+ac/abc=1 thus :
ab + bc + ac = abc , so abc -(ab+bc+ac) +a+b+c -1>=8 is really a+b+c -1>=8
that is a+b+c >=9 . So If I could somehow prove that a+b+c>9 then I could work backwards and prove the former statement.
But the only progress I've made is :all of a,b,c must be greater than 1 because if they weren't then any of the 1/a,1/b,1/c would be greater then 1 thus we would need negatives(and a,b,c are positive) to "bring back" the value to 1, nor can they equal to 1 because the same thing would happen(one of 1/a,1/b,1/c would be equal to 1 and we would need negatives)so a>1, b>1, c>1 adding these three together we get a+b+c >3 ,and I need a+b+c+>=9.
Sorry for the long post. Could anyone give me some directions?
Thanks,
Daniel
Could you prove it for 2?
## \frac1a + \frac1b = 1## Prove that ##ab\geq 4##?
Your problem hinges on the relationship between a, b, and c.
If a = b = c, then they are all 3, right?
Let's change one of the three...let a be (3-x), either b or c would have to increase to maintain the 1/a + 1/b + 1/c = 1 balance.
How much would it change?
Let's say they absorb the difference equally...share the burden, then you have ##\frac{1}{3-x} + \frac{2}{3+y} = 1##. Can you solve for y in terms of x? If y > x/2 you have shown that (3-x) + (3+y)+(3+y) > 9.
Thank you RUber!
(a-1)(b-1)(c-1)>=8
Thanks,
Daniel
You can regard this as a constrained optimization problem:
\begin{array}{l} \min_{a,b,c} f(a,b,c) = (a-1)(b-1)(c-1) \\<br /> \text{subject to} \\<br /> \displaystyle \frac{1}{a} + \frac{1}{b} + \frac{1}{c} = 1<br /> \end{array}<br />
Let us restrict the problem to ##a,b,c > 1##. There is a good reason for this, because if you allow any of ##a,b,c## to be ##< 1## but positive, then you must also allow one or more of them to be ##< 0## in order to balance out the constraint. In that case you can construct a sequence of feasible ##a_n, b_n, c_n## values that give ##f(a_n,b_n,c_n) \to -\infty##: an unbounded problem having no minimum.
OK, so we want ##a, b, c > 1##. Solve the constraint for ##c## as a function of ##a,b##, then plug that formula into ##f(a,b,c)## to get a new function ##F(a,b)## involving ##a## and ##b## alone, and with no constraint anymore (other than ##a,b > 1##, and implicitly, ##c > 1##). This unconstrained 2-variable optimization problem can be solved by finding the stationary point (or points) of ##F(a,b)##. If ##\min_{a,b} F(a,b) \geq 8## you are done.
Wow, I would've never thought of something like that. Although this way of proving is a little too complex for me.
Thank you for your reply!
