Prove integral with arctan and square root singularity
  • Thread starter zhulihuang
    Integration
zhulihuang
Please prove the integral in the attachment
Tried many ways to solve it. Integration by parts, trig sub etc.
The closest one is the substitution $U=\frac{r^2}{2}-\frac{R^2/2}+x^2$, which gives some arcsin. I change it into arctan, but it is not the arctan mathematica shows. I guess it has something to do with the $\sqrt{R^2 - x^2}$, since it will blow up at R. May need delta function to handle it.
  • Definite integral from 0 to b of x divided by the product of the square root of (a^2 + x^2) and the square root of (b^2 - x^2), dx, equal to a times arctan(b/a) divided by the square root of a^2.
Welcome to PF;
Nice try :)
This is your homework - we can help you where you get stuck but you have to do the work.
Please give it a go and show your working as far as you get.
Try to describe how you are thinking about the problem as you go.
Don't worry about looking stupid - we've all done this before: you are among understanding, and friendly, people here.
You tried many ways- please show us at least some. If possible one where you feel you came closest to solving the problem. That will make it easier to give suggestions.
The closest one is the substitution ##U=\frac{r^2}{2}-\frac{R^2}{2}+x^2##, which gives some ##\arcsin##. I change it into ##\arctan##, but it is not the ##\arctan## Mathematica shows. I guess it has something to do with the ##\sqrt{R^2 - x^2}##, since it will blow up at ##R##. May need delta function to handle it.
Well your integral (off the supplied attachment) seems to be: $$\int_0^b \frac{x.dx}{\sqrt{a^2+x^2}\sqrt{b^2-x^2}}=\frac{a\arctan(b/a)}{\sqrt{a^2}}$$ ... since there is no ##r## or ##R## in the integrand, it is difficult to see your reasoning behind the substitution. From context - I'm guessing R=b and r=a?
Considering the arctan in the solution - perhaps a substitution like ##x=a\tan\theta## and a table of trig identities will be the way to go?
Did you try that?
However, HallofIvy is right - it is better for you to go step-by-step through the one you felt got the closest.
So you made the substitution: what was the next step?
(I know: it's a pain typing out the math. Use the "quote" button off the bottom of this post and see how I was able to type the math out ... you can copy and paste then make minor adjustments.)
