Prove limit of (sin2x)/(2x) as x approached 0 is 1?
  • Thread starter Thread starter jessjolt
    Limit
The limit of (sin2x)/(2x) as x approaches 0 is proven to be 1 using the epsilon-delta definition of limits. The discussion emphasizes the importance of the known limit of (sinx)/x as x approaches 0, which is also 1. Participants suggest various methods to prove this limit, including geometric reasoning, Taylor series expansion, and the squeeze theorem. The conversation highlights the need for rigorous proofs without circular reasoning, particularly for educational purposes.
  • Epsilon-delta definition of limits
  • Understanding of Taylor series expansion
  • Knowledge of the squeeze theorem
  • Basic trigonometric identities and properties
  • Study the epsilon-delta definition of limits in detail
  • Learn about Taylor series and their applications in calculus
  • Explore the squeeze theorem and its proofs
  • Investigate geometric interpretations of trigonometric limits
Students learning calculus, educators teaching limit proofs, and anyone interested in the rigorous foundations of trigonometric limits.
jessjolt
Prove limit of (sin2x)/(2x) as x approached 0 is 1. By prove I mean using the epsilon/delta definition of precise limit. You may use the fact that the limit of (sinx)/x as x approaches 0 is 1.
attempt: (where E=epsilon and d=delta)
|(sin2x)/(2x) - 1| < E if |x|<d
2(-E+1) < (sin2x)/(2x) < 2(E+1)
...now I am guessing that from here you need to isolate the x so as to get |x| is less than some expression, which solves for delta. But when I try this I keep getting that x is greater than some number, not less. Also I do not know what my professor means by being able to use the limit of sinx/x?
So you know that if
|y|&lt;\delta~\Rightarrow~|\frac{\sin(y)}{y}-1|&lt;\varepsilon
You need to find
|x|&lt;\delta~\Rightarrow~|\frac{\sin(2x)}{2x}-1|&lt;\varepsilon
Obviously, y=2x here...
I would like to know if there's any proof of "limit of (sinx)/x as x approaches 0 is 1." ..
Sure, watch http://www.khanacademy.org/video/proof--lim--sin-x--x?playlist=Calculus
How "limit of (sinx)/x as x approaches 0 is 1." is proven depends upon how sine has been defined. If for example sin'(0)=1 in included in the definition the result is trivial.
Think of a circle with radius r, and a differential angle dtheta that spans r*dtheta from the center on the circumference.
Sin(dtheta ) = r*dtheta / r , right ( although it seems there are 2 hypotenuses both being r, take one of them accepting the other is across the angle that is about 89.999999999... degrees )
So Sin(dtheta)*r=r*dtheta
cancel r's
to get to the eqn
Sin(dtheta)/(dtheta ) = 1
which interprets to lim x---> 0 , Sin x / x = 1
Yes thanks for replies above.
But in fact I have watched somewhere else, saying that the area of circle = pi * r^2 is dependent on the result sinx/x = 1 as x->0
Say, cut the circle of radius r into n equal partitions (each with angle n/2pi in the center) and area of the circle = n*r^2 /2 *sin(n/2pi) (by area of triangle = A*B*1/2*sin(angle between AB)
Take n tends to infinity, you get pi *r^2Is there any proofs either than geometric reasoning? Say, something like epsilon-delta stuff? thanks in advance!
The most straightforward method is to use the Taylor series in the vicinity of the origin:
\frac{\sin x}{x} = 1 - \frac{x^2}{6} +\frac{x^4}{120} + \mathcal{O}(x^6)
Clearly the limit is 1 as x vanishes.
Oh thank you!
But how to show that the Taylor expansion does equal to sinx without using sinx/x->1 at all? I am teaching a group of students which I want to make sure everything goes in the right path and get rid of "circular proofs"! thx!
my concern is - how can we show the area of sector is 1/2*pheta?
and would there be any simple ways with epsilon-delta?
As I said above, you don't need to use the geometrical setting. You can simply say that \sin\theta&lt;\theta&lt;\tan\theta for \theta\in(0,\pi/2). This could be illustrated by plotting the functions together: http://www.wolframalpha.com/input/?i=plot+sin(x),x,tan(x)+for+x=0..pi/2
Thank you very much! but are there any simple proofs of x>sinx and x<tanx?
sin(x) is chosen so that sin'(0)=1
it is just a convention
33K
