Prove m²+n²=cosec²θ from three given equations
  • Thread starter Thread starter ritwik06
    Trigonometry
4 replies · 3K views
ritwik06
If [tex]m^{2}+m' ^{2}+2mm' cos \theta=1[/tex]
[tex]n^{2}+n' ^{2}+2nn' cos \theta=1[/tex]
[tex]mn+m'n'+(mn'+m'n)cos \theta =0[/tex],
then prove that [tex]m^{2}+n^{2}=cosec^{2} \theta[/tex]
I have tri a lot but its difficult to eliminate m' or n'
If I add the first to equations and separate m^2+n^2 to left ide, again its difficult to prov the RHS to [tex]cosec ^{2} \theta[/tex]
draw the triangle!
Hi ritwik06! :smile:
Well, looking at the the first two equations, you're obviously supposed to draw a triangle with sides m and m', and an angle of π - θ between them. :wink:
Give the name φ to the angle opposite m (so the angle opposite m' is … ?).
Then do the same with n n ' and ψ.
And then use the sine rule … :smile:
Hi tim :smile:
Well I am not familiar with this. though I have used sine rule in physics. Please tell me why am I expected to make a triangle ?? and what shall I do with this thing? Simply applying:
sin a /a=sin b/ b =sin c /c won't solve my purpose, i have tried it. :wink:
regards
cosine rule for triangles …
ah … perhaps you haven't done the cosine rule for triangles …
a2 = b2 + c2 - 2bc cosA​
so the reason to make this particular triangle is because the first two equations given are the cosine rule for two triangles, both with one side of length a = 1, and both with opposite angle π - θ, one with the other sides of length m and m', and the other n and n'.
(check for yourself that the cosine rule really does give those two equations for those triangles)
Draw those triangles, and apply the sine rule to get m and m' in terms of θ and φ, and n and n' in terms of θ and ψ.
Then plug those values into the third given equation, which should give you a nice relationship between θ φ and ψ. :smile:
ritwik06 said:
Hi tim :smile:
regards
Because the cosine law says that if a triangle has sides of length a, b, c and A is the angle opposite side A, then c2= a2+ b2- 2ab cos(A).
The equation [itex]m^2+ m'^2+ 2mm'cos(\theta)= 1[/quote] differs from that only only in having "+" instead of "-". Since [itex]cos(\pi- \theta)= -cos(\theta[/itex]), that should make you think of a triangle having sides of length m, m', and 1 and having angle [itex]\pi- \theta[/itex] opposite the side of length 1.[/itex]
