Prove that angle BAD equals angle CEA in triangle ABC
  • Topic:
  • Thread starter Mathick
    Triangle
2 replies · 3K views · last reply
Mathick
In the triangle $$ABC$$ a point $$D$$ lies on the edge $$BC$$, $$E$$ - on the edge $$AB$$. Aditionally, $$BD=AC$$, $$AD=AE$$ and $$AB^2=AC\cdot BC$$. Prove that $$\sphericalangle BAD = \sphericalangle CEA$$.
I have to do this task on Maths class on Monday and I need any tips or something because I don't know how to start it.
I won't give you the answer, but see if you can show that (1) the line $AB$ is tangent to the circle through $A$, $C$ and $D$; (2) the triangles $BAD$, $CEA$ are congruent.
  • Geometry diagram: triangle ABC with points D on BC and E on AB, a circle through A, D and C, segments AD, AC and EC drawn, and lines BA extended past A and BC extended past C.
Proof: the line $AB$ is tangent to the circle through $A$, $C$ and $D$
Knowing that $$BD=AC$$, $$AD=AE$$ and $$AB^2=AC\cdot BC$$, we get $$\frac{AB}{AC}=\frac{BC}{AB}$$ and then $$\frac{AB}{BD}=\frac{BC}{AB}$$. Thus, the triangles $$ABD$$ and $$CBA$$ are similar. So $$\sphericalangle BDA=\sphericalangle CAB$$ and $$\sphericalangle BAD=\sphericalangle ACB$$. Additionally, $$\frac{AC}{AB}=\frac{AD}{BD}$$ (because the triangles $$ABD$$ and $$CBA$$ are similar). So $$\sphericalangle BAC=\sphericalangle BDA$$, and what's more $$\sphericalangle ADC=\sphericalangle CA...$$ (there is no letter on line AB after A).
As a result, the line AB is tangent to the circle through $A$, $C$ and $D$ because of the theorem of which is illustrated on the photo.
Is it correct? Is there any better proof?
  • Circle with a tangent line at the top touching it at a point; a chord from that point to the bottom of the circle, with angles labeled alpha and pi/2 minus alpha, and the text pi/2 minus (pi/2 minus alpha) equals alpha.
