Prove that if p > 3 is prime, then p^2 = 6k + 1.
  • Thread starter Thread starter s3a
    Prime
The discussion focuses on proving that if p is a prime number greater than 3, then p² can be expressed as 6k + 1 for some integer k. The proof establishes that p mod 6 cannot be 0, 2, or 4, as these would imply p is even or a multiple of 3. The only valid cases are p mod 6 = 1 or p mod 6 = 5, both leading to p² ≡ 1 (mod 6). This conclusion is supported by modular arithmetic and congruence theory.
  • Understanding of prime numbers and their properties
  • Familiarity with modular arithmetic
  • Knowledge of congruence relations
  • Basic algebraic manipulation skills
  • Study the properties of prime numbers in number theory
  • Learn about modular arithmetic and its applications
  • Explore congruence theory in depth
  • Practice proving statements using modular proofs
Mathematics students, educators, and anyone interested in number theory and modular arithmetic proofs.
s3a
Problem:
Prove that if p is a prime number larger than 3, then p^2 = 6k + 1 for some k ∈ ℤ.
Correct Solution:
"Note that if p is a prime number larger than 3, then p mod 6 cannot be 0, 2, or 4 as this would mean p is even, and cannot be 3 as this would mean p is a multiple of 3.
The only two remaining cases are p mod 6 = 1 or p mod 6 = 5.
p mod 6 = 1: Then p = 6k + 1 for some k ∈ Z. This means
p 2 = 36k^2 + 12k + 1 = 6(6k^2 + 2k) + 1 = 6i + 1 where i = 6k^2 + 2k.
p mod 6 = 5: Then p = 6k + 5 for some k ∈ Z. This means p 2 = 36k^2 + 60k + 25 =
6(6k^2 + 10k + 4) + 1 = 6i + 1 where i = 6k^2 + 10k + 4.
In both cases, we have the desired result."
Modulo computations.
I understand why the remainder/value of p mod 6 cannot be 0, 2 or 4, because the non-remainder part would be divisible by 6 (and therefore divisible by 2), and the remainder part would also be divisible by 2, therefore the entire number p would be divisible by 2, which would mean that it is even, and if a number greater than 3 is even then it is divisible by a number other than 1 or itself, so it is not prime.
I also get that p mod 6 = 3 would mean that p is a multiple of 3, and p cannot be 3 (since it must be larger than 3 as stated in the problem), but I don't get why it cannot be other multiples of 3 like 9.
And, I don't get why the solution is computing p mod 6 in the first place.
As for evaluating the p mod 6 = 1 and p mod 6 = 5 cases, I do understand what's going on there.
Could someone please help me fully understand what the solution is saying?
Any input would be GREATLY appreciated!
Like you said, we know for sure that p = 1 (mod 6) or p = 5 (mod 6). If p = 1 (mod 6), then p^2 = 1^2 = 1 (mod 6), and we're done. Else, p = 5 = -1 (mod 6), and so p^2 = (-1)*(-1) = 1 (mod 6). p can't equal 3 mod 6, else it'd be divisible by 3 (like 9), and p wouldn't be prime.
On the first point, why not construct a short proof yourself to show that:
If p = 3 mod 6 then p is divisible by 3. Hence p is not prime (p > 3).
On the second point, the proof is in two parts. First, it establishes which congruences mod 6 are potentially prime: only 1 and 5. Then shows that both, when squared, are equal to 1 mod 6.
You could try an alternative proof starting with ##p^2 mod 6## and working back. But it wouldn't be as neat.
This is a really easy problem, read a little bit of congruence theory...
  • · Replies 16 ·
  • · Replies 30 ·
