Prove that tan2x - sin2x = tan2x·sin2x
12 replies · 3K views
Faint
(tan2x) - (sin2x) = (tan2x)(sin2x)
Prove these two are equal.
Various trig identities, mainly tan2x = sin2x / cos2x
I tried putting in Sin2x / cos2x for tan, but I don't know where to go from there.
Anyone mind helping me out?
This has a really simple solution. Factor out sin(x)^2 from the left hand side and then simplify.
I don't how/where you can factor sin(x)^2 out in this case. This is what I have done to the left side thus far.
[tex]\frac{sin^{2}x}{cos^{2}x} - \frac{sin^{2}x}{1}[/tex]
then
[tex]\frac{sin^{2}x}{cos^{2}x} - \frac{sin^{2}xcos^{2}x}{cos^{2}x}[/tex]
which ends up as
[tex]\frac{sin^{2}x - sin^{2}xcos^{2}x}{cos^{2}x}}[/tex]
Well, using your steps, you're almost at the solution. Again, factor sin(x)^2 out of the numerator and simplify. :)
This is what I was talking about in my initial post: tan(x)^2 - sin(x)^2 = sin(x)^2 (sec(x)^2 - 1), which is easy to simplify.
[tex]\frac{sin^{2}x (1 -cos^{2}x)}{cos^{2}x}}[/tex]
I'm missing something, because I still don't get it. What am I overlooking? Sin/Cos is equal to Tan, but then I have (1 - cos2x)/(cos2x)
Are you familiar with the trig. identity sin(x)^2 + cos(x)^2 = 1? If you are, the solution should seem fairly obvious in both instances.
At this point I have:
[tex]\frac{sin^{2}x (1 -cos^{2}x)}{cos^{2}x}} = (\frac{sin^{2}x}{cos^{2}x})(\frac{sin^{2}x}{1}})[/tex]
I know that identity, but I can't see how it can be used on either side.
I'm sorry for my complete lack of ability to grasp this.
If you know that identity then you surely know 1 - cos(x)^2 = sin(x)^2 or similarly that sec(x)^2 - 1 = tan(x)^2.
Just realized this:
[tex]\frac{sin^{2}x (1 -cos^{2}x)}{cos^{2}x}} = \frac{sin^{2}x(sin^{2}x)}{cos^{2}x}[/tex]
which turns into
[tex]\frac{sin^{2}x (1 -cos^{2}x)}{cos^{2}x}} = \frac{sin^{2}x(1-cos^{2}x)}{cos^{2}x}[/tex]
Did I do anything incorrect there? And thank you very much for your help.
Nothing there is incorrect - in fact that result should tell you something - but you should have made a connection which it appears you have still failed to make. If 1 - cos(x)^2 = sin(x)^2 and we have (1 - cos(x)^2)/cos(x)^2, what substitution can I make to simplify the expression?
sin(x)^2
------------ = tan(x)^2
cos(x)^2
Correct? I get confused when this happens though:
[tex]\frac{sin^{2}x (sin^{2}x)}{cos^{2}x}}[/tex]
to
[tex]tan^{2}x\frac{sin^{2}x}{cos^{2}x}}[/tex]
or does the cos(x)^2 drop?
The cos(x)^2 term does not drop but is merely factored out essentially in the tan(x)^2 term; hence, your resulting equation should read tan(x)^2 sin(x)^2. Q.E.D.
Okay, I understand. Thank you a lot for the great help. :)
