Prove the dipole potential is differentiable everywhere except at the surface
The discussion revolves around proving the differentiability of the dipole potential, represented by an integral involving charge density and surface charge density, at points except at the boundary where it is claimed to be discontinuous. Participants are exploring the conditions under which the potential is differentiable and the implications of the behavior of the charge distributions.
  • Participants discuss the need to establish the existence and continuity of partial derivatives of the dipole potential. Some express uncertainty about the rigor required for the proof, while others suggest examining specific cases or counterexamples to understand the differentiability better.
The discussion is ongoing, with participants sharing various insights and approaches. Some have pointed out the necessity of identifying properties of the charge density for a rigorous proof, while others question the validity of certain steps taken in the original poster's reasoning. There is no explicit consensus on the best approach, but several productive lines of inquiry are being explored.
Participants note that assumptions about the charge distributions being "well-behaved" are critical to the discussion. There are also concerns about the mathematical rigor required for the proof, particularly regarding the treatment of limits and integrals. The original poster expresses a desire to understand the differentiability of potentials more deeply, indicating a gap in the existing literature on the topic.
Mike400
Moved from a technical forum, so homework template missing
The dipole potential is given by:
##\displaystyle\psi=\int_{V'} \dfrac{\rho}{|\mathbf{r}-\mathbf{r'}|} dV'
+\oint_{S'} \dfrac{\sigma}{|\mathbf{r}-\mathbf{r'}|} dS'##
I need to prove that ##\psi## is differentiable at points except at boundary ##S'## (where it is discontinuous)
I know if partial derivatives of ##\psi## "exist and are continuous" everywhere except at boundary ##S'##, then ##\psi## is differentiable everywhere except at boundary ##S'##.
How shall I proceed in showing partial derivatives of ##\psi## exist?
Thanks for any help in advance.
You need to show us how far you can get with this problem. My main question would be how rigorous you think you need to be?
Let:
##\displaystyle\psi_{V}=\int_{V'} \dfrac{\rho}{|\mathbf{r}-\mathbf{r'}|} dV'##
##\displaystyle\psi_{S}= \oint_{S'} \dfrac{\sigma}{|\mathbf{r}-\mathbf{r'}|} dS'##
I need to prove the following two statements:
##(1)## Existence of partial derivatives of ##\psi## everywhere except at boundary ##S'##
My approach: I do not have any approach right now.
##(2)## Continuity of partial derivatives of ##\psi## everywhere except at boundary ##S'##
To prove ##(2)##, we need to prove the following:
(i) Continuity of partial derivatives of ##\displaystyle\psi_{V}## all over space
(ii) Continuity of partial derivatives of ##\displaystyle\psi_{S}## everywhere except at boundary ##S'##
My approach:
(i) I do not have a simple approach. However in this book (page 150) there is a rigorous proof.
(ii) If we fix ##\mathbf{r'}##, then ##\dfrac{x-x'}{|\mathbf{r}-\mathbf{r'}|^3}## is continuous in space except at ##\mathbf{r}=\mathbf{r'}##.
Therefore ##\dfrac{(\Delta{q_i}) x-x'}{|\mathbf{r}-\mathbf{r'}|^3}## is continuous in space except at ##\mathbf{r}=\mathbf{r'}##.
Since superposition of continuous functions is a continuous function:
##\displaystyle \lim \limits_{N \to \infty} \sum_{i=1}^N \dfrac{(\Delta{q_i}) x-x'}{|\mathbf{r}-\mathbf{r'}|^3}
=\int_{S'} \dfrac{(dq') x-x'}{|\mathbf{r}-\mathbf{r'}|^3}
=\int_{S'} \dfrac{(\sigma) x-x'}{|\mathbf{r}-\mathbf{r'}|^3}\ dS'=E_{S\ x}=\dfrac{\partial {\psi_S}}{\partial x}##
is continuous everywhere except at ##\mathbf{r}=\mathbf{r'}## points, i.e. boundary ##S'##
I'm not sure how much I can help. But, anyway:
1) If you take a charged spherical shell as an example. The electric field is discontinuous but the potential is continuous, but not differentiable at the surface.
2) You can find functions ##\rho## where this would not hold. You are going to have to make some assumptions about ##\rho## and ##\sigma## being "well-behaved".
3) The term in the denominator, technically, makes these improper integrals. Certainly for points within the volume or on the surface. That's another complexity.
4) Possibly a counterexample, like the one above, is enough to show that in general the potential is not differentiable across a surface charge. In fact, if ##\sigma## is zero on some area, then the potential may well be differentiable at a point in that region. So, I'd just get an example of a non-differentiable potential.
5) Apart from that you'll just have to use the definition of a partial derivative. It's enough to do it for one variable.
To do this rigorously would be a nightmare IMHO.
Sorry I can't be of more help.
Maybe @fresh_42 has some thoughts?
I don't know how much this helps, but it seems you need to use the FTC in 2-dimensions, which is Green's theorem, though I don't have a full understanding of how to do this. Is this what you are aiming for?
I was told by moderators to show my work. I have worked it out myself in the best possible way I could. It just needs to be checked (if there are any mistakes).
242337
242338
242339
242340
242341
continued below
242342
242343
Are there any mistakes or anything missing?
Can anyone point out the flaws in my work if there are any.
I had a look at it. In general the result won't be true. It will depend on ##\rho## being well behaved in some way.
Any rigorous proof should identify the required properties of ##\rho##.
The first thing you did was take a limit inside an integral. That in general is not possible.
On the main body you seemed to prove continuity outside the region of charge, but there was nothing to justify continuity at the singularity. A rigorous proof would have to take the limit of proper integrals in this case.
In general a rigorous proof ought to be built on perhaps some intermediate theorems. Doing it from first principles is probably asking too much. And, if I'm honest, of limited value.
Finally, you need to decide whether the integral is Riemann or Lesbesgue.
##\rho## is continuous, bounded and its domain ##V'## is finite. Any more properties required to be added??
I was also not convinced myself with part I and part II in the first place. The convergence theorems seem to be too esoteric to me. Do you know another simpler method to show the existence of partial derivatives of ##\psi^V## and ##\psi^S##?
I think I have done. Please have a look at part V
PeroK said:
Finally, you need to decide whether the integral is Riemann or Lebesgue.
I am using Riemann integration. (Haven't studied Lebesgue yet).
Note: I am a physics student, not a math student. So I am not familiar with the convergence theorems and Lebesgue integration. However all of the physics books I have never discuss the differentiability of
potentials and fields. This dissatisfies me and so I am trying to get out of this difficulty. Can you please suggest whether I really need to go through the proofs of differentiability in the first place, or can simply assume them to be continuously differentiable as physicists do. If I am to adopt the latter, how can the assumption be justified?
  • · Replies 42 ·
