Prove the following Logic Property
  • Context: MHB
  • Thread starter Thread starter shamieh
    Logic Property
The discussion centers on proving a logic property using a truth table, specifically examining the expression x + y * z = (x + y)(x + z). Participants explore the nature of this property, its classification, and the correctness of their truth table evaluations.
  • Some participants propose that the property in question is the Distributive Property, specifically the distributivity of disjunction over conjunction.
  • Participants present truth tables to evaluate the expressions but express uncertainty about the correctness of their calculations.
  • There are conflicting evaluations of specific rows in the truth table, with some participants questioning the outputs for rows 6 and 8.
  • One participant realizes an error in their evaluation order, leading to a corrected expression that aligns with the proposed property.
  • Another participant emphasizes the importance of parentheses in Boolean expressions to avoid ambiguity in operations.
  • Some participants discuss the conventions of operation precedence in Boolean algebra compared to ordinary arithmetic.
Participants do not reach a consensus on the correctness of the truth table evaluations initially presented. There are multiple competing views on the interpretation of the logic property and the necessity of parentheses in expressions.
Participants express uncertainty regarding the evaluation of specific rows in the truth table and the implications of operation precedence in Boolean algebra versus arithmetic.
shamieh
Prove the following logic property using a Truth Table (perfect induction). What is this property called?
My Answer:
Distributive Property?
Truth table.
  1. x y z f
    [0]0 0 0 0
    [1]0 0 1 0
    [2]0 1 0 0
    [3]0 1 1 1
    [4]1 0 0 0
    [5]1 0 1 1
    [6]1 1 0 0
    [7]1 1 1 1
By truth table I get: $$\bar{x}yz + x\bar{y}z + xyz$$ which becomes z + z + xyz ?Am I doing this wrong? Why am I not getting x + yz?
should I use algebraic manipulation?
x + yz = (x + y)(x + z)
x + yz = xx + xz + xy + yz
x + yz = x + xz + xy + yz
now what?
My Answer:
Yes, distributivity of disjunction over conjunction. Regular distributivity in arithmetic x * (y + z) = x * y + x * z is distributivity of multiplication over addition: multiplication is carried into the sum and is distributed to each of the terms y and z. Similarly, in x + y * z = (x + y) * (x + z), disjunction (+) is carried into the conjunction and is distributed to each of the conjuncts y and z. This type of distributivity does not hold in regular arithmetic, unlike distributivity of conjunction over disjunction: x * (y + z) = x * y + x * z.
shamieh said:
Truth table.
  1. x y z f
  2. 0 0 0 0
  3. 0 0 1 0
  4. 0 1 0 0
  5. 0 1 1 1
  6. 1 0 0 0
  7. 1 0 1 1
  8. 1 1 0 0
  9. 1 1 1 1
Is this the truth table of the left- or right-hand side? In any case, check rows 6 and 8.
The truth table is of the left hand side. What do I need to check rows 6 and 8 for?
$$Row 6:$$ 1 OR 0 = 1, 1 AND 1 = 1, thus; 1.
$$Row 8:$$ 1 OR 1 = 1, 1 AND 1 = 1, thus; 1
"OR evaluates to 1 if any n in the comparison is 1"
"AND evaluates to 1 if every n in the comparison is 1"
These hold true...So I don't understand the problem here?
I don't understand how you calculated this. But in any case, you got 1, while in post #1 the value of f in rows 6 and 8 is 0.
The left-hand side is x + y * z.
Row 6: x = 1, y = 0, z = 0, so x + y * z = 1 + 0 * 0 = 1 + 0 = 1.
Row 8: x = 1, y = 1, z = 0, so x + y * z = 1 + 1 * 0 = 1 + 0 = 1.
I've forgotten a row :p Let me fix it lol.
I labeled my rows correctly now. Can you check and see if my $f$ is producing the right output again?
Here is what I am getting: $$\bar{x}yz + x\bar{y}z + xyz$$ which is $$z + z + xyz$$?
Please check rows 4 and 6. The value of (x + y * z) should be 1 there, as I explained in post #4.
I found the Problem Ev, I was evaluating 1 + 0 before I was evaluating 0 * 0. I feel like an idiot. Thanks so much for the help!
so i get
$$(\bar{x}yz)+(x\bar{y}\bar{z})+(x\bar{y}z)+(xy\bar{z})+(xyz) = x + yz$$ which by distributivity of disjunction over conjuction gives me$$ (x + y)(x + z) = xx + yz = x + yz$$ :D:D
thus
$$x + yz = (x + y)(x + z)$$
Just a reminder:
(x+y)*z is not the same as: x+(y*z), as one can see by setting:
x = y = 1, z = 0.
Parentheses matter.
x +yz is equivalent to x +(y*z) though correct? Or should I include parenthesis just to be safe? Because if you know that yz is y * z wouldn't it be obvious that according to operations it is clear the multiplication would be done, then addition?
If you are following a CONVENTION in which it is AGREED that multiplication is performed FIRST, then yes.
Although such a convention exists for ordinary arithmetic, it does not (logically) follow that the same convention is to be used for Boolean operations.
In ordinary arithmetic, multiplication is a "higher level" operation than addition (addition has to be defined first, and then multiplication is "iterated addition"). In Boolean algebra, disjunction and conjunction are "on the same level", there is no intrinsic reason to denote one as "prior" (hence the symmetry in the DeMorgan rules, conjunction and disjunction are DUAL).
I would include the parentheses, so as to obviate the need for clarification to any reader.
  • · Replies 17 ·
