Prove x d/dx δ(x) = -δ(x) using gaussian delta sequence
4 replies · 64K views · last reply
coaxmetal
show
[tex]x\frac{d}{dx}\delta(x)=-\delta)(x)[/tex]
using the gaussian delta sequence ([tex]\delta_n[/tex]) and treating [tex]\delta(x)[/tex] and its derivative as in eq. 1.151.
the gaussian delta sequence given in the book is
[tex]\delta_n=\frac{n}{\sqrt{\pi}}e^{-n^2x^2}[/tex]
and eq 1.151 is just part of the definition of the delta function:
[tex]f(0)=\displaystyle\int_{-\infty}^{\infty}f(x)\delta(x)dx[/tex]
thus far, I have tried substitution the derivative of [tex]\delta_n(x)[/tex] for the derivative of the delta function, and then taking the limit as n goes to infinity, but that got me nowhere. I have also tried integrating both sides to see where it got me, but that was nowhere useful. The problem is I just don't understand how the derivative of the delta function works on its own.
The delta function is actually a distribution, and is not differentiable in the classical sense. In order to consider such differentiation, we have to revert to generalized derivatives. This is done by assuming a certain level of differentiability on f and some vanishing conditions.
If f is a smooth function with compact support on a set D, the generalized derivative v' of a distribution v is any function w such that
[tex]\int_D v' f dx = - \int_D w f' dx[/tex]
Since the delta function is a distribution, it only truly makes sense to characterize its derivative under integration.
You may want to take a look at the following two pdfs:
This link talks about generalized derivatives
http://links.uwaterloo.ca/amath731docs/sobolev.pdf
This link talks about the Dirac delta distribution
http://links.uwaterloo.ca/amath731docs/delta.pdf
Okay, I realize that what I gave you may not be entirely helpful since you have to use the Gaussian sequence.
We know that
[tex]\displaystyle \lim_{n\to\infty} \delta_n = \delta [/itex]<br /> and that it only makes sense to consider the delta function under the integral. So try evaluating<br /> [tex]\lim_{n\to\infty} \int_{-\infty}^\infty x \frac{d}{dx} \delta_n \ dx [/itex]<br /> then show that the value you get is equivalent to<br /> [tex]\int_{-\infty}^\infty -\delta(x) \ dx[/tex][/tex][/tex]
your first answer, and the fact that it only makes sense under integration, actually got me doing just what you suggested, so thanks. THanks for the links too, I was looking for good resources on the delta function. I think I have it now.
