Proving a Fact About Exact Differentials
  • Thread starter Thread starter e(ho0n3
    Differentials
The discussion centers on proving that the differential form P dx + Q dy is exact under the condition that Q_x = P_y, where P and Q are functions with continuous partial derivatives on a disc D. The participants clarify that the function g(x, y) can be defined as g(x, y) = ∫_a^x P(t, b) dt + ∫_b^y Q(x, s) ds, leading to the conclusion that g_x = P and g_y = Q, confirming the exactness of the differential. Additionally, it is established that if the line integral of P dx + Q dy around any closed curve is zero, then Q_x - P_y must also equal zero, reinforcing the relationship between the functions.
  • Understanding of exact differentials in multivariable calculus
  • Familiarity with Green's theorem and its applications
  • Knowledge of continuous partial derivatives
  • Proficiency in evaluating line and double integrals
  • Study the implications of Green's theorem in vector calculus
  • Learn about the properties of exact differentials and their applications
  • Explore the relationship between line integrals and conservative vector fields
  • Investigate the fundamental theorem of calculus for multiple variables
Mathematicians, students studying multivariable calculus, and anyone interested in the applications of differential forms and vector calculus.
e(ho0n3
[SOLVED] Proving a Fact About Exact Differentials
Problem. Let D be a disc and let P and Q be functions on D with continuous partial derivatives with respect to x and y. Let C be any closed curve in D.
Given the fact that
\int_C (P \, dx + Q \, dy) = 0 \leftrightarrow Q_x = P_y
show that P dx + Q dy is an exact differential. (Hint: Let (a, b) be any point in D and set
g(x, y) = \int_a^b P(t, b) \, dt + \int_b^y Q(a, s) \, ds
Show that g is the desired function.
Attempt. P dx + Q dy is an exact differential if there is a function g(x, y) with g_x = P and g_y = Q. So if I take the partial derivative with respect to x of the function g defined in the hint, I should get P right?
Let p be the anti-derivative of P with respect to the first variable and let q be the anti-derivative of Q with respect to the second variable. Then by the fundamental theorem of calculus
g(x, y) = p(x, b) - p(a, b) + q(a, y) - q(a, b)
and so g_x(x, y) = p_x(x, b) = P(x, b)[/tex] right? The problem here is that there's a b instead of a y. I'm mostly likely doing something terrible wrong here because I haven't used the fact stated in the problem. Help!
Given the fact that
I assume this was supposed to be
g(x, y) = \int_a^x P(t, b) \, dt + \int_b^y Q(a, s) \, ds
<br /> If that &quot;b instead of an a&quot; is in the book and not your mistake, then it is a misprint in the book!
Right. Sorry for the typo. That is what screwed me up. It should be:
g(x, y) = \int_a^x P(t, b) \, dt + \int_b^y Q(x, s) \, ds
And so
g_x(x, y) = P_x(x, b) + \int_b^y Q_x(x, s) \, ds
I apply the fact that Q_x = P_y and simplify to get that g_x(x,y) = P(x,y). Similarly, g_y(x,y) = Q(x,y) and thus P dx + Q dy is an exact differential.
One more problem: If Q_x = P_y, it is easy to show that the line integral of P dx + Q dy around any closed curve is 0 by applying Green's theorem. However, the converse does not seem to be necessarily true.
From Green's theorem,
\int_C (P \, dx + Q \, dy) = \iint_R (Q_x - P_y) \, dx dy
Given that the above is 0, then
\iint_R Q_x \, dx dy = \iint_R P_y \, dx dy
This is as much as I can deduce. How is it possible to further deduce this into Q_x = P_y?
The problem of my previous two posts were discussed in class today. The prof. said that because the double integral is 0 for any region R, the function Q_x - P_y must be 0.
This sounds reasonable. I would like to examine this idea for the one-dimensional case. Let f(x) be a function continuous on a domain D. Now suppose for any interval (a,b) in D,
\int_a^b f(x) \, dx = 0
To prove that f(x) = 0, I have to show that for any x in D, f(x) = 0. Arguing by contradiction, suppose for some c, f(c) is not 0. Because f is continuous,
\lim_{x \to c} f(x) = f(c)
Thus, for any e > 0, there is a d > 0 such that for all x with c - d < x < c + d, f(c) - e < f(x) < f(c) + e. Therefore,
2d(f(c) - e) = \int_{c-d}^{c+d} f(c) - e \, dx &lt; \int_{c-d}^{c+d} f(x) \, dx &lt; \int_{c-d}^{c+d} f(c) + e \, dx = 2d(f(c) + e)
For e << f(c), if f(c) is positive, f(c) - e and f(c) + d are both positive and so the integral in the middle must be positive. If f(c) is negative, then the middle integral is negative. This is a contradiction as that integral should be 0. Hence, for all values of x in D, f(x) = 0.
That's cool. Concerning the problem in the previous two posts, the region R enclosed by C may be described as the points (x, y) such that x is in the interval (a, b) and y is in the interval (c, d). In this manner,
\iint_R Q_x - P_y \, dxdy = \int_c^d \int_a^b Q_x(x, y) - P_y(x, y) \, dx dy = 0
This is true for every region R enclosed by a curve C in the domain D. Thus, the bounds of the outer integral range over the domain of x-values in D and the bounds of the inner integral range over the domain in y-values of D.
This implies that the inner integral must equal 0 and consequently, that Q_x - P_y = 0.
I think this explanation is sound. I will mark this thread as solved.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
