Proving AC · BP = 0 with orthogonality conditions
  • Thread starter Thread starter 53Mark53
    Proof Vector
18 replies · 3K views
53Mark53
let the point where the line through B and X intersects with AC be P
[/B]
I know that
ACdotBP = 0
AC = AD+DC
BP = PC+ CD
Therefore (AD+DC)dot(PC+CD)=0
I also know that:
ECdotCE = 0
BCdotDA=0
However I am stuck on showing that the dot product of ACdotBP is equal to 0
If anyone can help me it would be much appreciated
thanks
[/B]
I know that
ACdotBP = 0
AC = AD+DC
BP = PC+ CD
I also know that:
ECdotCE = 0
BCdotDA=0
thanks
How did you get BP = PC+ CD?
And isn't AC⋅BP = 0 what you have to prove?
thanks[/QUOTE]
Sorry that should say BP=BC+CP
And yes I am trying to prove AC⋅BP = 0
I am just unsure on the way that I should go about it
You know that AX⋅BC=0, CX⋅BA=0.
What you could do is pick an origin O (that could be any point, doesn't really matter), and express the vectors in terms of this origin.
For example: AX = OX - OA, BC = OC - OB, and similarly for the other vectors.
Now express AX⋅BC=0, CX⋅BA=0 in these terms, and compare the two expressions that you get.
Notice that you have to prove that BX⋅CA = 0.
When I substitute AX = OX - OA, BC = OC - OB and BA = BO+OA, CX=CA+AB
I get (OX-OA)⋅(OC-OB)=0 and (CA+AE)⋅(BO+OA)=0
What would I do from here would I have to rearrange the equations?
Actually, when you rewrite AX⋅BC=0 and CX⋅BA=0 in terms of vectors originating in O, what you get is:
AX⋅BC=0 indeed becomes (OX-OA)⋅(OC-OB)=0
But CX⋅BA=0 becomes (OX-OC)⋅(OA-OB)=0.
Now use the distributive property of the dot product to compute these two expressions.
Write the results one under the other and look at them for a moment. Combining them in the correct way will lead to the hoped for result.
I am not sure if this is the distributive property of the dot product but this is what I got:
OXOC+OAOB=0
OXOA+OCOB=0
How would i got about combining these?
OXOC+OAOB=0
OXOA+OCOB=0
The distributive property of the dot product is:
(a + b)⋅c = a⋅c + b⋅c (where a,b and c are vectors).
From this it follows, for example, that (a + b)⋅(c + d) = a⋅c + b⋅c + a⋅d + b⋅d,
or (a - b)⋅(c - d) = a⋅c - b⋅c - a⋅d + b⋅d (where a,b c and d are vectors).
Apply this correctly to:
(OX-OA)⋅(OC-OB)=0
(OX-OC)⋅(OA-OB)=0
(OX-OA)⋅(OC-OB)=0
(OX-OC)⋅(OA-OB)=0
(OX-OA)⋅(OC-OB)=OX⋅OC-OA⋅OC-OX⋅OB+OA⋅OB
(OX-OC)⋅(OA-OB)=OX⋅OA-OC⋅OA-OX⋅OB+OC⋅OB
How would I combine this now?
You left out that both expressions are 0.
Did you notice that two terms appear in both expressions? That should give you a clue about the next step: how to combine the two expressions.Remember that the final goal is to prove that BX⋅CA = 0.
(OX-OA)⋅(OC-OB)=OX⋅OC-OA⋅OC-OX⋅OB+OA⋅OB=0
(OX-OC)⋅(OA-OB)=OX⋅OA-OC⋅OA-OX⋅OB+OC⋅OB=0
OX⋅OA-OC⋅OA-OX⋅OB+OC⋅OB=OX⋅OC-OA⋅OC-OX⋅OB+OA⋅OB
OX⋅OA+OC⋅OB=OX⋅OC+OA⋅OB
now how would I prove that BX⋅CA = 0?
The distributive property of the dot product is still valid.
Two terms contain OX, two terms contain OB ...
OX⋅OA-OX⋅OC=OA⋅OB+OC⋅OB
OX(OA-OC)=(OA+OC)OB
How would I prove it now?
OX(OA-OC)=(OA+OC)OB
You have a sign error: what you should get is OX⋅OA-OX⋅OC=OA⋅OB-OC⋅OB
Now, look back at post #4: for any vector YZ, YZ = OZ - OY.
BX⋅CA=0
BX=OX-OB
CA=OA-OC
(OX-OB)⋅(OA-OC) = 0
OX⋅OA-OC⋅OX-OB⋅OA+OB⋅OC=0
Therefore: OX⋅OA=OA⋅OB-OC⋅OB+OX⋅OC
OA⋅OB-OC⋅OB+OX⋅OC-OC⋅OX-OB⋅OA+OB⋅OC=0
0=0
Is this now correct?
Thanks
53Mark53 said:
BX⋅CA=0
BX=OX-OB
CA=OA-OC
(OX-OB)⋅(OA-OC) = 0
0=0
Thanks
I'm not sure I follow the logic here. BX⋅CA = 0 is what you have to prove.
You had OX⋅OA - OX⋅OC = OA⋅OB - OC⋅OB.
That can be written as OX⋅(OA-OC) = OB⋅(OA - OC)
That becomes OX⋅CA = OB⋅CA.
(All these steps actually appear in your previous post.)
From that you easily get the value of BX⋅CA.
OX⋅CA-OB⋅CA. =0
(OX-OB)⋅CA=0
BX=(OX-OB)
therefore
BX⋅CA=0
53Mark53 said:
OX⋅CA-OB⋅CA. =0
(OX-OB)⋅CA=0
BX=(OX-OB)
therefore
BX⋅CA=0
Yes.
Samy_A said:
Yes.
Thanks for your help I really appreciate it!
