Proving Convexity of Bounded Function F
  • Thread starter Thread starter talolard
    Bounded Function
4 replies · 3K views
talolard
Hey, the original question is not in english, so I am translating. So just to make sure I'm understood, i take convex to mean that the graph of the function is below the tangent.
The question:
Let F be a convex function and F is bounded from above by some number C, prove that F is static (again, my translation, by static I mean that for every x F(X)=a)
I don't think I'm close, but I am stumped, some mild hin tto point me in the right direction would be great.
we will write F as a taylor expansion:
[tex]f(x_0)+f'(x_0)(x-x_0) > f(x_0)+f'(x_0)(x-x_0) + \frac {f''(c)(x-x_0)^2}{2} <a \iff[/tex]
[tex] 0 > \frac {f''(c)(x-x_0)^2}{2} <a - f(x_0)+f'(x_0)(x-x_0) \iff[/tex]
[tex] 0 >\frac {f''(c)}{2} < \frac {a}{(x-x_0)^2} - \frac {f(x_0)+f'(x_0)}{x-x_0}[/tex]
I don't think Taylor's theorem is required here. The other flaw with your approach is that you are assuming some value for a beforehand in trying to show the function is constant. I think a better approach is to show that f(x) = f(y) for every real x,y.
I think it's a lot easier if you consider two points x and y and suppose x < y. If f(y) > f(x), what can you say about the behavior of f as x approaches infinity? Similarly, what if f(y) < f(x)? Remember in working with these two cases, you are trying to obtain a contradiction if your goal is to show the function is constant. But there is really only one statement in the hypothesis you can directly contradict.
The definition I learned of convex is that the graph lies above the tangent. I don't think the problem works with your definition: for example, f(x)=-x2 is bounded above by 0, and lies below its tangent.
The function doesn't need to be strictly convex.
Ok, it took me a few days to work this over and I'm still not there. Here's what I have so far:
Since F is convex then every point has one sided deriviatives such that
[tex]x>y f_{-}'(y) \leq f_{+}'(y) \leq f_{-}'(x) \leq f_{+}'(x)[/tex]
which means that the function is monotonic increasing.
let x>y then [tex]lim_{x-> \infty} f(x) = c[/tex] because the function is monotonic increasing and bounded from above. But this means that
[tex]lim_{x-> \infty} \frac {f(x) -f(y)}{x-y}= lim_{x-> \infty} \frac {c -f(y)}{x-y} =0[/tex] Which means that there exists a point y<"a"<x where [tex]f'(a)=0[/tex] but this means that for any x<a [tex]f'(x)=0[/tex]
Now take y>x>a. Then [tex]lim_{x-> \infty} f(x) = c and f(y)=c[/tex] so for all x after a certain point [tex]f'(x)=0[/tex] then all points before that point must also have [tex]f'(x)=0[/tex] because of the monotonity of f. Then f is constant.
Is that correct?
Thanks
