Proving inequality properties with case analysis
  • Thread starter Thread starter Kernul
    Inequality
10 replies · 3K views
Kernul
Prove the following facts about inequalities. [In each problem you will have to consider several
cases separately, e.g. ##a > 0## and ##a = 0##.]
(a) If ##a \leq b##, then ##a + c \leq b + c##.
(b) If ##a \geq b##, then ##a + c \geq b + c##.
(c) If ##a \leq b## and ##c \geq 0##, then ##ac \leq bc##.
(d) If ##a \leq b## and ##c \leq 0##, then ##ac \geq bc##.
So, I've tried to prove the first one (the second is basically the first one but with inequalities inverted) the following way:
If ##a > 0, b > 0## or ##a < 0, b < 0## (do I really have to say that ##b> 0## too?)
##a \leq b \implies a + c \leq b + c##
##a + (c + (-c)) \leq b + (c + (-c))##
##(a + c) + (-c) \leq (b + c) + (-c)##
If ##a = 0, b > 0##
##0 \leq b \implies c \leq b + c##
##(c + (-c)) \leq b + (c + (-c))##
##c + (-c) \leq (b + c) + (-c)##
##c \leq b + c##
So it's proved, right?
Now, going to (c), we have this ##c \geq 0## that stops me from using ##c^{-1}## to prove them because it's not ##c > 0##.
Which other way can I prove the last two?
EDIT: Sorry, I didn't notice the inequalities were wrong.
(a) If ##a <= b##, then ##a + c <= b + c##.
(b) If ##a >= b##, then ##a + c >= b + c##.
(c) If ##a <= b## and ##c >= 0##, then ##ac <= bc##.
(d) If ##a <= b## and ##c <= 0##, then ##ac >= bc##.
##a <= b \implies a + c <= b + c##
##a + (c + (-c)) <= b + (c + (-c))##
##(a + c) + (-c) <= (b + c) + (-c)##
##a + c <= b + c##
If ##a = 0, b > 0##
##0 <= b \implies c <= b + c##
##(c + (-c)) <= b + (c + (-c))##
##c + (-c) <= (b + c) + (-c)##
##c <= b + c##
Now, going to (c), we have this ##c >= 0## that stops me from using ##c^{-1}## to prove them because it's not ##c > 0##.
Looking at several cases for each part is a waste of time; in every part there is no need at all for "cases". Just use an appropriate definition of "≤" or "≥".
An appropriate definition of ##\leq## and ##\geq##? Wouldn't that be:
##a \leq b## means ##a < b## or ## a = b##
##a \geq b## means ##a > b## or ## a = b##
What does ##a < b## mean? What is a very simple way to test if ##a < b##?
Anyway, I did not claim that what you are doing is wrong; I am just saying it is not the fastest way.
To deal with your original question: in your argument you started with ##a \leq b##, then got ##(a+c) + (-c) \leq (b+c) + (-c)##, then canceled the "##(-c)##' on both sides to end up with ##a+c \leq b+c##. However, that last step is invalid: it basically assumes what you are trying to prove, because if you set ##A = a+c## and ##B = b+c## you are going from ##A -c \leq B-c ## to ##A \leq B##---but you have not proved that yet.
##a < b## means that ##a## is a number smaller than ##b##.
To see if ##b - a## is still a positive number? If it's negative it means that actually ##a > b##.
Now you are getting it (in your second sentence above).
Oh right. I can't think of any way to proceed from that part right now.
So I should simply see if ##(b + c) - (a + c) > 0##?
Kernul said:
Oh right. I can't think of any way to proceed from that part right now.So I should simply see if ##(b + c) - (a + c) > 0##?
That is the way I would do it (although I would use "##\geq##" instead of "##>##").
Oh yes.
Doing like that I would end up with ##b + c - a - c \geq 0## and so ##b - a \geq 0##. But does this really prove what I was trying to prove? Isn't this the opposite way since I started directly with ##a + c \leq b + c##, which was what I had to end up while proving?
Kernul said:
Oh yes.
No: you assume ##a \leq b##, which means that ##b-a \geq 0##. However, ##(b+c) - (a+c) = b-a,## so we have ##(b+c) -(a+c) \geq 0##, which means (by definition) that ##b+c \geq a+c##. No circular arguments are involved; just elementary algebra.
Oh, now I get it.
Thank you very much.
