Proving Least Positive Residue Using m-Cycle Permutations
  • Thread starter Thread starter Bashyboy
    Positive Residue
5 replies · 2K views
Bashyboy
Prove that if ##\sigma## is the ##m##-cycle ##(a_1 ~ a_2 ... a_m)##, then for all ##i \in \{1,...,m\}##, ##\sigma^{i}(a_k) = a_{k+i}##, where ##k+i## is replaced by its least positive residue ##\mod m##.
My question is embarrassingly simple. What is the least positive residue? Would it be that number ##x \in \mathbb{Z}^+## for which ##x \equiv k+1 (\mod m)##?
It simply means the remainders in ##\{1, \ldots , m\}## which is necessary for the index ##i+k## to make sense.
E.g. You can write ##16 = 2 \cdot 7 + 2## or ##16 = 1 \cdot 7 + 9## or ##16 = 4 \cdot 7 - 12##. All these numbers ##2,9,-12## are possible remainders of a division by ##7##. However, we usually only consider the ##2## as the one we want to look at. And ##2## is the least positive one.
Okay, I hate to revive this thread, but I haven't been able to look at the problem for some time. I am still having trouble with this least positive residue business. What happens if ##k+1## is a multiple of ##m##? Wouldn't the remainder be zero, which is a not a positive number? Don't we need to prove that ##k+1## divided by ##m## has a least positive residue in ##\{1,...,m\}##? I am not even sure I worded that last sentence correctly. I am trying to see the connection between the remainder you get from the division algorithm and the one the problem demands (i.e., the remainder in ##\{1,...,m\}##).
If ##k+1## is a multiple of ##m##, then the least positive residue is ##m## for the reason you noted, i.e., 0 is not a positive number.
Okay, I think I am starting to see now. Perhaps someone could help me with proving the theorem now. We will prove the theorem by induction. When ##i=1##, we have the formula says ##\sigma^1(a_k) = a_{k+1}##. Now, either ##k+1 \in \{1,...,m\}## or ##k+1 = m+1##. In in first case, we have ##k+1 = m \cdot 0 + k+1## and therefore the least positive residue is ##k+1##, implying ##\sigma^1 (a_k)=a_{k+1}##. In the second case, the least positive residue is ##1## and ##k=m##, so that ##\sigma^1(a_k) = \sigma(a_m) = a_1##. In either case, however, the formula agrees with how ##\sigma## is defined to map the elements ##\{a_1,...,a_m\}##.
I feel that the above is correct, but it could perhaps be stated more precisely, especially the line ##\sigma^1(a_k) = \sigma(a_m) = a_1##.
Now I am trying to work on induction, but I am having a little trouble. Suppose that ##\sigma^i(a_k)= a_{r}##, where ##r## is the least positive residue, holds for some ##i## (which ##i##? How many?). Then ##\sigma^{i+1}(a_k) = \sigma (\sigma^i(a_k))##. Since this holds for ##i##, ##\sigma^i(a_k) = a_r##. I am having trouble seeing what ##\sigma## does to ##a_r##; i.e., what does ##\sigma (a_r)## equal?
I feel that the above is correct, ...
Yes.
... but it could perhaps be stated more precisely, especially the line ##\sigma^1(a_k) = \sigma(a_m) = a_1##.
To me, it's fine.
It holds for all numbers from ##1## to ##i##. We simply pretend as if we had checked them all. And from that, we show, that it has to be also true for the next one, that is ##i+1##.
Correct.
Now you get a little bit lost. What you have (by induction hypothesis) is ##\sigma^{i+1}(a_k) = \sigma (\sigma^i(a_k)) = \sigma (a_r) = \sigma^1 (a_r)##. You just have written it (in the line above my "correct"). But you know more about ##r##. You constructed it with ##i## by doing ##i## additions ##+1## and reduced every of the ##i## results modulo ##m##, step by step from ##1## until ##i##. So is this the same as reducing the entire ##r=k+i## in one step instead? From here on, simply apply the same argument to ##a_r## as you did in the induction base for ##a_k##.
