Proving (n²+1)/(n+3) → +∞ using epsilon-N definition
  • Thread starter Thread starter squareroot
    Limit
14 replies · 3K views · last reply
squareroot
Prove the limit by using the ε criteria
[itex]\stackrel{lim}{n→∞}[/itex][itex]\frac{n^2+1}{n+3}[/itex] = +∞
Hi guys.So I'm having trouble proving this limits(all limits that i need to prove that they equal +/- ∞) , all that I've learned in calculus so far at school is these e proprieties
limit when x→∞ from xn=L ⇔ [itex]\forall[/itex]ε>0 [itex]\exists[/itex]nε so that for [itex]\forall[/itex] n≥nε we have |xn-L|<ε
the second one is when limit whenx→∞ from xn= +∞ it's the same except the last part where you don't have |xn-L|<ε but we have xn≥ε
fot the third one limit when x→∞ from xn= -∞ when xn≤-ε
TY!
TY!
You're not using the correct form for this type of limit. This is the one you want.
$$ \forall M, \exists N \text{ such that } n \ge N \Rightarrow f(n) > M$$
The idea here is that M and N are large numbers. You don't use ##\epsilon## in this type of limit proof.
well what you said is the same with what i said "the second one is when limit whenx→∞ from xn= +∞ it's the same except the last part where you don't have |xn-L|<ε but we have xn≥ε
Which means that it isn't the same. Also, ##\epsilon## is generally considered to be a small number (close to 0).
Well yes but i tried solving it like that and i get lost in all that math , i have a polynominal equation in n...can't you show me?
The way PF works is that we help you, but we don't do your work for you. The polynomial is a quadratic, and you should already know how to solve quadratic equations and inequalities. Show us where you got stuck.
Ok here we go , so starting backwards from the theorem we have (n2+1)/(n+3)≥ε after solving this and by arranging it you have
n2-nε+(1-3ε)≥0
from here
Δ=ε2-4(1-3ε)=ε2+12ε-4
so it from here where i m not certain what to do i tried to put the condition that Δ≥0 but by solving that i get really ugly results.I don't know what to do from here!
You want :
[itex]\forall M > 0, \exists N > 0 \space | \space n>N \Rightarrow a_n > M[/itex]
So start by massaging what you want into a suitable form :
[itex]\frac{n^2 + 1}{n + 3} > M[/itex]
You should not use ε for this type of limit, as it is almost universally used to represent numbers that are close to 0.
From the inequality $$\frac{n^2+1}{n + 3} > M$$
you get
##n^2 - Mn + 1 - 3M > 0##
The values of n that make the expression above equal to 0 are
$$n = \frac{M \pm \sqrt{M^2 + 12M - 4}}{2}$$
It is not necessary to get an exact value for n. All that is needed is to find a value that is large enough. ##\sqrt{M^2 + 12M - 4}## ≈ M, but the square root expression is always a little larger. I think we can say that the radical is smaller than 2M as long as M is not too small. For example, if M = 10 (which isn't very large), ##\sqrt{M^2 + 12M - 4}=\sqrt{216}≈11 < 20 = 2M##. For any larger value of M the radical will be smaller than 2M.
Can you carry on from here?
Not really , the thing is i don't really have a solid understanding about what am I after to prove here.So we've proved that that radical will be smaller than 2M when M is a large number, but hor does that help me with my initial inequation ?I'm sorry i know I'm pretty much asking to solveit step by step to me , but it 's my first kind of this exercise from my first calculus homework ever , and i really want to have a solid foundation on calculus.
You can make life a lot easier by simplifying the problem first. [itex]\frac{n^2 + 1}{n + 3} > \frac{n^2}{n + 3} > \frac{n^2}{n + n}[/itex] (for n>3). Simplifying the last expression and showing its limit is infinity shows the first one has that limit as well.
Oh!I get it now! And it's obvious that n2/2n's limit is +∞ so from that i can conclude that the limit of my equation is also +∞.This is very very useful , and i can use it to solve all my exercises of this type.Thanks a lot! But is it a valid method? Seems more of an observation than a demonstration to me :smile:
For example here is how i could solve another exercise which looks similar
Prove that limn→∞[itex]\frac{n<sup>3</sup>+2n}{n<sup>2</sup>+3n-1}[/itex]=+∞
So [itex]\frac{n<sup>3</sup>+2n}{n<sup>2</sup>+3n-1}[/itex] < [itex]\frac{n<sup>3</sup>+2n}{n<sup>2</sup>+3n}[/itex]
But [itex]\frac{n<sup>3</sup>+2n}{n<sup>2</sup>+3n}[/itex]=[itex]\frac{n(n<sup>2</sup>)+2}{n(n+3)}[/itex]=[itex]\frac{n<sup>2</sup>+2}{n+3}[/itex], now here 2 and 3 are pretty irrelevant when n→∞ so we could say [itex]\frac{n<sup>2</sup>}{n}[/itex]=n
limn→∞ n=+∞, that is obvious so from this i proved that limn→∞[itex]\frac{n<sup>3</sup>+2n}{n<sup>2</sup>+3n-1}[/itex]=+∞
What do you say?Is it ok?
P.S idk why the eq editor didn't work!
You can make it into a real proof. If n^2/(2n)>M then (n^2+1)/(n+3)>M. You can use the same bound for the simpler expession for the more complicated.
Do not use [NOPARSE][/NOPARSE] and [itеx][/itеx] together, if you want to write supscripts, then please write
Code:
[NOPARSE][itex]n^3+2n[/itex][/NOPARSE]
Also, limits can be written nicely as
Code:
[NOPARSE]
[itex]\lim_{n\rightarrow +\infty} n^2[/itex]
[/NOPARSE]
Here is a LaTeX guide:
https://www.physicsforums.com/showpost.php?p=3977517&postcount=3
