Proving this series converges or diverges
  • Thread starter Thread starter bonfire09
    Series
26 replies · 4K views
bonfire09
Prove [itex]y_n=\frac{1}{n+1}+\frac{1}{n+2}+...+\frac{1}{2n}[/itex] where [itex]n\in\mathbb{N}[/itex] is convergent or divergent.
I am stuck on this. I think its divergent but I am having trouble proving that it is divergent. I tried to break up the sequence using partial sums but I don't see a pattern. What I also don't get is what [itex]y_1[/itex] is equal too. Is it [itex]y_1=\frac{1}{1+1}+\frac{1}{1+2}+...+\frac{1}{2*1}[/itex] or is it equal to [itex]y_1=\frac{1}{1+1}[/itex]? I've been stuck for quite a while.
From what I understand, it looks like this:
$$y_n=\sum_{k=n+1}^{2n}\frac{1}{k}.$$
That help?
Yes but how would I go about proving it is divergent. I was thinking of using [itex]\frac{1}{n^2}+...+\frac{1}{n^2}[/itex] since [itex]\frac{1}{n+1}+...+\frac{1}{2n}>\frac{1}{n^2}+...+\frac{1}{n^2}[/itex]?{Edit*I don't think it works}. I was thinking of using [itex]\frac{1}{n+1}+...+\frac{1}{n+1}[/itex]. I don't think the way you wrote the series works. I think the limits have to be adjusted.
No, that doesn't work. Since the denominators are all "of order n", it would be better to compare the terms to 1/n (or your suggestion 1/(n+1)). For all i between 1 and n, [itex]1/(n+i)\ge 1/(2n)[/itex]
I...don't think so. Check again. I'm pretty sure my expression for the summation is correct.
I'd use a test of convergence. Are you familiar with any?
Well this what I get so far that [itex]\sum_{k=n+1}^{2n}\frac{1}{k}≥ \sum_{k=n+1}^{2n}\frac{1}{k+1}[/itex] Hence its divergent. I think it works since [itex]\sum_{k=n+1}^{2n}\frac{1}{k+1}=\frac{1}{(n+1)+1}+\frac{1}{(n+2)+1}+...+\frac{1}{2n+1}[/itex] ≤ [itex]\sum_{k=n+1}^{2n}\frac{1}{k}= \frac{1}{n+1}+\frac{1}{n+2}+...+\frac{1}{2n}[/itex]
This is a little bit subtle
$$\frac{1}{2}=\frac{n}{2n}<\sum_{k=1}^n \frac{1}{n+k}<\frac{n}{n+1}<1$$
hint:think log(n)
hint2:
if
$$H_n=\sum_{k=1}^n \frac{1}{k}$$
then
$$\sum_{k=1}^n \frac{1}{n+k}=H_{2n}-H_{n}$$
so is the way I have it not correct then?
Ok I will try other methods. I would think there would be a much simpler way of doing this because Bartle (book I am using) presents convergence and divergence of series before he introduces integration and differentiation.
Fair enough. You can also show a sequence converges if you can show it's monotone and bounded. Can you show ##y_{n+1}-y_{n}## is positive so it's monotone increasing and, as lurflurf indicated, bounded above?
So [itex]y_{n+1}= \frac{1}{n+2}+\frac{1}{n+3}+...+\frac{1}{2n+1}[/itex] and [itex]y_n=\frac{1}{n+1}+\frac{1}{n+2}+...+\frac{1}{2n}[/itex]. So [itex]y_{n+1}-y_n= \frac{-1}{n+1}+\frac{1}{2n+1}[/itex]. I think that is how it supposed to go.
Right idea, but the last term in ##y_{n+1}## is ##\frac{1}{2(n+1)}##, not ##\frac{1}{2n+1}##. Do it a little more carefully. It might be good to write out the n=1, n=2, n=3 cases explicitly, then do some differences and compare with what you think the answer is symbolically. That's what I do.
Oh yeah I forgot. [itex]y_{n+1}= \frac{1}{n+2}+\frac{1}{n+3}+...+\frac{1}{2n+5}[/itex] and [itex]y_n=\frac{1}{n+1}+\frac{1}{n+2}+...+\frac{1}{2n}[/itex] So [itex]y_{n+1}-y_n=\frac{-1}{n+1}+\frac{1}{2n+1}+\frac{1}{2n+2}[/itex] which seems to be decreasing that is [itex]y_{n+1}\leq y_n[/itex]
bonfire09 said:
Oh yeah I forgot. [itex]y_{n+1}= \frac{1}{n+2}+\frac{1}{n+3}+...+\frac{1}{2n+5}[/itex] and [itex]y_n=\frac{1}{n+1}+\frac{1}{n+2}+...+\frac{1}{2n}[/itex] So [itex]y_{n+1}-y_n=\frac{-1}{n+1}+\frac{1}{2n+1}+\frac{1}{2n+2}[/itex] which seems to be decreasing.
Ok, so why do you think [itex]\frac{-1}{n+1}+\frac{1}{2n+1}+\frac{1}{2n+2}[/itex] is negative? I don't. Just realized 2n+5 has got to be a typo, since your difference is correct.
Oh yes its increasing. Now once I show that [itex]\frac{-1}{n+1} \leq \frac{1}{2n+1}+\frac{1}{2n+2}[/itex]. Now I think I'm going to have to use a epsilon proof to show [itex]y_n[/itex] its convergent which I need some help with.
bonfire09 said:
Oh yes its increasing. Now once I show that [itex]\frac{-1}{n+1} \leq \frac{1}{2n+1}+\frac{1}{2n+2}[/itex]. Now I think I'm going to have to use a epsilon proof to show its convergent.
That's a little garbled too. My whole point is that there is likely a theorem in Bartle that if a sequence is monotone increasing and bounded above, then it converges. Use the theorem. No need for epsilons if you've got the theorem.
It says 3.3.2 Monotone Convergence Theorem A monotone, sequence of real numbers is
convergent if and only if it is bounded. Further: (a) If X = (xn) is a bounded increasing sequence, then [itex]lim(x_n) = sup\{x_n : n ε N\}[/itex]. I some how have to show [itex]y_n[/itex] is bounded and all I know its increasing so it is monotone.
lurflurf already hinted you that it's bounded. You are summing n numbers and they are all less than 1/n, so? Doesn't that mean it's bounded? Are you clear on the monotone bit? Why is ##\frac{-1}{n+1}+\frac{1}{2n+1}+\frac{1}{2n+2}## positive?
Well [itex]\frac{-1}{n+1}<\frac{1}{2n+1}+\frac{1}{2n+2}[/itex] since if we start from [itex]\frac{-3}{n+1}<\frac{2}{2n+1}=\frac{-2}{n+1}<\frac{2}{2n+1}+\frac{1}{n+1}=\frac{-2}{n+1}<\frac{2}{2n+1}+\frac{2}{2n+2}=\frac{-1}{n+1}<\frac{1}{2n+1}+\frac{1}{2n+2}[/itex] Thus its positive. Oh yeah I saw the hint. Since its bounded and monotone its convergent by the monotone convergent theorem.
##\frac{-1}{n+1}<\frac{1}{2n+1}+\frac{1}{2n+2}## is certainly true. But that's useless. You want to prove ##\frac{-1}{n+1}+\frac{1}{2n+1}+\frac{1}{2n+2} \gt 0##. That's completely different. Do the algebra and combine the fractions.
Well [itex]\frac{1}{n+1}<\frac{1}{2n+1}+\frac{1}{2n+2}[/itex] since if we start from [itex]\frac{1}{2n+2}<\frac{1}{n+1}=\frac{2}{2n+2}<\frac{1}{2n+1}+\frac{1}{2n+2}→\frac{1}{2n+1}+\frac{1}{2n+2}-\frac{1}{n+1}>0[/itex] Thus its positive. Oh yeah I saw the hint. Since its bounded and monotone its convergent by the monotone convergent theorem.
Ok, I find that a little hard to follow, but it's probably ok. Yes, ##y_n## is increasing and bounded above. So it converges.
Thanks so much. I think I am going to practice on other series and sequences until I get a good hang of it. I don't think its that bad now.
Just a note, the value the sequence converges to can be found this way:
[tex]\lim_{n\to\infty} \sum_{k=0}^{2n} \frac{1}{k} - \sum_{k=0}^{n} \frac{1}{k}<br /> = \lim_{n\to\infty} \sum_{k=0}^{2n} \frac{1}{k} - \log(2n) - \sum_{k=0}^{n} \frac{1}{k} + \log(n) + \log(2)<br /> = \gamma - \gamma + \log(2) = \log(2)[/tex]
Yeah, that's what lurflurf was pointing out. I think it's more elementary to approach it as a Riemann sum as in post 10.
