Proving V1 is Not a Vector Space
10 replies · 3K views · last reply
hms.tech
V1 is defined as the span of the vectors b1,b2,b3,b4
Prove that V1 is not a vector space.
A set of axioms :
If u and v are tow vectors in the span of b1,b2,b3,b4 then:
1. u + v belongs to V1
2. ku also belongs to V1
Don't know how to prove 1. wrong !
  • Four column vectors labeled b1 through b4 in 4-dimensional form: b1 = (1,0,0,0), b2 = (1,1,0,0), b3 = (1,1,1,0), b4 = (1,1,1,1).
hi hms.tech! :smile:
i'm confused :redface: …
i thought span is defined as the smallest vector subspace that (etc) :confused:
what definition of span have you been given?​
To prove that [itex]V_1[/itex] is a vector space, the two closure axioms must be satisfied, as stated in your relevant equations.
[tex]V_1= \left ( b_1,b_2,b_3,b_4 \right )[/tex]
[tex]V_1= \left ( \begin{bmatrix}1 \\ 0 \\ 0\\0 \end{bmatrix}, \begin{bmatrix}1 \\ 1 \\ 0\\0 \end{bmatrix},\begin{bmatrix}1 \\ 1 \\1\\0 \end{bmatrix},\begin{bmatrix}1 \\ 1 \\ 1\\1 \end{bmatrix} \right )[/tex]
According to the two properties:
[tex]1.\;b_1+b_2\not=b_3<br /> \\2.\;k\times b_1\not=b_2[/tex]Also, if you write the 4 vectors as a matrix and reduce to its row echelon form, you will see that it has no free variables, meaning, all the 4 vectors are linearly independent.
I think i might have to rephrase the question. Becuase i think i interpreted it wrongly.
so again :
Here is the complete question :
  • Textbook excerpt defining vectors b1 = (1,0,0,0), b2 = (1,1,0,0), b3 = (1,1,1,0), b4 = (1,1,1,1) as column vectors, followed by the question (i) Give a reason why V1 ∪ V2 is not a linear space.
so again :
That's a completely different question from your post #1.[tex]V_1= \left ( \begin{bmatrix}1 \\ 0 \\ 0\\0 \end{bmatrix}, \begin{bmatrix}1 \\ 1 \\ 0\\0 \end{bmatrix},\begin{bmatrix}1 \\ 1 \\ 1\\0 \end{bmatrix} \right )= \begin{bmatrix}1 & 1 & 1 \\ 0 & 1 & 1 \\ 0 & 0 & 1\\ 0 & 0 & 0 \end{bmatrix}[/tex]
[tex]V_2= \left ( \begin{bmatrix}1 \\ 0 \\ 0\\0 \end{bmatrix}, \begin{bmatrix}1 \\ 1 \\ 0\\0 \end{bmatrix},\begin{bmatrix}1 \\ 1 \\ 1\\1 \end{bmatrix} \right )= \begin{bmatrix}1 & 1 & 1 \\ 0 & 1 & 1 \\ 0 & 0 & 1\\ 0 & 0 & 1 \end{bmatrix}[/tex]Note: vector spaces are sometimes called linear spaces.
yes, i know that vector space is the same thing as a linear space, but again, how to we prove that V1 union V2 is not a vector space ?
[tex]V_1+V_2\not=kV_1\;or\;V_1+V_2\not=kV_2[/tex]where k is a scalar multiple.
what axiom is that, i can't recall any such axiom of a vector space ?
[itex]V_1\cup V_2[/itex] is the sum of all corresponding elements of [itex]V_1[/itex] and [itex]V_2[/itex]. Therefore, it is [itex]V_1 + V_2[/itex].
The result of the vector addition, let's call it, [itex]V_3[/itex], is to be tested against the closure axioms to verify if it is a vector space of either [itex]V_1[/itex] or [itex]V_2[/itex].
Now, according to the closure axiom of scalar multiplication, if [itex]V_3[/itex] is a scalar multiple of [itex]V_1[/itex] or [itex]V_2[/itex], then the former is a vector space. You can get the answer easily from here.
the simplest way is to find a in V1 and b in V2 such that a+b is not in V1 and is not in V2 :wink:
(and the simplest choices for a and b would be one 1 and three 0s)
yeah i got it, thanks for the explanation. I took the vectors b3 and b4, added them together and proved that the resultant vector does not lie in v3.
