Proving weight symmetry and sum in Newton-Cotes formulas
  • Topic:
  • Thread starter Thread starter akerman
    Formula
7 replies · 3K views
akerman
I have been given this question and I have no idea how to answer it. I know that the answer will contain two small proofs where one of them uses quadrature formulae.
So I have been ask to show Show it holds that $\omega_j=\omega_{n-j}$ and that $\sum_j{\omega_j}=(b-a)$. Knowing that Newton cotes formulae is in the equi spaced points $x_i=a+ih$ with $h=(b-a)/n$ and $i=0,\dots,n$
Any idea how to properly solve this?
First proof should consider odd functions in the interval from -1 to 1, and I would like to show that ωj=ωn−j The second one should consider the quadrature formulae (constant funciton 1) based on that I would like to prove ∑jωj=(b−a) where ω is the weights. However I don't know how...
I haven't answered before because I don't quite know what to make of your question.
Which formulae do you mean?
What do you mean by $\omega_j$?
So in this context ωj are weights, actually I think its called a quadrature weight. So I would like to show that for corresponding weights it is true or it holds that ωj = ωj-1. I am sure for this proof odd functions need to be considered in the interval of -1 to 1. Does that explain it any better?
We interpolate $f$ using a Lagrange interpolation polynomial of the form
p_n(x)=\sum_{k=0}^nL_k(x)f(x_k).
We obtain
\int_a^bf(x)dx\approx \int_a^b\sum_{k=0}^nL_k(x)f(x_k)=\sum_{k=0}^nf(x_k)\int_a^bL_k(x)dx:=\sum_{k=0}^nf(x_k)\omega_k,
where the $\omega_k:=\int_a^bL_k(x)dx$ are called integration weights.
So based on that I would like to prove that $ω_j=ω_{n−j}$ and the second proof should be proving that $\sum\limits_j ω_j=(b−a)$.
I like Serena do you know how it can be achieved?
We obtain
The Lagrange polynomials $L_k(x)$ are completely independent of $f(x)$.
Since the interval has been split in equal subintervals, the construction of $L_k(x)$ is completely symmetric.
Therefore $L_k(x) = L_{n-k}(x)$, which in turn implies that $ω_j=ω_{n−j}$.
OK that makes sense.
What about the second proof which is ∑jωj=(b−a). I need to prove it considering the quadrature formulae (constant function 1)
If we fill in $f(x)=1$, we get in the left hand side:
$$\int_a^b 1\ dx = b-a$$
and on the right hand side:
$$\sum_{k=0}^n 1 \cdot \omega_k = \sum_j \omega_j$$
In other words:
$$b-a \approx \sum_j \omega_j$$
Furthermore, with $f(x)=1$ the Lagrange interpolation is a perfect interpolation.
That is:
$$f(x) = p_n(x)$$
So the approximation will actually be an equality.
So:
$$b-a = \sum_j \omega_j$$
which concludes the proof.
