Proving wx = wy from x = y using field axioms
5 replies · 3K views
Tomp
Using only the fi eld axioms, prove that if x,y ε R and x = y then wx = wy.
http://mathworld.wolfram.com/FieldAxioms.html
The solution to this can be solved within 2 lines or so using the field axiom inverses/multiplications ,however, this is one of a couple of assignment questions and it seems a little too easy? Am I thinking about this question correctly?
It's a very easy problem - there is no "trick" to it. I just did this quickly to check it; I got it using distributivity and additive inverses.
Notice :
x = y ⇔ x - y = 0
So similarly :
wx = wy
wx - wy = 0
w(x-y) = 0
w0 = 0
So either w=0 or 0=0. I am pretty sure your question should require that w≠0 and then the rest should be obvious.
Zondrina said:
Im pretty sure your question should require that w≠0 and then the rest should be obvious.
Why should you require w≠0? It's still a true statement if you take any w real.
Zondrina said:
Notice :
x = y ⇔ x - y = 0
So similarly :
wx = wy
NO![/size]
The equation above is what the OP needs to show. You can't start off by assuming what you're trying to prove.
Zondrina said:
wx - wy = 0
w(x-y) = 0
w0 = 0
I don't think it can be proven from the field axioms. Rather, you need axioms for the equality operator. This is usually handled in logic courses.
For now, I think it is enough to say that: x and y are the same number, so wx and wy must be the same number as well.
For a more rigorous approach, you need mathematical logic.
