Pulling a Carpet: Min Force & Velocity of Centre of Mass
  • Thread starter Thread starter Titan97
    force momentum
The problem involves a long pliable carpet being pulled backwards with constant velocity, requiring the determination of the velocity of the center of mass of the moving part and the minimum force needed to pull it. The context is rooted in mechanics, particularly focusing on concepts of momentum and forces acting on a system.
  • Participants discuss the relationship between the movement of different parts of the carpet and the center of mass, questioning whether the carpet stretches due to varying velocities. There are inquiries about which velocity to use when calculating force and considerations regarding the application of conservation of energy.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the use of momentum change to calculate force, while others are questioning the assumptions made about the velocities involved.
There are uncertainties regarding the definitions of velocity and force in the context of the carpet's movement, as well as the implications of energy considerations and the behavior of the carpet during the pulling process.
Titan97
A long pliable carpet is laid on the floor. One end of the carpet is bent back and then pulled backwards with constant velocity ##v##. Find the velocity of centre of mass of the moving part and the minimum force required to pull the moving part.
##P=mv##
If the end of the carpet that is pulled backwards, moves a distance ##2x##, then the bent part will move a distance ##x## and after some calculations, I found that the midpoint shifted by a distance ##\frac{3x}{2}##.
  • If each part of the carpet is moving with different velocities, then won't the carpet stretch?
  • Also, for finding force, $$F=\frac{dM}{dt}v$$ Which ##v## should I use?
  • Finally, some points in the carpet will experience a jerk and suddenly acquire a velocity. So I can't use conservation of energy right?
The different parts of the carpet are not moving with different velocities - the centre of mass is a geometric location, not physically part of the carpet. The part of the carpet that corresponds to "the middle" keeps changing.
Newton's Law is for the force acting through the centre of mass.
You are adding energy to the carpet via whatever pulls on the carpet.
to calculate the force required you better use change in momentum
@Simon Bridge it's given in the solution to "observe that it's not P=mv_cm"
See dvrm reply post #3
That's is what I did. What is v?
the required force must be equal to rate of change of momentum -
write down the the equation and see whether you can calculate the force and velocity-
take a portion of the carpet moved by the action of force...
how you can calculate v - by energy considerations or impulse...
  • · Replies 27 ·
17K
  • · Replies 24 ·
