Python vector dot product with cos and sin elements
22 replies · 3K views
Arman777
Insights Author
Take as input from the user an integer N. We don't want the user to enter very large integers, so exit with an error message if N>20. You may assume that N is an integer (and not a real number) and also that it is positive. Make two vectors v1 and v2 using v1.append() and v2.append() to fill in these vectors in the following way:
  • nth element of v1 should be cos(pi*n/16)
  • nth element of v2 should be sin(pi*n/21)
Finally find the scalar product of the two vectors.
Here is my code
Python:
#!/usr/bin/python
N=int(input('Enter integer: '))
if N>20:
    print ('error')
    exit ()
elif N<20:
    v1=[]
    for n in range (1,N+1):
        import math
        x=math.cos(math.pi*n / 16)
        v1.append(x)
        print (v1)
Problem is it takes v1 for every n so its like v1=[x1] then v1=[x1,x2] v1=[x1,x2,x3] it prints all like this
But I just only want the last one. How can I choose it ?
Thanks
It's not clear to me what you're asking -- the "last one" of what?
First interpretation: you just want the last element of an array
use of the minus one index position gets the last element in your array / list.
Second interpretation: you want the final print stmt only
just move the print statement out of that for loop by 'de-indenting' it
Important point:
Your if statements are incorrect. As is they don't address the N=20 case (contra to problem directions). If you choose to do an "elif" you need to get the inequalities right -- just using an "else" statement is easier and less error prone here, I think.
For example İts like this for N=6 there's 6 v1 vector. but I only want the last one (I think that's the right way to solve the problem)
Not exactly.. umm I want only the last array then I ll do the same thing for v2 then I ll multiply those.
"Important point:
Your if statements are incorrect. As is they don't address the N=20 case (contra to problem directions). If you choose to do an "elif" you need to get the inequalities right -- just using an "else" statement is easier and less error prone here, I think."
I changed my equality..thanks for warning
Oh wait that's the answer I guess
I can't tell whether the real issue is understanding how to manipulate a list, or understanding how for loops work, or understanding how whitespace works in Python, or something else.
For avoidance of doubt, there is no "last array" here. The way to think about it is: your code only has one array (actually a list) that you are appending to, via a command called "append". There aren't multiple arrays here -- just one, that you're growing over time via the 'append' operation. After that for loop is done, you only have that 'fully grown' list.
If you 'de-indent' the print stmt, you won't be doing a print at every iteration of the for loop, and instead you'll just do a single print once you've completed the for loop (and only see the 'fully grown' list).
sometimes just playing around with this stuff, as well as some examples in books, can be quite helpful. Allen Downey has some nice books that he makes freely available via the publisher. E.g. you may enjoy "Think Python", here:
http://greenteapress.com/wp/think-python-2e/
I see your point..actually I also didnt fully understand what question asks us ? Since now I have a feeling that my approach is wrong to answer the question.
Okay could you just show me a way to sum the this A for every z
Code:
#!/usr/bin/python
if N>20:
    print ('error')
    exit ()
elif N<=20:
    v1=[]
        import math
        v1.append(x)
    v2=[]
    for y in range (1,N+1):
        k=math.sin(math.pi*y / 21)
        v2.append(k)
    for z in range (1,N):
        A=v1[z]*v2[z]
        h=sum(v1[z]*v2[z])
        print (h)
I am really stucked
last lines
suppose I have a vector ##\mathbf v## with ##m## entries in it and I want to get the sum. I can of course use a built-in function (which is preferable once you get comfortable with all of the basics), but I can also create a running sum.
Python:
running_sum = 0
for i in range(m):
    running_sum += v[i]
# for loop has terminated at this point
print(running_sum)
you should be able to translate this to your problem
Minor point: Integers are real numbers. They just don't happen to have a fractional part.
I've added some comments on your code. Look for the >> characters.
Code:
#!/usr/bin/python
if N>20:
    print ('error')
    exit ()
elif N<=20:                               ;; >> Or you could just use else:
    v1=[]
        import math                    ;; >> This is very inefficient. This import statement should be up at the top, not inside a loop
        v1.append(x)
    v2=[]
        v2.append(k)
    for z in range (1,N):               ;; >> Why range(1, N)? Your other loops have range(1, N+1)
        A=v1[z]*v2[z]
        h=sum(v1[z]*v2[z])            ;;>> See Stone Temple Python's hint on how to do this
        print (h)                     ;;>> Do you really want to print the sum in each loop iteration? You need to do this only once, after the loop finishes.
I am really stucked
For the record, there is no such word in English as "stucked."
Okay here my last work , please help me..
Python:
#!/usr/bin/python
if N>20:
    print ('error')
    exit ()
elif N<20:
      import math
      v1=[]
          v1.append(x)
          v2=[]
              v2.append(k)
              v=[]
      for z in range (0,N):
                  A=v1[z]*v2[z]
                  v.append(A)
                  running_sum = 0
      for i in range(0,N+1):
          running_sum += A[i]
          print(running_sum)
Arman777 said:
Okay I did it
What does this mean? Does it mean that you got your code to work?
Here's how I would do the problem.
For an input value of N, I fill in the first array as v1(0), v1(1), ..., v1(N - 1), and the same for the v2 array.
I removed some of the code you had that was inside a loop, moving it outside the loop so that it would run only once.
I also simplified your code by reusing variables instead of introducing new variable names.
I also added comments along the way to help the reader understant what I was doing. This is a good habit to get into,
and is probably one that your instructor wants you to use.
Finally, there was a bug in your code with "if N > 20:" and "elif N < 20:" Do you know what the bug is?
Python:
import math
if N>20:
    print ('error')
    exit ()
#elif N<20:                  ## What happens if you enter 20?
else:
      v1=[]
      # Fill array v1 with values of cos(pi * n/16)
      for n in range (0,N):
          v1.append(x)
      # After array is filled, print out its values
      print("v1: ", v1)
      v2=[]
      # Fill array v2 with values of sin(pi * n/21)
          x=math.sin(math.pi*n / 21)
          v2.append(x)
      print("v2: ", v2)
      running_sum = 0
      # Calculate dot product of arrays v1 and v2
          running_sum += v1[n] * v2[n]
      # Print the dot product value
      print(running_sum)
yep
why bug ?
Why print all the data ? If N=20 then I mean there would be 40 lines ?
Python:
#!/usr/bin/python
if N>20:
    print ('error')
    exit ()
elif N<=20:
      import math
      v1=[]
          v1.append(x)
          v2=[]
          v2.append(k)
          v=[]
          A=v1[z]*v2[z]
          v.append(A)
      sm = sum(v[0:N])
print(sm)
my code
Arman777 said:
why bug ?
In your previous code (post #11) you had
if N > 20:
<stuff>
elif N < 20:
<other stuff>
What happens if the user enters 20?
I added the first two print statements mostly as sanity checks, just to see if I was getting reasonable values in the two arrays.
No, you don't get 40 lines. I entered a value of 6, so both arrays were printed on one line. If you have larger values, you'll get longer lines that wrap, but you won't get 40 separate lines.
Your code:
Python:
          v1.append(x)
          v2=[]
          v2.append(k)
          v=[]
You could use "for n in range (0, N) for both loops. You don't need two separate loop control variables, and you can run your loops for n = 0, 1, 2, ..., N-1
You should NOT have v2 = [] as part of the first loop. In other words, this line should NOT be indented.
You should also NOT have v = [] as part of the 2nd loop.
In the second loop, you don't need a different variable k -- you can re-use x.
Finally, you don't need to have a third array v[], as this is a waste of computer memory. Instead, you can do this, which is pretty much what Stone Temple Python was saying:
Python:
Well I tried that but I couldn't do it
Is that changes anything ?
if N > 20:
<stuff>
elif N < 20:
<other stuff>
I see your point now. Well, you are right 20 gives me the error. I can make elif N<=21 or just else , I think both are same?
Okay, I changed that well, does it make difference? don't get me wrong I am really asking since I want to learn
I did a check to see that our codes give the same result or not and they don't I wonder why?
the upper one is mine and the lower is yours.
Cause my range starts from 1...
I have already send it like hours ago , but its nice to see my mistakes
Why did you start indexing at one in your ranges?
note: in python, you should basically never do
Python:
it should almost always be
Python:
 for y in range (N):
There are some special cases where you are doing a padding at index zero for an N+1 length array, but those are special cases and don't apply here.
A general comment: you are deep in the weeds on indexing and this is predictably causing problems. Things like using a specific (and wrong) elif statement, when in fact you should just be using an else statement.
And while Mark's comment that creating an extra array ##v## is wasteful is more to the point for this exercise, I wanted to point out that if you did need to create ##v## for some reason and wanted to sum all of the entries in ##v##, you should never use
Python:
sm = sum(v[0:N])
As this is setting you up for subtle indexing issues, and makes the reader strain to confirm what is being summed over
instead just use
Python:
sm = sum(v)
which is a built-in function that sums over everything -- you only use indexing to 'grab' some proper sub-portion of the whole array and then sum said the thing you 'grabbed'.
if you have any small projects similar to this that you're interested in, you'd be wise to do them now, even though the assignment is done. Just repeatedly doing coding projects day in and out and getting a little better each time, really adds up.
Arman777 said:
Well I tried that but I couldn't do it.
Look at the bottom of my code in post #13.
Arman777 said:
Is that changes anything ?.
Yes. You are essentially declaring your two arrays in each loop iteration. This is inefficient.
if N > 20:
<stuff>
elif N < 20:
<other stuff>
Arman777 said:
I see your point now. Well, you are right 20 gives me the error. I can make elif N<=21 or just else , I think both are same?.
No, "elif N <= 21:" is not the same.
In post #14 you had
if N > 20:
<do stuff>
elif N <= 20:
<do other stuff>
This is OK, but here's a nicer way to do things:
if N > 20:
<do stuff>
else:
<do other stuff>
If N is larger than 20, you want to bail out, otherwise continue on with your calculations.
Arman777 said:
Okay, I changed that well, does it make difference? don't get me wrong I am really asking since I want to learn.
That's good that you want to learn. My comments are intended to be constructive criticism, to help you understand your code better, and to write better code. Unlike C, C++, C#, Java, and many other languages, Python doesn't use braces { } to delimit blocks of code. Instead, Python uses indentation.
In Python, there's a difference between these two snippets.
1.
Python:
sum = 0
for i in range(0, 6)
    sum += i
    print(i)
2,
Python:
sum = 0
    sum += i
print(i)
In the first example, the print statement executes 6 times. In the second example, the print statement executes only once.
Arman777 said:
I did a check to see that our codes give the same result or not and they don't I wonder why?.
Because my indexes range from 0 through N - 1, and yours range from 1 through N -- that's why.
The problem statement didn't specify whether n should start from 0 or from 1. I think the intent was that it should start from 0, but you would have to ask your instructor which of these was intended.
No idea :)
Like what can I do, any examples? I started to like the coding..it takes time for me but its fun
Also, I 'll be more careful in ranges, thanks for the info also for the sum thing.
I understand now ..I couldn't think of it before or I didn't know it actually. (How to use it, even stonetemple said it...)
oh.I get it know thanks for that.
Yes, I also think it should start from zero.
I learned the general idea I guess. Thanks
Arman777 said:
No idea :)
Well, you may enjoy https://projecteuler.net/
The beginning problems are easy but it gets progressively more difficult. (Too many prime number problems in there overall for my tastes but there are a lot of other problems as well.)
One of my original interests in coding was probability related problems -- e.g. coding an option pricing model (don't do this if you don't already know option pricing) or solving/ estimating little probability puzzles -- e.g. the riddler at 538 has a lot of problems that are amenable to running a simulation https://fivethirtyeight.com/tag/the-riddler/
There's a lot of other stuff out there -- just find little projects or puzzles that have a somewhat simple but repetitive quantitative component -- computers are great for that kind of thing, provided you write correct code, of course
MIT has a great free sequence on edx.org, as well 6.001x I think is their intro to CS with python
I started to do first problem but I am stuck :)
should I post the problem here ?
edit:Okay, I solved it :) no need
edit 1: It seems a great site thanks for sharing.
Yes. Create a new thread for the problem in this forum as it's a new problem. Mark or I or another member, will likely be able to help.
(As always, try to use the HW template, show your first or second cut at attempting the problem, and so on.) A lot of this stuff really is iterative -- just keep on putting in the (thoughtful) time, and the problem will eventually yield to you.
