Questions about Normalized Eigenfunc, Probability & Hamiltonian
  • Thread starter Thread starter good_phy
good_phy
Hi. I have three question. First is form of normalized momentum egien function
Liboff said that of unbounded is \frac{1}{2\pi}exp[ikx] But Why should this
form be normalized eigen function of momentum in unbounded?
Second question is whether probability density is equall to particle density.
Deriving Continuity Equation of QM, Original form of Equation is \frac{\partial \rho}{\partial t} + \nabla\bullet J = 0
Replacing \rho to \Psi give probability current density.
But what does it means? My idea about this quantity is unclear. Please Give me a relavent
example!
Third question is How to construct Hamiltonian of many body problem.
Is it right that considering two particle with interaciton of V(x),where x is distance between
two particle, Hamiltonian of the system(not particle) is H = \frac{-\hbar^2}{2m}\frac{\partial}{\partial x_{1}} + \frac{-\hbar^2}{2m}\frac{\partial}{\partial x_{2}} + v(x)? How can i solve this form?
The first couple are easy and I'll comment quickly (do not have the time to answer all of them).
If you normalize a plane wave, you are actually using a Dirac-delta function definition.
http://en.wikipedia.org/wiki/Dirac_delta_function
Look part way down the page for Fourier definitions.
\Psi \Psi^{*} is the probability density the integral over all space is equated to \rho.
This is the basis of QM.
Hope this helped.
Thank you for your help I solved my first question. But How about second and third question? Anyone know about this well?
I can't imagine real meaning of the Probability current density!
  • · Replies 17 ·
  • · Replies 29 ·
  • · Replies 31 ·
