QFT & Entanglement: NRQT vs. PCT Transform
  • Context: Graduate
  • Thread starter Thread starter Nusc
    Entanglement Qft
The discussion centers on the differences between nonrelativistic quantum theory (NRQT) and quantum field theory (QFT) regarding the PCT (parity, charge conjugation, and time reversal) theorem, the collapse of the wave function, and their implications for entanglement and the EPR paradox. Participants explore theoretical implications, interpretations, and the measurement problem within quantum mechanics.
  • Some participants question why NRQT lacks PCT while QFT incorporates it, suggesting that the collapse of the wave function is not governed by the Lagrangian or Hamiltonian, thus making PCT irrelevant for collapse.
  • Others argue that both collapse and EPR are aspects of the measurement problem, which does not significantly differ between NRQT and QFT.
  • One participant states that charge conjugation cannot be defined in non-relativistic physics, which is essential for relativistic QFT, and highlights that the weak interaction violates discrete symmetries.
  • Several participants discuss the implications of entanglement and EPR, with some asserting that QFT accounts for strong correlations without violating relativistic causality, while others challenge the clarity of this assertion.
  • There are differing views on the necessity of discussing EPR in the context of this topic, with some asserting it is irrelevant and others emphasizing its importance in understanding entanglement.
  • Some participants express skepticism about the conclusions drawn regarding locality and nonlocality, suggesting that the nature of measurement results and their probabilistic interpretation is contentious.
  • The preparation procedure for entangled states is mentioned as a factor in understanding the origins of entanglement, with examples provided for specific cases.
Participants do not reach a consensus, as multiple competing views remain regarding the relevance of PCT, the nature of entanglement, and the implications of the measurement problem in NRQT versus QFT.
Participants note that the discussion involves complex interpretations of quantum mechanics, with unresolved questions about the nature of measurement, locality, and the implications of various quantum theories.
  • #61
Demystifier said:
Said someone who uses philosophical arguments himself. ;-)) SCNR.
In physics, "philosophy" means "a different philosophy than the one I believe".
  • #62
stevendaryl said:
Yeah, that's the possibility I referred to way back in
Yes, I know you got it right away; I was just replying to posts from you and Dr. Chinese and now I think the idea is more clear. I'm not sure what to believe — if you take your complete initial state and you trace out Erik's part, it seems like it leaves a mixed state of the two entangled states. I'm just curious, do you think this scenario needs some non-classical feature (besides the Bell test part), like retrocausality or "unitary collapse" ?
  • #63
This is how it is done.
From
High-fidelity entanglement swapping with fully independent sources
arXiv:0809.3991v3
I'm hoping that someone can explain how this works. From my understanding, a 50:50 meam splitter with a photon in each input will have both photons in one output IFF the photons are completely in phase. Otherwise they behave independently. The explanation in the paper uses coincidences between detectors at possibly empty outputs.
  • #64
If both photons have the same polarization they will end up in the same output of BS (because of HOM interference) and in the same output of PBS (because they have the same polarization). So all these you can throw out as there will be no detections in two separate detectors.
If both photons have different polarization they will be either in the same or different outputs of BS subject to phase difference between ##H_2/H_3## modes vs phase difference between ##V_2/V_3##. If phase difference between horizontal modes is the same as phase difference between vertical modes they will end up in the same port (I guess ... because one mode has it's phase flipped), and if relative phases differ by ##\pi## then in different ports. And because they have different polarization they end up in different ports of PBS. So they can detect both photons separately.
That way they single out two states:
##(|H_1 V_4\rangle + |V_1 H_4\rangle) \otimes (|H_2 V_3\rangle + |V_2 H_3\rangle)##
and
##(|H_1 V_4\rangle - |V_1 H_4\rangle) \otimes (|H_2 V_3\rangle - |V_2 H_3\rangle)##
  • #65
Thanks. The beam splitter equation does not include polarization. It is written in terms of photon creation and anihilation operators in the channels.
The HOM effect measures the relative phase - not polarization angle.
Unless the beam-splitter is different. Apart from that your explanation looks OK.
  • #66
HOM interference happens for identical photons (whatever that means, but it certainly means the same polarization). Relative phase is certainly not a factor. Look at Fig.2 in the same paper. There are no fluctuations as relative delay is changed. This is common mistake to expect some phase dependent fluctuations in HOM interference, but there are none.
  • #67
I think I've worked it out. Normally in the entangled scenario we can write ##P(xy|\alpha\beta)=\tfrac{1}{2}P(x|\alpha)P(y|\alpha\beta) + \tfrac{1}{2}P(y|\beta)P(x|\alpha\beta)## and applying Malus' law we get ##P(11\ or\ 00) = \cos(\alpha-\beta)^2##. In the swapping case the information about the ##\alpha (\beta)## setting does not get transferred across from A to B. Instead the polarizations of photons 1 and 4 are projected in the same, or perpendicular polarizations ( ie V or H).
We can write ##P(xy|\theta_1\theta_4)=P(x|\theta_1)P(y|\theta_1\theta_4)##
Applying Malus' gives ##P(11|\theta_1\theta_4)=\cos(\theta_1-\alpha)^2\cos(\theta_1-\beta)^2## and ##P(00|\theta_1\theta_4)=\sin(\theta_1-\alpha)^2\sin(\theta_1-\beta)^2## and summing the last two is the probability of a coincidence between A and B. The sum reduces to ##\frac{\cos\left( 4\,\theta_1-2\,\alpha-2\,\beta\right) +\cos\left( 2\,\beta-2\,\alpha\right) }{4}+\frac{1}{2}##. For ##\alpha=(0, \pi/4),\ \beta=(\pi/8,\ 3\pi/8)## it turns out that ##a+b=\pm(a-b)## and also for the pairings ##(a,b'),\ (a',b),\ (a',b')## so setting ##\theta_1=0## we can write
##\frac{\cos\left( 4\,\theta_1-2\,\alpha-2\,\beta\right) +\cos\left( 2\,\beta-2\,\alpha\right) }{4}+\frac{1}{2}=\frac{\cos\left( 2\,\beta-2\,\alpha\right) }{2}+\frac{1}{2}=\cos(\alpha-\beta)^2##
So under certain assumptions it is possible for photons 1 and 4 to give the right statistics for total entanglement. This would be apparent if these events could be filtered out. I have not tried to work out what the Q1 and Q2 coincidences would be for this but they no doubt exist.
  • #68
akvadrako said:
What I meant by "basis" is that A&B start out entangled either along the same bases or cross bases.
If it's same, ##AB = |HH\rangle + |VV\rangle##, Erik will measure 1, ##E = |HH\rangle + |VV\rangle##.
If it's cross, ##AB = |HV\rangle + |VH\rangle##, Erik will measure 0, ##E = |HV\rangle + |VH\rangle##.
Okay, I think I found a way to make sense of it. The AB system is normally written in the classical basis:
##|H_A + V_A\rangle \otimes |H_B + V_B\rangle##
but for the entanglement swapping experiment, the same/cross basis is more convenient:
##|H_A + V_A\rangle \otimes |same + cross\rangle##
This makes it look just like any standard measurement of entangled qubits. When Erik measures same/cross on his system, of course it collapses the AB system. And just like any fully entangled pair, they should also be able to violate a Bell inequality along that basis.
  • #69
In entanglement swapping experiments polarization relationship is determined between two photons and relative phase relationship is determined between two pairs of polarization modes. Determining just one relationship is not enough to perform entanglement swapping.
One possible problem with a view that Bell state measurement (BSM) just reveals preexisting entanglement is that analysis of swapping is done in particular basis. Say maybe BSM forces photons from different entangled pairs to certain polarization and phase relationships and if it is not done we can't sort the quartets to four necessary bins before measurement of Alice's and Bob's photons.
  • · Replies 31 ·
  • · Replies 58 ·
  • · Replies 69 ·
  • · Replies 175 ·
13K
  • · Replies 376 ·
24K
  • · Replies 24 ·
  • · Replies 140 ·
11K
