QM:Finding the probabilities of a Hamiltonian measurement
This discussion revolves around a quantum mechanics problem related to finding probabilities associated with a Hamiltonian measurement, specifically focusing on eigenvectors and their normalization. The original poster references a problem from Zetelli and discusses the calculation of probabilities using eigenfunctions and wavefunctions.
  • The original poster attempts to normalize eigenvectors and calculate probabilities but encounters issues with complex values in the normalization factor. Some participants question the normalization process and suggest that the normalization constant should be real.
Participants are actively engaging in clarifying the normalization process and discussing the relationship between linear algebra and quantum mechanics. There is a recognition of the need to express the initial state as a linear combination of eigenvectors, and some guidance has been provided regarding the calculation of expansion coefficients.
There is mention of potential confusion between linear algebra methods and quantum mechanics principles, particularly regarding the treatment of complex numbers in normalization. The original poster also notes challenges in expressing the initial state due to the presence of complex numbers in the eigenvectors.
~Sam~
This problem is from Zetelli 3.21
http://imgur.com/wYTNVwz
Just the standard probability via product between the eigenfunction and the wavefunction
I've found the eigenvectors for the Hamiltonian (-i,5,3) (-i,-2,3) (3i,0,1)
I can orthonormalize them, as well as normalize the initial state |y(0)> however I run into a problem when actually calculating the probabilities. I only get complex values and can't seem to get rid of them, especially since the normaliztion factor for |y(0)> is 1/sqrt(-1-16i). Can anyone help?
They are already orthogonal, you only need to normalize them.
Then you must do the normalization wrong. Normalization constant must be real. Can you show us how you normalized ##\psi(0)##?
Ahh yes I realize now, I was trying to normalize then in terms of linear algebra instead of quantum mechanics. It looks like it's actually 1/sqrt(59). Normalizing the rest of the vectors and calculating the probabilities using bra-ket squared gives me ~59.322% ~23.73% ~16.95% which sum up to 100% so that looks right? Thank you
Both ways should coincide as linear algebra is one of the bases on which quantum mechanics was established.
Seems like the way I was doing it with linear algebra is wrong for complex numbers, just taking the dot product sums and square rooting. Any ways do you have any insight in helping in the part C of finding it how it evolves in time? I know I just need to write out the initial state as a linear combination of the eigenvectors, but the first number is 4-i, and there is no real numbers in the first entry in either three of the eigenvectors, they are just i, -i, and 3i. Same for the other entries
Right.
What you have to do is that you have to write ##\psi(0) = c_1 u_1 + c_2 u_2 + c_3 u_3##. You already have ##\psi(0)##, ##u_1##, ##u_2##, and ##u_3##. What are yet to calculate are the expansion coefficients. How do you normally find the expansion coefficients given the basis your vector is expanded to is orthonormal?
blue_leaf77 said:
Right.
Yeah just by using the formula for the C_n and taking the bra-ket of the eigenvectors and the initial wavefunction. I've finished the rest of the problem. Thank you!
