Quantum interpretations and indistinguishable elementary particles
35 replies · 6K views · last reply
Ben vdP said:
elementary particles are identical. The indistinguishability is a consequence of that.
Yes. Nobody is disputing that. But, as I've already pointed out, this fact has nothing to do with ensemble interpretations vs. interpreting the quantum state as describing individual systems.
Ben vdP said:
It starts to look now that by interpreting a physical system as an ensemble the concept of identical particles
got incorporated into Ballentine.
Can you give a specific quote from Ballentine that supports this claim?
Ben vdP said:
This concept may be missing in other interpretations. Or how do other interpretations reckon with the concept of identical particles?
Um, by using the same basic math of QM that deals with it? That's how QM models indistinguishability of identical particles: by how wave functions for systems consisting of multiple identical/indistinguishable particles are constructed. What those wave functions represent according to a specific interpretation--whether they represent an ensemble or an individual quantum system--does not change how the wave functions are constructed at all. So there is no need for different interpretations to "reckon with" indistinguishability separately. It's already reckoned with in the basic math of QM that all interpretations use.
Ben vdP said:
The original question could even be rephrased that way.
Rephrasing the question doesn't help any. The response is still the same. See above.
Ben vdP said:
By describing it as an individual physical system, it is being overlooked that every such physical system is like any other such physical system.
You still don't appear to grasp that "an individual physical system" in QM is not the same thing as an individual elementary particle. Please go back and read my posts #8 and #19 again, carefully. The supposed issue you are claiming here simply does not exist.
Lord Jestocost said:
the two particles can't even be distinguished by their locations – or rather, by the probabilities of their being found at various locations
To clarify a point that might be confusing here, in the light of what I said in post #8 earlier in this thread: if I have a single electron in a Penning trap, and I just let it sit there, I can "distinguish" it from all other electrons by saying it's the electron in that Penning trap.
But as soon as I try to do something that involves more than one electron, like put a second electron into the trap, or release two electrons from two different traps and put them through some kind of experiment and then try to put them back, I can no longer say which of the two electrons I end up with came from which place at the start. If I put a second electron into the trap, for example, I can no longer say which of the two electrons in the trap was already there and which was the one I put in. And the wave function I write down for the two-electron system in the trap will reflect that. And, as I've said, that fact is independent of any choice of QM interpretation: all interpretations will use the same wave function, constructed the same way, for the two-electron system. They just will say different things about what that wave function "means" over and above the predictions it allows us to make.
The issue has become more clearer now and I think these posts misses the point.
It is not about individual elementary particles at all.
Suppose you are writing down a description for the state of a free particle fp with schrodinger equation and wave function ...
After stating that it describes an individual physical system (and not individual particles).
Where in the description has the notion or characteristic of identical particles been expressed?
The description ought to be complete and there should be no discrepancy between the description and actual physical elementary particles or their characteristics.
In the end QFT needs to save the day.
No, they don't. If anyone in this thread is missing the point, IMO it's you.
Nowhere, because the quantum system in this case only consists of one particle.
The notion of "identical indistinguishable particles" only comes into play when you want to write down a single wave function that describes a quantum system containing two or more particles of the same type. And QM already has a perfectly good way of doing this, that doesn't depend on any particular interpretation.
Which I already said in post #31 (and I said parts of it in earlier posts as well, going back to post #8).
There isn't. See above.
There's nothing that needs to be "saved". As I've already pointed out several times now, there is no issue here at all.
Since the OPs question has been answered multiple times in this thread, this is a good time to close it.
Thank you all for contributing here and thanks to the OP for posting his questions here.
The thread is now closed.
