Quantum mechanics - several constant potentials
7 replies · 2K views · last reply
Eitan Levy
A particle with mass m is in a one dimensional potential, as seen below.
The wave function in [itex]x<0[/itex] is 0.
The wave function in [itex]0<x<b[/itex] is: [itex]Asin(kx)[/itex]
The wave function in [itex]x>b[/itex] is: [itex]Be^{-\alpha x}[/itex]
It is known that [itex]k=3*10^{10}[/itex] and [itex]b=0.5333333*10^{-10}[/itex]
Find [itex]\alpha[/itex]
Schrodinger stationary equation
Piecewise potential V(x) defined as infinity for x < 0, 0 for 0 ≤ x ≤ b, and V_0 for x > b.
What I tried to do was using the fact that the wave function should be continuous.
[itex]Asin(kb)=Be^{-\alpha b}[/itex]
The derivative also should be continuous:
[itex]kAcos(kb)=-\alpha Be^{-\alpha b}[/itex]
And the probability to find the particle in total should be 1:
[itex]\int_0^b A^2sin^2(kx) dx + \int_b^{\infty} B^2e^{-2\alpha x} dx =1[/itex]
This set of equations is to hard to deal with, the equations should be solved with calculator only so I think I did something wrong.
Also, there may be a better way to approach this problem, but I'm not seeing it.
Hints: It's much easier than you think. You only need the first 2 equations.
Is the answer 0.08763*10^(10)?
I haven't done the calculation. How did you get that value?
Also, have you forgotten units or were there really none supplied in the original question?
I divided the first equation by the second:
[itex]\frac{1}{k}tan(kb)=-\frac{1}{\alpha}[/itex]
And I plugged in the numbers.
No units were provided.
Agreed. Well done! A couple of points:
1) You haven't correctly used standard form (mantissa in wrong range).
2) You have rounded the last digit incorrectly when giving the answer to 4 significant figures.
If working in SI units, what do you think the unit would be? (If I were handing this in, I would make a comment about the appropriate SI units below my answer.)
[itex](Angstram)^{-1}[/itex]
The ångström (Å) (note spelling and capitalisation) is a bit old-fashioned, but is still used in some areas. It is not an SI unit.
1 Å = 10⁻¹⁰ m
That means
1 Å⁻¹ =10¹⁰ m⁻¹
I would have given the answer as:
α = 8.76x10⁸ (m⁻¹ assuming we are working in SI units)
EDIT: It's very poor practice to give values without units. The question should have given the units for k and b.
