Has entanglement in quantum physics been experimentally validated?
Entanglement in quantum physics has been experimentally validated through thousands of experiments, confirming its existence and behavior as predicted by quantum mechanics. Key methods include generating pairs of entangled particles and demonstrating perfect correlations using the cos^2(theta) function for photons, reaching a maximum of 1 at angles of 0 or 90 degrees. The violation of Bell inequalities further substantiates the non-locality of entangled particles, disproving many hidden variable theories. Recent experiments have eliminated loopholes in the diffraction limit tests, reinforcing the completeness of quantum mechanics.
  • Understanding of quantum mechanics principles, particularly entanglement
  • Familiarity with Bell's theorem and Bell inequalities
  • Knowledge of correlation functions in quantum physics
  • Basic concepts of diffraction and interference patterns
  • Study the implications of Bell's theorem on local realism
  • Explore the mathematical foundations of quantum entanglement
  • Investigate recent advancements in quantum optics and entangled photon experiments
  • Learn about the role of superdeterminism in quantum mechanics
Physicists, quantum mechanics students, researchers in quantum optics, and anyone interested in the experimental validation of quantum theories.
SDetection
Hi, as my previous thread was closed, I'd like to continue asking some questions here regarding QM (of course if the mentors don't mind that ?).
DrChinese said:
This experiment and a zillion other tests of the HUP have demonstrated it is indeed correct. Every day, new and sophisticated experiments are performed on entangled particles and their behavior must follow the HUP to obtain the expected results. So the scientific community is actually performing ongoing experiments in this regard daily.
So, has entanglement been experimentally proven?.
Yes, in literally thousands of experiments covering dozens of ways that particles can be entangled.
Entanglement can be verified a number of ways. The usually starting point is to generate a stream of particle pairs that exhibit a maximum of "perfect correlations". Only entangled pairs exhibit this, which is the cos^2(theta) function for photons. That reachs its max of 1 at theta=0 or 90 degrees. Unentangled photons follow a different correlation function, with a max of only .75 at those angles. The unentangled function is .25+.5(cos^2(theta)).
The next step is usually to form a Bell Inequality and demonstrate its violation. Obviously, for both the first step and the second step, the exact functions are dependent of the particle types, the setup, what is being measured, number of particles (entanglement can be 2 or more), etc. So the exact methodlogy varies, but is always described.
Yes.
In the early 80s http://en.wikipedia.org/wiki/Alain_Aspect" that confirmed entanglement.
I still don't get it, could someone explain to me, from physics point of view, how Bell's experiment proved entanglement?.
You don't prove a thing like entanglement (or gravity). What you do is to compare the predictions of different theories to see if you can dismiss some of those theories.
A large class of hidden variable theories make predictions that satisfy Bell inequalities. Quantum mechanics makes predictions that violate those inequalities. Experiments were performed, and the results weren't even close to satisfying the Bell inequalities. Therefore, those hidden variable theories have been falsified.
Note that violation of Bell inequality is only ONE aspect of the test of quantum entanglement. The other is the breaking of the diffraction limit using these entangled particles.
http://physicsworld.com/cws/article/news/19514
Such experiments were done 5 years ago!
Zz.
Zz.
OK, but do the loopholes still apply to those new experiments, specifically http://physicsworld.com/cws/article/print/1332" ?:
physicsworld.com said:
Bell himself was worried that, according to special relativity, the nonlocal (faster than light) influence demonstrated in the Aspect experiment could involve propagation backward in time in other inertial reference frames of equal status. What he called the "cheapest resolution" to this problem was to return to the Lorentz (i.e. pre-Einstein) approach to relativity in which an ether is retained. In other words, there is a preferred frame of reference in which a real causal sequence may be defined (see Bell's contribution to The Ghost in the Atom in further reading). Propagation backward in time in other frames may then be dismissed as "unreal" or "apparent". More generally, however, Bell hoped for better theories than the ones we have now, and insisted that our current version of quantum theory was no more than a temporary expedient.
There are no loopholes in the diffraction limit experiments.
Zz.
Zz.
I'm sorry, I meant do the diffraction limit experiments (as Bell's experiments) favor the completeness of QM?. If so do the loopholes still apply to them?.
Thanks.
Thanks.
You are no longer making any sense.
At some point, YOU have to do your own homework. We have arrive at that point where you have to read those experiments yourself, understand the physics, and then figure out if your question makes any more sense.
Zz.
Vanadium 50 said:
SDetection said:
I meant photons can be more concentrated at a tiny hole than electrons.
Why do you think this?
Ok, Here is why I think so. Electrons interference pattern :
http://www.hitachi.com/rd/research/em/doubleslit.html"
Photons interference pattern:
http://ophelia.princeton.edu/~page/single_photon.html"
But why this happens?.
These are not "tiny holes"!
Look at the nature of the detector. In many cases, these are CCD detectors. It means that whatever is triggering it has a finite "boundary" of detection.
If I make the CCD camera pixels bigger, you get bigger "holes".
Zz.
If you are asking about why the patterns are different, it looks to me that the electrons were diffracted through slits while the photons were diffracted through holes. :wink:
I know, I didn't mean that. If you compare the two patterns, you will notice that when photons go through the slits, they are more concentrated at one entrance point (tiny hole) along the slits axis unlike electrons.
No!, if you are sure about that, you would have said this before :smile:.
Huh? Did you show these pictures before? Do you know what they represent?
SDetection said:
There are no loopholes in the proof of entanglement. What you are trying to refer to is the alleged loopholes in tests of Bell's inequality, which is used to rule out local realism. These are not the same things as proof of entanglement. Even folks that assert local realism is not ruled out by these tests must acknowledge that entangled pairs do NOT act like unentangled pairs.
I meant that you saw pictures of photons/electrons interference pattern before?.
Yeah, I know, maybe I should have said "entanglement interpretation". But have all the alleged loopholes been argued as not happening in Bell's experiment?.
I have certainly seen them before. What's your point?
I'm sorry, it was maybe a misunderstanding.
Are you perhaps referring to the fact that in the second picture the light source is more collimated (maybe a laser beam)?
This thread is really hard to read. I'm surprised it hasn't been locked yet.
It is definitely a laser beam passing through a double slit.
DrChinese said:
The usually starting point is to generate a stream of particle pairs that exhibit a maximum of "perfect correlations". Only entangled pairs exhibit this, which is the cos^2(theta) function for photons. That reachs its max of 1 at theta=0 or 90 degrees. Unentangled photons follow a different correlation function, with a max of only .75 at those angles. The unentangled function is .25+.5(cos^2(theta)). .
If the stream of particle pairs are photons, perhaps we can explain the entanglement using "special relativity". Per SR, from the photon's point of view, the distance between the pair is always zero and time stands still, then the entanglement is not so perplexing
Yeah, it's a laser source, but the mean distance between consecutive photons is 2 km.
Come on!, don't put ideas in the mentors minds. As I'm still learning, and this is a public forum, I'd like to know what you think is so hard to read, quote me, and I'll try to improve the writing.
Maybe it's hard to read for you because some posts here are in the context of a prior discussion.
Ok, but what I intended is: are you referring to the fact the two pictures are different because in the second case the laser beam's cross section area is lower than the slits' dimensions?
Yes but not exactly:
This thread has really become VERY confusing, but it is due to your own fault. Note that it started simple with issues about entanglement, and now it is nothing more than going back to going around in circles about standard diffraction and interference.
It appears that even after repeated attempts in this and the other previous threads, you clearly have not understood (or want to understand) the QM picture of interference. And now, you are trying to pick on some apparent "details" about the interference. Let me just say that the mathematical description for BOTH types of interference does NOT differ. Unless you can show otherwise, you are barking up the wrong tree of ignorance here.
Do not attempt to go after non-existent effect or entity by simply making wild guesses. We draw the line right there in this forum. While we welcome people who sincerely want to learn, we do NOT cater to someone who is simply shooing empty bullets in all directions hoping to make one sticks. There have been many people who have responded to your ORIGINIAL question hoping that you wanted to learn about entanglement, and somehow, it has degenerated back to some nonsensical in-detail examination of the interference pattern.
Either this goes back to discussing what you asked for in the beginning of the thread, or this thread is done. It is your call.
Zz.
I'm sorry but I don't know how this thread is confusing!, it's an open and ongoing discussion. If someone thinks that something is confusing, he/she just have to refer to it and explain why it's so. I don't post and run away, I'm very committed here.
But as the thread title implies, I want to discuss all aspects of quantum physics, not just entanglement. Also correct me if I'm wrong, Diffraction and interference in the slits experiments are very important aspects of quantum physics, right?. Also I was responding to question by a member regarding why I think photons can be more concentrated at a tiny hole unlike electrons.
Correct me if I'm wrong, but quantum physicists themselves don't understand that?.
When it comes to the mathematics, I assure you that I'm very convinced, but I'm only concerned with quantum physics. Also which "types of interference" you are referring to if the "mathematical description" for them is the same?.
I'm sorry, but it's divide and conquer, a very good learning technique, I'm not "shooting empty bullets", my arguments are based on logic and reasoning even if they were scientifically wrong in the beginning. Also I didn't hold my position on any argument that was proven scientifically wrong, which means that I want to learn and I actually did. Also I'm not questioning QM successful predictions but I want to come up with a non counterintuitive interpretation.
As I said I want to discuss all aspects of quantum physics, I'm not going off-topic here. I'm reading about entanglement and I'll not drop it from the discussion.
But my original question was "do the mentors mind me asking any questions regarding QM?":
SDetection said:
It is your call.
No, It's yours :smile:, and I know that you're open-minded and won't close this thread.
  • · Replies 58 ·
  • · Replies 17 ·
