Question about discussions around quantum interpretations
  • Context: Undergrad
  • Thread starter Thread starter ojitojuntos
    Amateur Quantom physics
The discussion centers on the interpretations of quantum mechanics (QM), particularly the challenges faced by Objective Collapse theories and the implications for deterministic versus probabilistic models. Participants highlight that while deterministic interpretations, such as Everett's, are prevalent, experimental evidence supports the inherent randomness of quantum phenomena, as demonstrated by Bell tests and double-slit experiments. Key texts like Ballentine's "QM: A Modern Development" and Weinberg's work on Quantum Field Theory (QFT) are recommended for deeper understanding. The conversation emphasizes the necessity of grasping fundamental QM principles before delving into interpretations.
  • Understanding of quantum mechanics fundamentals, including the measurement problem.
  • Familiarity with key texts such as Ballentine's "QM: A Modern Development" and Weinberg's QFT.
  • Knowledge of Bell's theorem and double-slit experiments.
  • Awareness of different interpretations of QM, including Objective Collapse theories and Everett's interpretation.
  • Study Gleason's Theorem and its implications for the foundations of QM.
  • Explore Quantum Field Theory (QFT) and its relationship to non-relativistic QM.
  • Investigate probabilistic interpretations of QM, focusing on texts by Asher Peres and Roland Omnes.
  • Research the philosophical implications of determinism versus non-determinism in quantum mechanics.
Physicists, students of quantum mechanics, and anyone interested in the philosophical implications of quantum interpretations and the nature of reality.
  • #151
iste said:
Which features of Bohm do you find impalatable, out of interest?
I'll get back to this later, have been busy and not had time to add readable posts in the Barandes thread either. I will get back and compare BM with Barandes SQC from a different angle, that illustrate common problems of Bohmian and Barandes picture, but what makes one more palatable. But none of them are satisfying; both needs to be completed. After all that comparasion is fair as both sort of aspires on a kind of HV approach, but in different ways... so ill respond anoter time
/Fredrik
  • #152
When discussing "interpretations" my perspective is always on solving the open foundational problems such as for example
  • Reduce fine tuning as it deflates explanatory value (Cosmological constant + SM model parameters or vacuum selection in string theory... all these manual settings suggests we really are missing something, string theory had an ambition here, but traded the SM parameter emergecen for something even worse in the vacuum selection)
  • Problem of time (distinction between evolution and dynamics and their different contexts)
  • Observer/Measurement problem (meaning and resolution of tension between inferential perspectives)
I think any pure interpretation of a model, in the sense of just thinking differently about the same math will never solve these problems. But it can help identify conceptual handles including different mathematical models that via correspondence make equivalent descriptions/predictions.
My preferences for which interpretations I find palatable are purely rooted in how likely I think their perspectives is to help make progress among the many, likely related, open questions.
I see largest potential using tools like ABM models of evolutionary IGUS, and comparing BM and SQC BM has an akward perspective that does not naturally mate with ABM and IGUS - but SQC does.
One of the key issues is that the nomological guide in both SQC and BM needs to be determined from Schrödinger Eq then via correspondences we get guidance or transition probabilites. This is both unsatisfactory.
But the difference is the nomological guidance in BM sits at global system dynamics level. Ie you need to consider the global system to make an inference about the future, and also specify initial conditions of the global system. This is fine at some Gods view level, but it is invalid for any subsystem view.
In SQC the nomological guidance sits at the subsystem/part level, even if there is a global time dependence, and the stochastic process in time, is independent of the initial conditions of other remote subsystems.
To try to fix the problems in SQC view, seems to be easily merged with ideas from ABM, seeking first principle constructions of the transition probabilities and release ourselves from the schrödiner equation and the hamiltonian. The transition probabilities could instead be perhaps understood as evolutionary atttractors in some way. This is possible thanks to the fact that Barances moves the dynamical law, from system level to stochastic subsystemlevel.
To fix the problem in the BM view, seems hard, beacse the causal rules is hardcoded at global, system level. But an real observer is a subsystem, and inferences at system level seems to be out of information capacity bounds for a real observer. And although mathematically a possibile in a descriptive sense, it gets opaque as it hides the constructing principle of internal interactions, which is alos why it gives apparent non-local effects, but I have no idea how to work with it from the inference perspective or how it helps a real observes learn about its environment - which I see as the central task; and how it describe it from the inside and not from an gods view.
So the main key is the level of where the nomological constructs work. System dynamics as universal paradigm is deeeply problematic, because it emergence there are usually more like dynamica attractors, that are essentially fine tuned via initial conditions or priors. With a bigger model of evolutionary attractors, self-organisations fixes the fine tuning as part of hte physical process. The only problem is that, the evolutionary changes can't always be captured bt a timeless law; ie embedded in a higher dimension. Trying to do that misses the point as it keeps trying to put the ruling constraints in a bigger fictional embedding.
/Fredrik
  • #154
ojitojuntos said:
Thank you so much for the explanation!
Guys, I recently read that objective collapse theories have been increasingly constrained. Does this mean that, indirectly, determinism has gained more plausibility over probabilistic interpretations?
No. The operationalis/instrumentalist account is probabilistic and has no objective collapse. Consistent histories is probabilistic and has no objective collapse. Recent nonmarkovian reformulations are probabilistic and have no objective collapse.
  • #155
I would say it rather makes the concept of objective probability less plausible as fundamental in a theory or interpretation where you insist that measurements and expectations are physical interactions and encodings as opposed to armchair mathematical constructs and "not real".
Ie. it makes it less plausible to think that objectively inferrable ~ real/ontic
/Fredrik
  • #156
  • #157
Thank you! Now, these past weeks I’ve tried to take some time off work to read a bit, but in afraid that I’m far from being able to grasp some of the concepts shared here.
I was wondering: Do QFT theories shift the balance towards a fully deterministic reading of nature vs a probabilistic one?
I tried to Google it, and learn from online sources, but the proliferation of AI articles and sensacionalista shows make it very hard to filter what is bogus and what not for a layman like me.
I even tried using AI to get a list of relevant articles, but most of them didn’t exist! Hahah
Again, I reallly appreciate your willingness to help me navigate these questions.
  • · Replies 34 ·
  • · Replies 45 ·
  • · Replies 109 ·
10K
  • · Replies 35 ·
  • · Replies 52 ·
  • · Replies 37 ·
