Question about Electricity and Water
  • Context: High School
  • Thread starter Thread starter Ravenlock
    Electricity Water
The discussion centers on the dangers of electrocution in water, particularly when a plugged-in toaster is dropped into a body of water, such as an Olympic-sized pool. Key points include that tap water conducts electricity, and the risk of electrocution depends on the resistivity of the water and the distance from the electrical source. The internal resistance of the human body is low, making it possible for dangerous currents to flow even in large bodies of water if the conditions are right. The conversation highlights that the position of a person in relation to the electrical source significantly affects the risk of electrocution.
  • Understanding of electrical conductivity and resistivity
  • Knowledge of basic electrical safety principles
  • Familiarity with the concept of current sinks
  • Basic physics of electric circuits
  • Research the resistivity of different types of water, including pool water and saltwater
  • Study the effects of electrical current on the human body, focusing on thresholds for sensation and pain
  • Learn about electrical safety measures in wet environments
  • Investigate the physics of electric fields in conductive mediums
Electrical engineers, safety professionals, and individuals interested in electrical safety in aquatic environments will benefit from this discussion.
Ravenlock
I had a question about electricty and being electrocuted. It is well known that if you drop a toaster that is plugged in into a bathtub you are sitting in, you will be electrocuted.
My question is, how far reaching is the electrical energy in a body of water?
For example, if I am in standing in one end of an olympic sized pool and someone drops a plugged in toaster in the other end, will I be electrocuted like I would in small body of water such as a bathtub? Or is there to much area and the electrical energy dissipates? Any help would be appreciated, thank you!
Ravenlock
Possibly, If you happened to be positioned near a suitable current sink.
OTOH, if you were in a fiberglass tub with plastic drain plumbing you might be able to simply pick the toaster up and drop it outside the tub with no harm to you.
Don't try this at home.
Tap water is a conductor of electricity, in the same fashion as wire but with higher resistivity.
If it were electrically insulated, the entire body of water would be at the same potential, and, if you were grounded, touching it anywhere could be adequate to kill you. On the other hand, if the circuit you make involves kilometers of water, the total resistance through that water (in series with you) will be quite high, and not much current would flow.
The resistivity of water varies immensely with the amount of type of substances dissolved in it; I can probably provide you an exact answer to your question -- how much water is necessary to provide a large enough resistance to avoid electrocution -- but I'll need to find the resistivity of pool water first. I wasn't able to find it after a few minutes of googling, so I gave up.
- Warren
I was swimming in the West Pearl River when lightning hit a tree about fifty feet from the bank. Some of the current spread out through the water. I was lucky to notice it at all because it was so weak and fast but I recognized the waveform signature. Some kids who were closer to the shore felt a stronger current and were impressed. No one was hurt but we were all properly scared and took refuge beneath a train bridge.
I had a long lasting interest in electrolysis as a kid and did many experiments with DC and salt water. I found that if you make the connection between two cans of salt water, 20 or 30 volts is about all you can stand. With fresh water the voltage is higher. With dry hands you will need about 70 volts to feel a shock. I compared my findings with some NASA documents while working on Space Station and they were in the same ball park. Intact skin on the fingers has a resistance near 30K ohms. You will have a hard time feeling less than 0.1 ma. A cut or puncture will conduct more and hurt more.
Electrical currents through the eye will cause you to see white light and not colors.
You could make some simplifying assumptions.
Parallel plates with water between them.
Maximum current for the standard US household outlet 20 amps @ 110v.
Divide the pool into a number of parallel resistors the size of a heart, the key problem area. A guess at 16 sq inches.
Say its survivable it the current stays at or below 5ma through your heart.
((20a * 1000)/5ma)*16in= 64000 sq in/144 = 445 sq ft = aprox 22 X 22 plate.
Notes:
The internal resistance of your body is very low so you want the pool long enough so the percentage change of the resistance of a column is small.
Knowing the actual water resistance here would be helpfull.
In the above setup your position between the plates won't really matter.
For point sources and sinks the problem becomes much more complicated.
Your location matters.
For an actual toaster the majority of the current will flow within the toaster and the pool itself will only get some minor residual currents.
Unfortunately, a residual current of 10ma across your heart is quite sufficient to kill you.
The above exercise really does not mean much in terms of the original question, since the outcome will be determined by the available current sinks and your position relative to them and the toaster. Current will always take the shortest path. Don't get in the way.
