How to Determine if a Glass was Broken from Inside or Outside
  • Thread starter Thread starter vabamyyr
    Glass
The discussion focuses on determining whether glass was broken from the inside or outside, referencing forensic analysis techniques used in crime scene investigations. Specifically, the concept of Haeckel marks is mentioned, which are fracture patterns that can indicate the direction of force applied to the glass. The conversation also touches on the classification of glass as an amorphous solid versus a highly viscous liquid, highlighting the complexities surrounding its physical properties.
  • Understanding of forensic analysis techniques
  • Knowledge of glass fracture patterns and Haeckel marks
  • Familiarity with the properties of amorphous solids
  • Basic principles of material science
  • Research forensic glass analysis techniques
  • Study the significance of Haeckel marks in fracture analysis
  • Explore the properties of amorphous solids in material science
  • Investigate the historical context of glass manufacturing processes
Forensic scientists, criminal investigators, material scientists, and anyone interested in the physical properties of glass and its applications in crime scene analysis.
vabamyyr
I saw CSI today and a glass was broken on the crime scene and furensics took one sample fracture from there and did one experiment in the laboratory also. (experimentor broke a window (glass) with baseball bat). And then they analysed those 2 fractures(one from scene and one from lab) and determined that the glass broken on the crime scene was done from the inside not from outside which would refer to burglary. But i couldn't figure out how. They talked about some Haeckel marks? and i typed it into google search and found nothing. Anyway can someone tell me the method determing whether normal window (glass) is broken from inside or outside, or is my question too confusing?
http://www.stanford.edu/~zhongj/SGKBweb/def/joiSurMor.html
http://members.aol.com/JRD203/csi-episode-010.htm
Enjoy.
i also have a question about glass: is it a liquid or a solid?
because i read something that claimed it is now considered a liquid with high viscosity, since old stain-glass windows appear to "run".
The thing about glass flowing in churches is untrue. The reason that such glass is thicker at the bottom is due to the manufacturing process. This glass was generally blown, flattened, and then spun, meaning that the glass was thicker on the outside of these big discs. The glass was then cut up into sheets, and when installed, common sense led to the glass being installed with the thick (heavy!) side at the bottom.
The answer to the question "is glass liquid or solid" is not a clear one, and if you use the search facility you will see some rather long debates presenting both sides of the argument. For engineering purposes, I like to class glass as an amorphous solid, although there are arguments for it being a highly viscous liquid, and some class a "glass" as being a separate category altogether.
brewnog, thanks for the clarification.
i can remember when there were just 3 forms of matter, solid/liquid/gas..those days are long gone. :smile:
For most practical purposes, it's still prudent to make a distinction between those three states. I'd always treat glass as a "solid" (unless it were molten :smike:)
  • · Replies 19 ·
9K
10K
