Question about higher dimensions and what connects them
The discussion revolves around the concept of higher dimensions, particularly focusing on the nature of additional spatial dimensions beyond the third. Participants explore the geometric representation of these dimensions, the implications of perpendicularity, and the limitations of human perception in understanding higher-dimensional spaces.
  • One participant describes the process of moving from lower to higher dimensions by adding perpendicular lines, questioning the nature of these additional lines and their representation in lower dimensions.
  • Another participant argues that additional lines do not have a direction that can be pointed to or drawn, suggesting that visual representations are merely intuitive and lack mathematical rigor.
  • A different viewpoint emphasizes that while we perceive only three dimensions, the existence of higher dimensions implies they are always present, raising questions about our ability to point in those directions.
  • One participant clarifies that our experience is limited to a three-dimensional spatial submanifold, which restricts our pointing to that submanifold despite the existence of higher dimensions.
  • A later reply questions whether the limitations of human perception might distort the understanding of dimensionality, suggesting a potential challenge to the previous claims about the nature of higher dimensions.
Participants express differing views on the nature of higher dimensions, the validity of visual representations, and the implications of human perception. No consensus is reached on these points.
Participants acknowledge limitations in understanding higher dimensions, particularly regarding the assumptions about perception and the mathematical representation of additional dimensions. The discussion remains open to interpretation and further exploration.
Cody Richeson
It's my understanding that, if we ignore the temporal dimension and just focus on spatial ones, then you get to the third dimension by starting with a point and adding perpendicular lines to them. Once you've done this a couple of times, you get three dimensions. Obviously, to the layman, it appears that there are no more perpendicular lines to add in order to reach higher dimensions. There are, of course, and in crude visual analogies a simple 4-dimensional cube appears to have diagonal lines protruding from the 3D dimensional edges. This is not how it "really" would look, as it's a shadow of the 4D actuality, but can anyone explain what direction these additional perpendicular lines are going in, and why they appear diagonal when downgraded to a shadowed projection? Also, why do the lines have to be straight, and why do they have to be perpendicular?
The additional lines do not go in any direction in which one can point, or that one can draw, as we can only point in three dimensions and draw in two. Drawings that show additional dimensions by diagonal lines are intended only to create intuition and have no mathematical rigour. Personally I find such drawings less than helpful, but if they help others than that's good for them.
The extra lines don't have to be perpendicular. But the only component of the new lines that is of interest is that which is perpendicular to all lines that have already been drawn, because when you remove the perpendicular component the remainder can be decomposed into a set of lines each of which is parallel to a line that has already been drawn. So one generally talks about a new line being perpendicular to the ones already drawn because it is simpler and neater.
You say the additional lines "do not go in any direction in which one can point," but we are constantly embedded in however many dimensions there are. I know we only perceive three, but if the dimensions are all there, all the time, then how come we can't point in the direction of additional lines?
Because at every instant in time we are in a three-dimensional spatial submanifold, and we can only point within that submanifold. The fact that that submanifold is embedded within an n-dimensional manifold does not change our submanifold, or where we can point, no matter how big n is.
Is that true, or does the limited perception of humans make it seem as though that were true?
  • · Replies 29 ·
11K
