Question about work, energy and the work energy theorem.
A mass is placed on a frictionless ramp and then encounters a rough patch before reaching another frictionless ramp, prompting a question about the height it reaches on the second ramp. The discussion centers on applying the work-energy theorem and understanding the forces at play, particularly friction and gravity. The key equation used is -µmgd = mgh_2 - mgh_1, which relates the work done against friction to the change in gravitational potential energy. Clarifications are sought regarding whether to account for the work done by gravity on both ramps. Ultimately, the consensus is that the initial calculations are correct and that gravity's work has been appropriately considered.
Ethan_Tab
So a mass m is placed on a ramp at a height given by h_1. This portion of the trip is frictionless. Then, at the bottom of the ramp the mass encounters a rough patch of levelled ground with a µk given my µ. This strip has a length of size "d" meters. After traveling across this surface, the mass encounters yet again, another frictionless ramp. The question wants to know how far up the second ramp the ball will get. Call this variable h_2. There were no ø given for either of the two ramps.
ΔE=W
GPE=mgh
KE=½mv^2
W+KE_1+GPE_1=KE_2+GPE_2+E_loss (due to friction)
KE_1=0
KE_2=0 (when it reaches it max height on the second hill)
If someone could confirm this or explain why this is incorrect it would be very helpful.
Im thinking,
Since W=F*D and I know the only force acting against the ball is that of friction (negative work), can I equate that to ΔGPE?
So; -µmgd=mgh_2-mgh_1
-µd+h_1=h_2
But now that I think about it, would there also be work done by the x component of gravity when the ball is rolling down and up the first and second hills? If anyone could clarify this it would be much appreciated.
Your solution looks correct to me.
Could you elaborate upon this? I am not entirely sure what you are confused about.
Can I just assume all work done is that which the mass encountered when it slid across the rough patch of length "d" or do I have to count for the work done by gravity when the mass was on both ramps?
Ethan_Tab said:
-µmgd=mgh_2-mgh_1
It looks like you did account for it.
Gravity is a conservative force. The work done on the mass by the force of gravity is equal to the change in kinetic energy of the mass; W = ΔK
Likes Ethan_Tab
Oh! I see! Thanks for the help :smile:.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
