Explosions and Damage: How Does Size Affect Impact?
  • Thread starter Thread starter jones111
    Explosions
Explosions impact objects based on their proximity and the nature of the blast, with smaller objects experiencing only a fraction of the force due to their limited exposure to the blast radius. The main components of an explosion include debris, fireball, and shockwave, and individuals are affected primarily by the parts that directly contact them. The "full force" of an explosion is defined by the pressure difference multiplied by the area of contact, meaning that larger exposed areas can result in greater force experienced. The concept of damage amplification in smaller objects struck by larger blasts is unclear, but damage varies significantly based on material properties. Overall, minimizing exposure to the blast is crucial for safety.
jones111
Quick question:
My friend and I are having problems on how explosions work.
According to him, in a explosion smaller objects don't receive the full force of the blast since they only encompass a small fraction of the blast radius.
So basically let's say if I'm in the path of a grenade blast or something, I'm not actually receiving the full force of the blast but the portion that comes contact with my body?
Another thing is their like a scale in which when smaller objects are hit by a larger explosive blast, the damaged is amplified?
jones111 said:
Quick question:
That would be correct - after all, how would your body be affected by the part of the explosion that does not come into contact with it?
To be clear - most explosions have three main parts: the debris, the fireball, and the shockwave. In some explosions, the light-pulse is strong enough to be a problem too. But each part is like being in a room sprayed by bullets ... you are only affected by the bullets that hit you.
Note: the "full force" of the explosion on a body is the total force experienced by the body. It is the pressure difference multiplied by the area. Strictly speaking you should say that a body does not intercept the full energy of the explosion - except in special situations, like when you fire a bullet, when the explosion is contained in some way.
I don't understand that question - can you provide an example?
Some sloppy terminology here but your friend is basically correct. The explosion is essentially a radial pressure wave, and the force you feel derives from a gradient in that pressure wave (high pressure from the compressed air will push you backwards). Force = pressure times area, so if you present a larger area to the source, you have a proportionally larger force.
"Damage" is a slippery term and depends a lot on the particular material. But I'd definitely recommend trying to minimise your area as seen by the source of the explosion. You'd certainly not want to do a star jump as the pressure wave comes towards you.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
