Radio Power Conversion: Convert mV/m or nW/m2 to Watts
  • Thread starter Thread starter coltonk
    Power Radio
The discussion revolves around converting measurements of electric field strength (mV/m) and power density (nW/m²) from a ham radio antenna into transmitted watts. Participants explore the implications of these measurements for assessing antenna efficiency and performance.
  • One participant expresses difficulty in finding a method to convert mV/m or nW/m² into watts to evaluate antenna efficiency.
  • Another participant suggests borrowing an SWR meter as an alternative measurement tool and clarifies that mV/m represents electric field strength.
  • A different participant explains that nW/m² measures power density at a specific location and notes that the meter does not account for the antenna's radiation pattern, which affects readings based on directionality.
  • One participant proposes using a far field meter for comparative measurements and suggests mapping the radiation pattern with a rotator to improve antenna design.
Participants do not reach a consensus on the best method for converting measurements to watts, and multiple approaches and considerations are presented without resolution.
Participants mention the limitations of the measurement tools and the need for understanding the antenna's radiation pattern, which may affect the accuracy of power calculations.
coltonk
TL;DR
Converting units of transmitted power
I have searched the internet and spoken to the manufacturer of my equipment and can not find an answer. I am using RFExplorer (test equipment) to measure the power generated by my ham radio antenna. The only options for displayed power is mV/m or nW/m2. I am trying to find out how to convert these into transmitted watts so I can see how efficient my antenna is radiating and my radio output is watts.
Can you just borrow an SWR meter instead? BTW, mV/m is the E-field strength.
https://www.wimo.com/en/cn-901hp-swr-meter
Is this your meter/spectrum analyzer?
nW/m2 is the best your meter can do with power measurements. It is the power measurement at the measurement location, a surface measured in m2. The problem is your meter doesn't know about how the antenna radiates in the other directions. With everything else being equal a more directive antenna will give you a higher reading on the beam axis, and lower readings off of the beam axis.
So, if you could measure in every direction, you could add up the total power. Really, you're integrating the measurements over a closed surface around the antenna. Alternatively, if you know the radiation pattern of your antenna, maybe you could use the meter to calibrate a theoretical summation over all directions.
That's what I have..
Is computation of absolute efficiency important?
Why not set up a test range with a far field meter, say beyond 60λ. Then you can make comparative measurements to improve the design relative to a simple dipole. If you have a rotator for your antenna under test you can also map the radiation pattern.
  • · Replies 37 ·
  • · Replies 16 ·
  • · Replies 27 ·
10K
