MHB What is the Probability of Certain Digits Not Appearing in a Random Selection?
  • Thread starter Thread starter WMDhamnekar
    Random
The discussion focuses on calculating the probabilities of certain digits not appearing in a random selection of digits. For event (a), the probability that 0 does not appear is calculated as 0.59049, derived from the general formula (9/10)^k. Event (b) mirrors the calculation for event (a), while event (c) is expressed as (81/100)^k, indicating the probability that neither 0 nor 1 appears. Event (d) is formulated as 2(9/10)^k - (81/100)^k, representing the probability that at least one of the digits 0 or 1 does not appear. The conversation highlights the complexity of the calculations and the need for clarity in expressing these probabilities.
WMDhamnekar
MHB
What is the probability that among k random digits,
(a) 0 does not appear;
(b) 1 does not appear;
(c) neither 0 nor 1 appears;
(d) at least one of the two digits 0 and 1 does not appear?
Let A and B represents the events in (a) and (b). Express the other events in terms of A and B.
My answer to (a) : $\displaystyle\sum_{k=1}^{5}\binom{5}{k} (0.1)^k\cdot (0.9)^{5-k}= 0.40951$ = The probability that 0 appears in 5 random digits. So, 0 does not appear in 5 random digits is 1-0.40951 = 0.59049. ∴ In general terms, the answer is $(\frac{9}{10})^k$
My answer to (b):Same as computed for (a)
My answer to (c) :$(\frac{81}{100})^k$
My answer to (d): $ 2(\frac{9}{10})^k - (\frac{81}{100}) ^k$
If A= event (a) and B= event (b) , Other event can be expressed in terms of A and B as event (c)= A*B and event (d) = $A\cup B$
WMDhamnekar said:
My answer to (a) : ## \sum_{k=1}^{5}\binom{5}{k} (0.1)^k\cdot (0.9)^{5-k}= 0.40951 ## = The probability that 0 appears in 5 random digits. So, 0 does not appear in 5 random digits is 1-0.40951 = 0.59049.
That's a very complicated way to work it out.
WMDhamnekar said:
In general terms, the answer is ## (\frac{9}{10})^k ##
That's correct, and a much simpler way to work it out that bears no relation to what came before, so what was the point in that?
Clearly.
WMDhamnekar said:
My answer to (c) : ## (\frac{81}{100})^k ##
So would your answer to the question "P(none of {0,1,2,3,4,5,6,7,8,9} appears)" be ## \left ( \frac{9^{10}}{10^{10}} \right )^k ##?
WMDhamnekar said:
My answer to (d): ## 2(\frac{9}{10})^k - (\frac{81}{100}) ^k ##
You've got the right idea here, but you need to get (c) right and this should follow.
If there are an infinite number of natural numbers, and an infinite number of fractions in between any two natural numbers, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and... then that must mean that there are not only infinite infinities, but an infinite number of those infinities. and an infinite number of those...
