jperk980
- 47
- 0
In the figure below, a rigid beam is attached to two posts that are fastened to the floor. A small but heavy safe is placed at the six positions indicated, in turn. Assume that the mass of the beam is negligible compared to that of the safe.
(a) Rank the positions according to the force on post A due to the safe, greatest compression first, greatest tension last (use only the symbols > or =, for example, 1>2>3=4>5=6).
(b) Rank the positions according to the force on post B due to the safe, greatest compression first, greatest tension last (use only the symbols > or =, for example, 1>2>3=4>5=6).
I was easily able to get the answer to a which is 1>2>3>4>5>6, but using the same method i was not able to come up with a correct answer to b. I know that 3 is the greatest compression and 6 is the greatest tension. I was pretty sure that 2=4 and 1=5 but that does not seem to be the case. can you please help me get the answer. Thank you.
