Rational power of the imaginary unit
20 replies · 3K views
coreanphysicsstudent
solve i^2/3 using complex number.
below is my solution.
i^2/3=e^(2/3(lni)), ※(lni = i(pi/2+-2npi))
=e^2/3(i(pi/2+-2npi))=e^i(pi/3+-4/3npi)
※e^i(+-4/3npi)=+-1 (is tha correct?) .....(*)
e^ipi/3 = (1/2 + root3/2i)..........(**)
(**)(*) =e^i(pi/3+-4/3npi)= i^2/3 (using property of exponents)
So, my answer is +-(1/2+root3/2i)
but the real answer is −1, (1±i√3)/2
What's wrong with my solution?
please help me through.
Hello @coreanphysicsstudent , :welcome: !
First: you want to learn some ##\LaTeX## to typeset math stuff; it's worth the investment.
$$i^{2/3}$$ or $$i^{2/3}$$looks so much better than i^2/3 !
Or else learn to use the editing buttons to at least get i2/3
Re your answer: ##^e\log## domain (principal value) is restricted to ##\arg \log \in (-\pi,\pi]##
Furthermore: you have two answers (##\pm## the book answer) and you can check if both yield ##i## when raised to the 3/2th power !
Finally, it is good to use a simpler method for exponentiating complex numbers:
$${\bf z} = {\bf a}^x \Leftrightarrow \quad |{\bf z}| = |{\bf a}|^x \quad \& \quad \arg {\bf z} = x \arg {\bf a}$$
I think the quickest way here is to notice that ##i = e^{i(\frac{\pi}{2} + 2n\pi)}##
Easier: ##i = e^{i\,\pi/2} ##. Therefore the modulus of ##i^{2/3}## is 1 and the argument ##\pi/3##
We also don't say 1 = 1 * 1n
Right, but if you use the more general form then you also get other solutions like ##e^{\frac{5\pi}{3}i}##.
BvU said:
That is not ##i^{2/3}##
Wolfram alpha seems to give three roots, which correspond to different values of ##n##.
As @etotheipi notes, ##i = e^{i\,\pi/2+2ni\pi}=e^{\frac {i\pi}2(4n+1)} ##, so ##i^{\frac 23}=e^{\frac {i\pi}3(4n+1)}##
Well Thank you for your advice. I wil learn LaTex sooner or later.
But I really don't understand your answer, it's quite difficult that using arg. I don't have any ideas of arg method.here's my method below, can you please adjust my method?
and how can i find correct answer that book refer.
haruspex said:
No.
Can you inform why (*) is wrong, and the correct method.
You mean here ?
To which I can subscribe. But:
And this site seriously claims ##i^{2/3} = -1 ## ? and also that ##e^z = e^{-z} ## ?
Down at the bottom it gives you one with all the roots on it:
We can take ##{(e^{\frac{5\pi i}{3}})}^{\frac{3}{2}} = e^{\frac{5\pi i}{2}} = i##. I don't think it is claiming ##e^z = e^{-z}##, it is just that ##e^{-\frac{i \pi}{3}} \equiv e^{\frac{ 5 i \pi}{3}}##, which is another solution.
It's slightly odd behaviour, but I wonder if that is down to the weirdness of rational exponents like in this case... I could well have this all wrong, if I am missing a key rule or something!
Perhaps I am the one with o:) egg on my face, stubbornly holding on to demanding a unique value in the complex world.
Here (at 4/5 into the page) is a counter-example (##i^i##) :
Another common pitfall is finding "the solution" to an exponential and assuming that it is the unique solution.
I'm inciined to ask @LCKurtz !PS And that would mean OP has 2/3 of the answers and his book answer only 1/3 !
You changed which expression is labelled (*) and which is labelled (**).
This is correct: ##\displaystyle e^{i \pi/3}=\frac{1}{2}+\frac{\sqrt{3~}}{2}i## .
This is incorrect in general: ##\displaystyle e^{\pm i~ 4n\pi/3}=\pm 1## . Moreover, it doesn't follow from what precedes it in your work.
What you have preceding it is (you do not need the ± ) is: ##\displaystyle e^{i (\pi/3+4n\pi/3)} ##.
But ## \dfrac{\pi}{3}+\dfrac{4n\pi} 3 \ne \dfrac{4n\pi} 3##.
Rather ## \dfrac{\pi}{3}+\dfrac{4n\pi} 3 = \dfrac{(4n+1)\pi} 3 ## .
Try some values for ##n##.
No, the book answer presents all three:
"but the real answer is −1, (1±i√3)/2."
It comes down to the exact wording of the question. It is quoted as saying "solve i^2/3" but that doesn’t quite make sense. If it actually says "find the solutions of" then we are clearly not only concerned with the principal solution. If it says "find" then I would consider it ambiguous.
Maybe a quicker way:
##i^{2/3} = \left(i^2\right)^{1/3}=\left(-1\right)^{1/3}##.
Of course, treat this as complex.
In the main branch:
## i^{2/3}=e^{(2/3)Logi}=e^{(2/3)(i(\pi/2+2n \pi))}##. Exponentiation is single-valued within a branch.
Or looking at ##i^{2/3}## as the solutions to ##z^3=i^2=-1## or the 3 roots of ( negative) unity.
